usb module with dspic33f
Jim90
PostPosted: Sat Aug 17, 2013 6:59 pm     Reply with quote
I am trying to use a usb module but my problem is that there is not resources for usb for dspic33f series.
#define LED1 PIN_B7
#define LED2 PIN_B6
#define LED3 PIN_B5
//Transmit and Receive Packet Size
#define USB_CONFIG_HID_TX_SIZE 16
#define USB_CONFIG_HID_RX_SIZE 16
/*******VENDOR ID AND PRODUCT ID********/
#define USB_CONFIG_PID 1        //Chnage Vendor Id and Product Id
#define USB_CONFIG_VID 4660        //So that they will work with my Application
//#include<pic18_usb.h>
//#include<usb_desc_hid.h>
//#include<usb.c>
  #include <pic24_usb.h>
#include <usb_desc_hid.h>
//#include <usb_desc_scope.h>   //USB Configuration and Device descriptors for this UBS device
#include <usb.c>        //handles usb setup tokens and get descriptor reports
//Macro Definition for LED ON and OFF
#define LED_ON(x) output_low(x)
#define LED_OFF(x) output_high(x)
void usb_debug_task(void)
    static int8 last_connected;
       static int8 last_enumerated;
       int8 new_connected;
       int8 new_enumerated;
       new_connected = usb_attached();
       new_enumerated = usb_enumerated();
    if (new_enumerated)
          LED_ON(LED1);
          LED_OFF(LED1);
       if (new_connected && !last_connected)
          printf("\r\n\nUSB connected, waiting for enumaration...");
       if (!new_connected && last_connected)
          printf("\r\n\nUSB disconnected, waiting for connection...");
       if (new_enumerated && !last_enumerated)
        printf("\r\n\nUSB enumerated by PC/HOST");
       if (!new_enumerated && last_enumerated)
        printf("\r\n\nUSB unenumerated by PC/HOST, waiting for enumeration...");
       last_connected=new_connected;
       last_enumerated=new_enumerated;
    unsigned char in_data[16];
    unsigned int i;
    set_tris_b(0x00);    //Port-B as Output Port
    set_tris_c(0x10);
    output_b(0x00);
    LED_OFF(LED1);
    LED_OFF(LED2);
    LED_OFF(LED3);
    lcd_init();        //Initialize the LCD Module
    lcd_gotoxy(3,1);
    lcd_putc("PIC18F4550");
    Delay_ms(1000);
    lcd_gotoxy(3,2);
    lcd_putc("USB EXAMPLE!");
    printf("\r\n\nUSB Test Program--->Written in CCS PIC-C");
    printf("\r\nEMBEDDED LABORATORY\r\n");
    usb_init_cs();
    Delay_ms(1000);
    lcd_putc("\fRECEIVED DATA:-");
    Delay_ms(1);
        usb_task();
        usb_debug_task();
        if(usb_enumerated())
            if(usb_kbhit(1))
                lcd_gotoxy(1,2);
                lcd_putc("                ");
                usb_get_packet(1,in_data,16);
                printf("\r\nReceived Data: ");
                for(i=0;i<16;i++)
                    printf("%c",in_data[i]);
                    //Send the Recevied Data to Serial Port
                    lcd_gotoxy(1+i,2);
                    lcd_putc(in_data[i]);
                //Now Clear the in_data array
                for(i=0;i<16;i++)
                    in_data[i] = '\0';    //Null Character
PostPosted: Sat Aug 17, 2013 6:57 pm Reply with quote Edit/Delete this post Delete this post
#define LED1 PIN_B7
#define LED2 PIN_B6
#define LED3 PIN_B5
//#include<usb.c>
int8 new_connected;
if (new_enumerated)
LED_ON(LED1);
LED_OFF(LED1);
unsigned int i;
set_tris_c(0x10);
output_b(0x00);
LED_OFF(LED1);
LED_OFF(LED2);
LED_OFF(LED3);
lcd_gotoxy(3,1);
Delay_ms(1000);
lcd_gotoxy(3,2);
usb_init_cs();
Delay_ms(1000);
Delay_ms(1);
usb_task();
usb_debug_task();
if(usb_kbhit(1))
lcd_gotoxy(1,2);
lcd_putc(" ");
for(i=0;i<16;i++)
lcd_gotoxy(1+i,2);
for(i=0;i<16;i++)
Is anyone who can help me?
PostPosted: Sun Aug 18, 2013 4:37 am     Reply with quote
What chip are you actually trying to use?.
What compiler version?.
Only four of the DSPic's have a USB module. The 33EP256/512xx810/814. The module is the same unit as the PIC24EP.
On these chips the #define __PIC_24_USB_H__ is defined by the compiler, and the code does compile for these, but only with the latest compilers.
