Little help, please
Goto page 1, 2  Next
Jean FOUGERON
Little help, please
PostPosted: Fri Jun 07, 2013 1:59 am     Reply with quote
Hi friends
It's surely a stupid issue but ...
#define E_MI !input(PIN_A0)
#define E_HI !input(PIN_A1)
#define E_Alarm !input(PIN_A4)
//#define E_Alarm !input(PIN_B4)
#define S_MI(x) output_bit(PIN_B3,x)
#define S_HI(x) output_bit(PIN_B2,x)
#define S_Alarm(x) output_bit(PIN_B5,x)
//variables-------------------------------------------------------------------
//Initialisation--------------------------------------------------------------
void initialisation()
   setup_wdt(WDT_ON);
//--------------------------------------------------------------------------Main
   initialisation();
   while(true)
      restart_wdt();                     // resetter le watch dog !
      S_MI(E_MI);
      S_HI(E_HI);
      S_Alarm(E_Alarm);
I use a PIC18F1230 to take advantage of pwm functions (not listed above)
In this code input(PIN_A0) does not work, nor other PIN_Ax
only PIN_B4 works
I mean that when I switch PIN_A0 to ground, or to 5V the Led connected at PIN_B3 always lit
Is there a reason ?
(the other pins are uses as follow :
A3 as RX
B0 as PWM0
A6 and A7 for the ceramic resonnator
B6 and B7 for the ICSP
Thanks for your suggestions
PostPosted: Fri Jun 07, 2013 2:33 am     Reply with quote
First a few general notes:
1) As a regular visitor on this forum you should know we like to see programs posted that are complete, including all fuses, etc. This saves us time as we can copy/paste the program to our IDE, but even more important is that we than can be sure to have the exact situation you are using. Often a wrong fuse setting can cause many strange behaviours.
2) Always post your compiler version number! It can be an issue specific to your version.
3) Do you really need a watchdog? Watchdogs often cause more problems than they solve. For 95% of the situations where your device has a user sitting next to it who can power cycle the device when it hangs, no watchdog is needed. At least, during development disable the watchdog to make life a lot easier to yourself.
4) Without the watchdog your posted program will be shorter. We like short programs.
Then your problem at hand. I don't want to find the problem for you as I think there are a few more steps you can take yourself:
- Did you have a look at the generated assembly code? It might give you some clues. See the list file (*.lst)
- Have you tried writing the input and output commands as separate program lines instead of combining them in a macro?
- Just wondering, but I do hope you have a debugging tool? An In Circuit Debugger like ICD2 or PicKit3 is essential. Single stepping through your code you should be able to find the problem easily.
Mike Walne
PostPosted: Fri Jun 07, 2013 3:12 am     Reply with quote
Like ckielstra says you should know the format by now. You're not being terribly helpful.
Maybe, since you've a problem with all the portA pins but not portB, it's something to do with portA pins defaulting to ANALOG inputs?
Mike
Jean FOUGERON
PostPosted: Fri Jun 07, 2013 4:09 am     Reply with quote
My PCH is V 4.14
My .h is as follow
#include "18F1230.h"
//#device adc=8                  //Where x is the number of bits read_adc() should return
#FUSES WDT32768                 //Watch Dog Timer uses 1:32768 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
//#FUSES H4                       //High speed Osc with PLL (> 4mhz)
//#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
//#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOSTVREN                 //Stack full/underflow will not cause reset
//#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#FUSES NOLVP                      //No Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRTC                   //configuration registers not write protected
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#use RS232(BAUD=75,BITS=8,PARITY=N,STOP=1,ERRORS)
Which is nearly the same for each project
My code is
#include "CPL.h"
#define PERIODE 0x31
long L_Periode;
boolean B_Isr1;
   //setup_wdt(WDT_ON);
   L_Periode=2*PERIODE;
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);  // 13ms pour T1_Div_BY_1 & 0xFFFF : 75Bdx
   setup_power_pwm_pins(PWM_COMPLEMENTARY,PWM_OFF,PWM_OFF,PWM_OFF);
      //PPWM channels 0 and 1 are both on and always opposite values
   setup_power_pwm(PWM_CLOCK_DIV_4|PWM_FREE_RUN,1,0,PERIODE,0,1,0);
   set_power_pwm0_duty(L_Periode);
//génération des pulses ---------------------------------------
#int_TIMER1
void BF()
   B_Isr1=TRUE;
Boolean B_BF;
   initialisation();
   while(true)
      //restart_wdt();                     // resetter le watch dog !
      S_MI(E_MI);
      S_HI(E_HI);
      S_Alarm(E_Alarm);
      if(B_Isr1)
         B_BF=!B_BF;
         B_Isr1=FALSE;
         set_power_pwm0_duty(L_Periode * (int)B_BF);
         output_bit(PIN_B6,B_BF);
It seems there is no reason why thes 3 pins are not read
z3ngew
PostPosted: Fri Jun 07, 2013 4:41 am     Reply with quote
I think the problem might be in wdt and infinite loop but i'm not sure
   while(true)
try to change this code structure,
Good Luck,
z3ngew
Jean FOUGERON
PostPosted: Fri Jun 07, 2013 7:14 am     Reply with quote
   while(true)
Good Luck,
z3ngew
Sorry it doesn't work independantly of watch dog. I always include a watchdog in my application, and it is the first time I cannot read a port.
Jean FOUGERON
PostPosted: Fri Jun 07, 2013 7:37 am     Reply with quote
I exchange the PICF1230 with a PIC18F1220 and ... PIN_A4 is read but still PIN_A0 nor PIN_A1 is not read.
What special could have these pins ?
I think Mike has given you the key. The rule always is that you need to turn off peripherals that are on pins, before you can be sure of using them. Port A on this chip, has both the normal analog inputs, and the comparator on it. Then the serial on A2/A3. Remember also A5 is _input only_.
Jean FOUGERON
PostPosted: Fri Jun 07, 2013 8:04 am     Reply with quote
OK
You're right.
I add setup_adc_ports(NO_ANALOGS); in the init and it works.
It is the first time I have to do that, maybe a coincidence ?
Thanks a lot.
PostPosted: Fri Jun 07, 2013 8:44 am     Reply with quote
It has a lot to do with PIC type and compiler version.
Seems a single pin can have 1,2,5 different uses these days!
CCS will change the default use of I/O pins to digital,though only on some versions(newer) of some compilers.
Since it isn't consistent,you should ALWAYS 'hardcode' the pins uses.NEVER take anything for granted.
From an 'old guy' perspective, I'm 'miffed' that the default use of pins isn't set to digital I/O instead of any number of fancy peripheral uses !
Guess some guys at microchip figure nobody uses I/O that way anymore ?
cheers
jay
Jean FOUGERON
PostPosted: Tue Jun 11, 2013 7:16 am     Reply with quote
cheers
jay
I agree so much !
Jean FOUGERON
PostPosted: Tue Jun 11, 2013 7:27 am     Reply with quote
And now, in the same project, a new issue appears !
#use RS232(BAUD=75,BITS=8,PARITY=N,STOP=1,UART1)
#include "CPL.h"
Boolean B_Emetteur=FALSE;
long L_Periode;
boolean B_Isr1;
char I_buffer;
   setup_wdt(WDT_ON);
   setup_adc_ports(NO_ANALOGS);   // pas d'analog. au reste les pin A0 A1 et A4 sont analogiques par défaut !
   setup_timer_0(T0_INTERNAL | T0_DIV_64);  // XXms pour T3_Div_BY_16
#int_TIMER0
void Sec()
   output_toggle(PIN_B3);
   if (B_Emetteur)
      putc(I_buffer);
      putc(I_buffer);
#int_RDA
void Receive()
char I_Caract1;
char I_Caract2;
   I_Caract1=getc();
   I_Caract2=getc();
   //S_Alarm(I_Caract1==I_Caract1);
   S_Alarm(TRUE);
boolean B_MI;
boolean B_HI;
Boolean B_Alarm;
   initialisation();
   while(true)
      B_MI=E_MI;
      S_MI(B_MI);
      B_HI=E_HI;
      S_HI(B_HI);
      B_Alarm=E_Alarm;
        //S_Alarm(B_Alarm);
                                            // bit 0 a chaque fois
                                            // bit 1 MA
                                            // bit 2 MI
                                            // bit 3 HI
                                            // bit 5 Alarm
        I_Buffer=0x01 + (int)B_MI*0x04 + (int)B_HI*0x08 + (int)B_Alarm *0x20;
      set_power_pwm0_duty(L_Periode *(int)(!input_state(PIN_A2))); //le PWM marche quand TX est au niveau bas
I have 2 panel with this code.
Panel 1 send a message of 2 bytes to panel 2
It really send it, I see it on the oscilloscope !
I expect Panel 2 receives it. But #int_RDA does not fire !
The Led of S_Alarm does not lit as it should !
But I see the signal on PIN_A3/RX of my PIC18F1230
(I precise my compiler version is PCH V 4.14)
Where could be my error ?
Thanks to all
PostPosted: Tue Jun 11, 2013 8:28 am     Reply with quote
First, what is the compiler version!.....
Version numbers are always 4.xxx. Are you actually on 4.014 or 4.140?. If the former, give up!. The earliest reasonably working V4 compilers were around 4.06x ish.
Then realise that INT_RDA, implies _one_ character is waiting to be read only. Not two.
#int_RDA
void Receive()
   char temp;
   static int8 old;
   static int1 state=FALSE;
   temp=getc();
   switch (state) {
   case FALSE:
       old=temp;
       state=TRUE;
   case TRUE:
       state=FALSE;
       if (old==temp)
          S_Alarm(FALSE);
          S_alarm(TRUE);
Then study your code. Where do you enable INT_RDA?.....
This is the 'biggy'..... Smile
Jean FOUGERON
PostPosted: Wed Jun 12, 2013 1:07 am     Reply with quote
V 4.140
Dear, what distrait am I ! Embarassed
Is it a sign of early Alzheimer ?
Thanks for all
Jean FOUGERON
PostPosted: Wed Jun 12, 2013 7:49 am     Reply with quote
In another way :
My receive routine is as follow :
#int_RDA
void Receive()
   I_Receive[I_Receive_Counter]=getc();
   I_Receive_Counter++;
   if(I_Receive_Counter==2)            // reçu 2 caractères
      I_Receive_Counter=0;
      if(I_Receive[0]!=I_Receive[1])   //problème
         I_Send=0x81;                  // bit 7 = demande de renvoyer
         B_Reponse=TRUE;
         S_Alarm(FALSE);
         B_MI=(I_Receive[0]&0x04);
         B_HI=(I_Receive[0]&0x08);
         B_Reponse=FALSE;
         S_Alarm(TRUE);
Where I expect that B_MI goes TRUE when I_Receive[0] has its bit 2 set, and FALSE in the other cases.
But, when I apply 0x05, 0x0D 0x25 or 0x2D on the pin RX of my PIC, B_MI stays FALSE
Now, when I use this routine :
switch (I_Receive[0])
            case 0x05:
               B_MI=TRUE;
            case 0x0D:
               B_MI=TRUE;
            case 0x25:
               B_MI=TRUE;
            case 0x2D:
               B_MI=TRUE;
            default:
               B_MI=FALSE;
B_MI goes TRUE when I_Receive[0] has its bit 2 set !!
I look at .lst and observe :
....................          B_HI=(I_Receive[0]&0x08);
0136:  MOVF   1D,W     --> W=I_Receive[0]
0138:  ANDLW  08       --> W=W & 0x08  Flag Z is actioned if bit 2 not set
013A:  BCF    19.4     --> B_HI=False
013C:  BTFSC  FE8.0    --> test bit 0 of FE8 (what is FE8 ?) and branch to 013E if not set
013E:  BSF    19.4     -->B_HI=true => FE8.0 is set
I understand that we proceed to as Bitwise AND between I_Receive[0] and bit 2, if the result is 1 then B_HI=True else B_HI=false
But in reality B_HI stays FALSE !
When I use the switch procedure, I have :
....................          switch (I_Receive[0])
0110:  MOVF   1D,W
0112:  XORLW  05
0114:  BZ    0124
0116:  XORLW  08
0118:  BZ    0128
011A:  XORLW  28
011C:  BZ    012C
011E:  XORLW  08
0120:  BZ    0130
0122:  BRA    0134
....................             case 0x05:
....................                B_MI=TRUE;
0124:  BSF    19.3
....................                break;
0126:  BRA    0136
....................             case 0x0D:
0128:  BSF    19.3
012A:  BRA    0136
....................             case 0x25:
012C:  BSF    19.3
012E:  BRA    0136
....................             case 0x2D:
0130:  BSF    19.3
0132:  BRA    0136
....................             default:
....................                B_MI=FALSE;
0134:  BCF    19.3
Wich is more complicated but which does what I expect : B_MI=TRUE when bit 2 of I_Receive[0] is set !
0110:  MOVF   1D,W    --> W=I_Receive[0]
0112:  XORLW  05       --> W=W XOR 05 ==0 only if bit 2=1 (which means B_MI has to be TRUE) and other bits are equals each other ! which generally is not the case !
0114:  BZ    0124        --> branch if equals zero
0124:  BSF    19.3      --> set B_MI to True
So ... I'm lost and do nor see why my simple routine using a & does not work and a complicated one does !
Thanks to all
Goto page 1, 2  Next
Page 1 of 2
