neochrome32
| Why is THIS important?? |
Posted: Sun Jun 23, 2013 1:32 pm |
Ok, i am ripping out my hair because no matter what CCS says, the data sheet doesn't match up.
I've used this chip successfully before, on CCS 4.114
SAME code, 4.130 it works yet the system keeps rebooting or restarting as though Watch dog is in use!
CCS 4.114, it works FINE, ONLY when i have a call to reset_cpu() in a FUNCTION that is NEVER used! or setup as interrupted!??
#include "24HJ128GP502.h"
#device *=16
#device WRITE_EEPROM = NOINT
#FUSES WPRES32 //Watch Dog Timer PreScalar 1:32
#FUSES WPOSTS1 //Watch Dog Timer PostScalar 1:1
#FUSES PROTECT_HIGH //General Segment Code Protect High Security
#FUSES CKSFSM //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOBSS //No boot segment
#FUSES NORBS //No Boot RAM defined
#FUSES NOWRTSS //Secure segment not write protected
#FUSES NOSSS //No secure segment
#FUSES NORSS //No secure segment RAM
#FUSES PR_PLL //Primary Oscillator with PLL
#FUSES FRC_PLL
//#FUSES NOPR //Primary Oscillator with PLL
//#FUSES NOPR //Pimary oscillaotr disabled
#FUSES OSCIO //OSC2 is general purpose output
#FUSES NOIOL1WAY //Allows multiple reconfigurations of peripheral pins
#FUSES CKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WINDIS //Watch Dog Timer in Window mode
#FUSES PUT128 //Power On Reset Timer value 64ms
#FUSES NOALTI2C //I2C mapped to alternate pins
#FUSES ICSP1 //ICD uses PGC1/PGD1 pins
#FUSES NOJTAG //JTAG disabled
#use delay(clock=64M, CRYSTAL=12M)
#pin_select U1TX = PIN_B0
#pin_select U2RX = PIN_B1
#PIN_SELECT OC1 = PIN_B6 // AUDIO RIGHT , LEG 15.
#PIN_SELECT OC2 = PIN_B7 // AUDIO LEFT, LEG 16
#pin_select SS1OUT = PIN_B15
#pin_select SCK1OUT = PIN_B14
#pin_select SDI1 = PIN_B13
#pin_select SDO1 = PIN_B12
//#use rs232(UART1, baud=57600,parity=N,bits=8,stream=PORT1)
#use rs232(STREAM=UART1,baud=57600, parity=N,bits=8,ERRORS)
#DEFINE RIGHT_PWM 0x01
#DEFINE LEFT_PWM 0x02
#use fast_io(b)
#ZERO_RAM
#bit SSPEN=getenv("BIT:SSPEN")
/* THESE ARE MY CHIP SPECIFICS */
#define MMC_CS PIN_c2
#define MMC_CLK PIN_c3
#define MMC_DI PIN_C4
#define MMC_DO PIN_C5
#define MMCSD_PIN_SELECT MMC_CS //o
#define MMCSD_PIN_SCL MMC_CLK //o
#define MMCSD_PIN_SDI MMC_DI //i
#define MMCSD_PIN_SDO MMC_DO //o
#use FAST_IO(C)
#include <string.h>
#define SOUNDBUFFERSIZE 1536
char buffer[SOUNDBUFFERSIZE];
//char soundBuffer[SOUNDBUFFERSIZE];
int16 buffer_load;
int16 buffer_read_pos;
int16 buffer_write_pos;
//#include "modplay/modplayer.c"
//#int_timer3 HIGH // wave form processor
void PlayBuffer(){
if(buffer_write_pos != buffer_read_pos){
//set_pwm2_duty((int16)buffer[buffer_read_pos]);
set_pwm_duty(LEFT_PWM, (int16)buffer[buffer_read_pos]);
buffer_read_pos++;
buffer_read_pos &= SOUNDBUFFERSIZE -1;
if(buffer_load>0) buffer_load--;
if(input(PIN_B11)) reset_cpu(); //<---------- crazy times! this funtion is NOT called, yet its a matter of working or not! (CCS 4.114) although CCS 4.130- the chip just constantly reboots)
clear_interrupt(int_timer3);
void main(){
setup_wdt(WDT_OFF);
//setup_timer1(TMR_INTERNAL | TMR_DIV_BY_8, 0x422F); // used to get 750hz ADSR controllers /// 80Mhz, on 6Mhz Crystal
//setup_timer3(TMR_INTERNAL | TMR_DIV_BY_8, 0x012E); // Wave Form Processing is mean for 22Khz Sampling. /// 80Mhz, on 6Mhz Crystal
setup_compare(RIGHT_PWM, COMPARE_PWM | COMPARE_TIMER2 ); // configue output as PWMs
setup_compare(LEFT_PWM, COMPARE_PWM | COMPARE_TIMER2 ); // configue output as PWMs
set_pwm_duty(RIGHT_PWM, 128);
set_pwm_duty(LEFT_PWM, 128);
set_tris_b(0b0000000000000000);
delay_ms(10);
fprintf(UART1, "Booted from PIC24HJ\r\n");
// now UP THE CLOCK DRIVER for FULL on CPU usage! about 50MIPS (20% over clocked... seems safe here, any higher and risking RAM issues)
setup_oscillator( OSC_CRYSTAL , 64000000);
for(;;){
output_high(pin_b10);
output_low(pin_b10);
Posted: Sun Jun 23, 2013 2:05 pm |
I'd have to dump out the listings and compare the two.
It's not uncommon that a fuse(maybe WDT) is being set/reset to the wrong condition for a different compiler version which we can't tell by just the program.
hth
jay |
Posted: Sun Jun 23, 2013 2:07 pm |
You have not got a UART selected in your #use RS232. Surprised it compiles. The line above 'remmed' out, does have the UART selected, but lacks 'ERRORS'.
I'd suspect you were compiling with this line before.
Mike Walne
Posted: Sun Jun 23, 2013 2:50 pm |
If it's re-booting, get the PIC to tell you what is causing the re-boot.
Attack the problem head on, don't flounder in the dark.
Mike |
neochrome32
Posted: Sun Jun 23, 2013 6:50 pm |
the line
the one remmed out, didn't compile :( it was strange...
but why.. would a function that is NOT called, cause the chip to work?? |
neochrome32
Posted: Sun Jun 23, 2013 7:04 pm |
it just fixed it self! ok, now i AM confused!
the timing seems abit off though
12M crystal, and clock=48M
the seconds seem a few miliseconds off... |
gpsmikey
Posted: Sun Jun 23, 2013 7:16 pm |
A long shot, but I have run into things like that before where a function (or other "stuff") got compiled in, but was not called and changed the behavior because it moved things around in memory just by being there. I have seen that before.
mikey _________________ mikey
neochrome32
Posted: Mon Jun 24, 2013 2:08 am |
GPSMikey. It felt that way before, i've kept my old copy of CCS 4.114, compiled an old project,
then compile the same project in CCS 4.130, uploaded to chip..
then compile the code abolve in ccs 4.130 and things seem to work!??
I cant feel confident in CCS 4.130! as Fuses appears to be doing different things and/or there are more options of/else difference!
frustrated a bit though..
thanks everyone, dont normally ask for help i try to read up as much as possible first, but this one bugged me hells over!
---- thank you again folks ---- |
Posted: Mon Jun 24, 2013 5:00 am |
I can't follow the problem report. Uncalled functions are removed during compilation, review the listing file.
Thus there are probably other reasons for reboot. Reboot with 16-Bit PICs should be always suspected
to be caused by a trap interrupt. Methods to catch it have been previously discussed in the forum. |
