write_fix_value_external_eeprom
tienchuan
PostPosted: Tue Jun 25, 2013 1:25 am     Reply with quote
Dear all.
I want to write fixed value into external eeprom when programing like command :
 #rom  int8 0xF00000={0,0}
Can I do this work in CCS C?
my version : 4.140, PIC18F4680, external EEPROM : AT24C04 ( it work well with 2404.c driver of CCS C)
Pls show me way to fix it?
Thanks all.
Begin Begin Begin !!!
PostPosted: Tue Jun 25, 2013 1:58 am     Reply with quote
Of course not.
The external EEPROM, is nothing to do with the PIC.
You need to program it with a hex file of it's own, and using a suitable programmer.
tienchuan
PostPosted: Tue Jun 25, 2013 3:02 am     Reply with quote
thanks Smile
It was solved by code, but when want to change fixed value, must change code and reprograming.
and here is my code:
1. to write fixed value into ext eeprom:
      write_ext_eeprom(0,1);
      write_ext_eeprom(1,0);
      write_ext_eeprom(2,0);
2. change code for the 2nd programing:
   write_offset=read_ext_eeprom(0);
   printf("\n\r offset n\r", write_offset);
   if(write_offset==0)
      output_low(PIN_C1);
      output_low(PIN_C2);
      output_high(PIN_C1);
      output_high(PIN_C2);
Thanks all Smile
PostPosted: Tue Jun 25, 2013 4:00 am     Reply with quote
Seriously, use an array:
const int8 eeprom_vals[]={1,0,0}
   int count;
   for (count=0;count<sizeof(eeprom_vals);count++)
       write_ext_eeprom(count,eeprom_vals[count]);
