PIC16F1519 UART not receiving
tojape
PostPosted: Fri Jun 21, 2013 12:49 pm     Reply with quote
Hi all,
I am having problem with a cheap pic micro: PIC16F1519 doesn't receive on RX pin (C7, pin 26) with the following code:
rs232test.c
#include <rs232test.h>
char chin=0x55;
disable_interrupts(GLOBAL);
setup_wdt(WDT_OFF);
printf(__FILENAME__);
   if(kbhit())
         chin=getc();
   putc(chin);
rs232test.h
#include <16F1519.h>
#device adc=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES WDT_SW                   //No Watch Dog Timer, enabled in Software
#FUSES PUT                      //Power Up Timer
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#use delay(clock=11045200)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1,errors)
The file name appears on the terminal screen, then the endless letter "U" comes despite of my typing on the keyboard.
Dropping a PIC18F46K22 in the socket of the PIC16F1519 works fine with the same main() function.
I tried to use the sw implementation of rs232 I/O adding "force_sw" option to the #use rs23 directive. The result is even worse.
The printf() works OK then instead of letters "U" (an 50% duty cycle waveform on the oscilloscope) 932us start level pulses appear. This is the duration of 9 bits@9600bps (1 startbit + 8 pieces of 0 bits). I am rather stuck with this problem.
Is it a bug of my compiler version (4.124) or am I doing something wrong?
The computer helps solving the problems which would have never arised without computers
ezflyr
PostPosted: Fri Jun 21, 2013 1:30 pm     Reply with quote
You are doing something wrong. When you specify a 'stream' in your #use rs232 statement, that stream name must then be used with the kbhit, getc,
and putc functions.
Try this code instead:
    chin=fgetc(PORT1);
    fputc(chin, PORT1);
Note, keep your COMMs test very simple until you know it's working properly, then you can add back the 'kbhit' and the delay so that you
continuously show the last character received.
John
dyeatman
Is your clock really this speed?
Also, you specify a stream in your use statement but nowhere else...
Google and Forum Search are some of your best tools
tojape
PostPosted: Fri Jun 21, 2013 1:59 pm     Reply with quote
Thanks to both of you for your replies.
I didn't bother with stream name since if I don't specify it in the serial I/O functions the compiler assumes the last used "USE RS232" stream. But you are right, I have to keep the test code as simple as possible.
I reduced my code, here it is, still not operable:
#device adc=16
#use delay(clock=11059200)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
char chin;
         chin=getc();
         putc(chin);
As you can see, I corrected the crystal frequency (which was not the problem, I simply mistyped it when I created the test project. The error was ignorable)
Sending the last char informed me during the test that my program hasn't hang or whatever...
Thank you again, and do you have any other idea?
PostPosted: Fri Jun 21, 2013 3:20 pm     Reply with quote
In your version (vs. 4.124), the compiler start-up code leaves PortC as an
analog port, whereas in vs. 4.141 it configures it as digital. To fix your
version and make PortC be digitial, add the line shown in bold below:
char chin;
setup_adc_ports(NO_ANALOGS);
chin=getc();
putc(chin);
tojape
PostPosted: Fri Jun 21, 2013 3:40 pm     Reply with quote
Thank you very much!
While you were typing I've found out the workaround adding the following code: :-)
#ASM
   CLRF 0x18E
#ENDASM
When I realized that the initialization is not correct in the assembly listing I tried my version and it worked.
However I will use your solution since yours doesn't depend on direct physical address.
Thank you again!
PS. Just for reference: 4.124 compiler initialization (ANSELC is missing!!!)
001C:  CLRF   FSR0H
001D:  CLRF   FSR0L
001E:  MOVLW  1F
001F:  ANDWF  STATUS,F
0020:  CLRF   rs232_errors
0021:  MOVLB  03
0022:  BCF    BAUDCON.BRG16
0023:  MOVLW  11
0024:  MOVWF  SPBRGL
0025:  MOVLW  A2
0026:  MOVWF  TXSTA
0027:  MOVLW  90
0028:  MOVWF  RCSTA
0029:  CLRF   ANSELA
002A:  CLRF   ANSELB
002B:  CLRF   ANSELD
002C:  CLRF   ANSELE
