USB HID send first data
SuperDave
PostPosted: Wed Jun 19, 2013 1:23 pm     Reply with quote
Delphi on the PC, CCS C compiler for 18LF13K50
Enumeration works fine. Trying to write some data to endpoint 0
Delphi
MyDevice.WriteFile(SendUSB, 5, Written)  // actual data 0,1,2,3,4
returns true (ie. success, 0 is endpoint zero, next four bytes are simple data, written changes from 0 before to 5 after)
CCS C - 18LF13K50 running and enumerated
void main()  {
  enable_interrupts(INT_USB);  //not sure needed
  enable_interrupts(global);
  usb_init();
  testdelay := 1;   //to see scope change on C1
  while (1) {
    output_toggle(Pin_C1);
    delay_ms(testdelay);
    if (usb_kbhit(0)) {  //should be true if endpoint 0 has data
   testdelay = 2;
  }  //end while (1)
}  //end main
TestDelay does not change from 1mS to 2mS. ie. usb_kbhit(0) is not triggering. Any idea why?
Configuration
#ifndef USB_CONFIG_HID_TX_SIZE
   //valid range is 0-255
   #define USB_CONFIG_HID_TX_SIZE   4  //
#ifndef USB_CONFIG_HID_RX_SIZE
   #define USB_CONFIG_HID_RX_SIZE   4     //
asmboy
PostPosted: Wed Jun 19, 2013 3:54 pm     Reply with quote
on WHAT OS and version might that be ??
also -you post so little code, ( and no includes - etc etc )
- that I don't see how anyone will be able to help you solve this.
PostPosted: Thu Jun 20, 2013 12:37 am     Reply with quote
USB endpoint 0, is reserved in USB for device control transfers.
Can't have less than 8 bytes. Normally controls things like DTR etc..
Your normal transfers cannot use this endpoint.
SuperDave
PostPosted: Thu Jun 20, 2013 5:12 am     Reply with quote
Thank you. Your statement "Can't have less than 8 bytes." is at odds with the configure comment "//valid range is 0-255" Is endpoint 0 restricted to 8 bytes?
PostPosted: Thu Jun 20, 2013 7:26 am     Reply with quote
Yes.
It is in the USB spec.
The very first packet sent to any USB device, is a 'setup' packet on endpoint 0, and is 8 bytes in size. This happens as the first part of enumeration. EP0, is reserved for command packets.
