Dumb question - delay_ms disables interrupts?
billvon
PostPosted: Fri Jul 05, 2013 12:56 pm     Reply with quote
This is an odd one.
I have a 60Hz signal going to the RB0/INT0 pin. The following code works; it gives me a pulse on LED1 60 times a second.
#include <18F67K22.h>
#device ADC=12
#include <regdefs_18F67K22.inc>
#use delay (clock=40000000)
#use RS232 (stream=term, baud=115200, UART1)
#use RS232 (stream=GPS, baud=9600, UART2)
#int_ext
void ext_isr() {
   bit_clear(INTCON,1);
   output_high(LED1);
   delay_ms(1);
   output_low(LED1);
main() {
   OSCCON=0x00;         //default osc
   bit_set(OSCTUNE,6);      //PLL on
   hw_init();
   enable_interrupts(int_ext);
   enable_interrupts(global);
   while(1) {
However if I change the last part of the code to this:
        while(1) {
then I get ten pulses a second. Is delay_ms disabling interrupts? It seems like that would be a very bizarre thing for it to do.
--bill von
PostPosted: Fri Jul 05, 2013 1:08 pm     Reply with quote
#int_ext
void ext_isr() {
output_high(LED1);
delay_ms(1);
output_low(LED1);
main() {
while(1) {
Turn on compiler warnings. You will see a warning message that tells
you why it's done.
Yes, it has to in order for the PIC to 'twiddle it's thumbs' while it's delaying.....
If you dump out both of the listings you'll see how and why this happens.
For anything other than very simple programs, it's best to use some kind of timer/interrupt scheme for delays that won't prevent the PIC from handling interrupts.
PostPosted: Fri Jul 05, 2013 1:11 pm     Reply with quote
This FAQ article shows one way to do a work-around:
http://www.ccsinfo.com/faq.php?page=delay_in_interrupt
billvon
PostPosted: Fri Jul 05, 2013 1:35 pm     Reply with quote
PCM programmer wrote:
Turn on compiler warnings. You will see a warning message that tells you why it's done.
There it is: "Interrupts disabled during call to prevent re-entrancy: (@delay_ms1)" I missed it in all the warnings for "variable never used."
Thanks.
--bill von
PostPosted: Fri Jul 05, 2013 1:47 pm     Reply with quote
clever programmers set a flag variable - and do delays outside the ISR
i would switch the led -set a flag -
then do the delay in MAIN and release the LED
Very Happy Very Happy Very Happy
billvon
PostPosted: Fri Jul 05, 2013 2:43 pm     Reply with quote
Thanks for the suggestion. The delay within the ISR is for testing only and will be removed once I ensure reliable interrupts (I have three time-critical interrupts to deal with.) The final code in the ISR's will just increment a set of time registers then exit; all displaying/LED blinking etc will be in mainline code.
--bill von
Gabriel
PostPosted: Fri Jul 05, 2013 2:53 pm     Reply with quote
interrupts do just that... they ... interrupt.
if you hang inside the ISR with a delay, you are not interrupting... you are creating a mess... and testing you your interrupts will be dificult probably.
the delay within the ISR is for testing only and will be removed once I ensure reliable interrupts
i think you will only ensure you are interrupting wrong.
.... errrr... thus you should take the delays out.
G.
CCS PCM 5.078 & CCS PCH 5.093
billvon
PostPosted: Fri Jul 05, 2013 4:00 pm     Reply with quote
Works fine now with the delays in place. Thanks for the help everyone.
--bill von
