hemasc_
| Change serial parity |
Posted: Sat Jun 29, 2013 2:11 pm |
Hi!
I'm developing a device that the user has the option to change the serial parity.
There is the possibility that I do change the parity among the firmware?
For example:
if(true) #use rs232(baud=9600, parity=O,stop=1,xmit=PIN_C6,rcv=PIN_C7,bits=8, errors)
else #use rs232(baud=9600, parity=E,stop=1,xmit=PIN_C6,rcv=PIN_C7,bits=8, errors) |
But I need to change only parity! |
hemasc_
Posted: Fri Jul 19, 2013 12:48 pm |
SOLVED
| Code: | #locate RCSTA = 0xFAC
#locate TXSTA = 0xFAB
#use rs232(baud=9600,xmit=pin_c6,rcv=pin_c7,errors,stream=COMM_1,enable=PIN_B1)
if(bit_with_parity)
bit_set(TXSTA,6);
bit_set(RCSTA,6);
bit_clear(TXSTA,6);
bit_clear(RCSTA,6);
