Problem to measure time period
kalisaitan
PostPosted: Mon Jul 15, 2013 8:42 am     Reply with quote
I want to measure the frequency of the square wave input at RA0 of PIC16F877A.
So how should i start writing the code in C for CCS compiler??
Crystal frequency is 1MHz.
THANKS
Mike Walne
PostPosted: Mon Jul 15, 2013 9:27 am     Reply with quote
1) Have a go yourself, post code here when/if you get stuck.
2) Read the forum guidelines.
3) Tell us the frequency range of your signals.
4) Search here and google for similar code, it's been done before.
Mike
PostPosted: Mon Jul 15, 2013 10:06 am     Reply with quote
consider using either the CCP circuit
or the timer1 ext input with a gate from timer0
you may need a prescalar depending on frequency..
and your crystal frequency may be too low for higher input freq counts.
all these factors are inter related
thats my hardware advice
now per Mike
get coding..........
Very Happy Very Happy Very Happy Very Happy
PostPosted: Mon Jul 15, 2013 11:31 am     Reply with quote
Look at EX_FREQC.C. Except for having to change the clock (it is setup to use 20MHz), this is a complete example of how to do this. Except using the CCP input not RA0. Trying to do it on RA0, would limit the possible frequency supported to only a few hundred Hz.
Mike Walne
PostPosted: Mon Jul 15, 2013 2:21 pm     Reply with quote
Try this as a link for starters.
http://www.ccsinfo.com/forum/viewtopic.php?t=47653&start=0&postdays=0&postorder=asc&highlight=exfreq
Mike
kalisaitan
PostPosted: Mon Jul 15, 2013 7:02 pm     Reply with quote
thanx but i am beginner in programming,
i have no concept actually how code works
PostPosted: Mon Jul 15, 2013 7:30 pm     Reply with quote
If you don't know anything about code or electronics or anything, you
shouldn't be asking questions on the forum at this point in time.
You should be looking at tutorials on the net:
Here's a video by CCS on how to use their compiler to write a program:
http://www.ccsinfo.com/videos/QuickStartVideo.wmv
Also you should answer questions that people ask you, such as what is
the range of input frequencies that you want to measure ?
kalisaitan
PostPosted: Tue Jul 16, 2013 6:40 am     Reply with quote
i mean i understand about basic programming.But
I have no such concept about to measure Time period..
i want to measure frequency range of about 40 to 80 Hz
ezflyr
PostPosted: Tue Jul 16, 2013 7:29 am     Reply with quote
kalisaitan,
Do you actually own the CCS 'C' compiler? In your first post, locked and now deleted, you asked for help writing a 'Hi-Tech C' program. Suddenly,
a few hours later, you posed the exact same question, but this time you switched your query to the CCS compiler. You have been referred to the
CCS example programs, and other resources, but up to now, you haven't shown that you have actually done anything on your own. Personally, I think
you are trying to get us to do your homework assignment, and you have no actual interest in learning PIC programming.
John
PostPosted: Tue Jul 16, 2013 10:09 am     Reply with quote
the concept you need to solve this is for frequency/period/time:
T=1/F
you do understand that right ?
and the examples already cited ought to give you guidance.
have you read them yet?
gpsmikey
PostPosted: Tue Jul 16, 2013 11:43 am     Reply with quote
Since you mention "40-80hz", it sounds like measuring power line frequency. You don't mention accuracy, but if you are intending to read that to several digits to the right of the decimal, you need to consider measuring over multiple waves and taking the average or some other way of accurately measuring the time as well as how you are going to accurately measure the "period" of the wave (zero crossing or ??? )
mikey
mikey
