ccsload: code not protected problem.
jai
PostPosted: Thu Jun 06, 2013 7:46 am     Reply with quote
Hi all,
I am programming the 16F887 with the fuses
#FUSES NOWDT
#FUSES HS
#FUSES NOBROWNOUT
#FUSES NOLVP
#FUSES MCLR
#FUSES PROTECT
Also tried with this
#FUSES WRT_1000
same result.
Complete erase has also been tried.
But looks like the code is not protected. CCSLOAD 4.40 gives the message
CODE not protected after programming device.
please can somebody tell me what to do?
regards,
jaikumar.
PostPosted: Thu Jun 06, 2013 3:02 pm     Reply with quote
Are you compiling in Debug mode or Release mode ? If you compile in
debug mode, the compiler will change several of the fuses. That's
because the ICD debuggers will not work with, or do not support certain
fuses.
Here is an example program. Notice that I have Watchdog, code protect,
and brownout enabled:
#include <16F887.H>
#fuses INTRC_IO, WDT, PROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
When I compile in Release mode, I get the fuses set the same way that
I specified in the program. This list is at the bottom of the .LST file:
Configuration Fuses:
   Word  1: 2FAC   INTRC_IO WDT PUT MCLR PROTECT NOCPD BROWNOUT IESO FCMEN NOLVP NODEBUG
   Word  2: 3FFF   BORV40 NOWRT
But then I compile the program in Debug mode. Here is the fuse list
at the end of the .LST file:
Word 1: 0CF4 INTRC_IO NOWDT NOPUT MCLR NOPROTECT NOCPD NOBROWNOUT IESO FCMEN NOLVP DEBUG
Some fuses have been forced to be compatible with the ICD debugger.
Notice that CCS has changed several of the fuses to "NO". So if you
want certain fuses to be enabled, make sure that compile in Release
mode. Do not try use the ICD for debugging (Breakpoints, etc) in Release
mode. "Release" mode means compile for production.
In MPLAB vs. 8.x, the selection of Debug/Release is done with a drop-
down box at the top of the MPLAB window. It's visible all the time.
I don't know how to select Debug/Release with the CCS IDE, because I
don't have it. I use the command line CCS compilers with MPLAB.
jai
PostPosted: Fri Jun 07, 2013 12:18 am     Reply with quote
Dear PCM programmer,
Thanks for the reply.
I am not on debug mode.
I also found that if i program without code protect and make a chip = file verify
there is a 100% match.
But when i set code protect with the fuses. When i do verification chip = file
I get a message
There are errors
Error patterns indicate code protection may be active.
The thing is the verification of code protection soon after programming always says "Code not protected" could this be a possible error in the programmer?
regards,
Jai.
jai
PostPosted: Fri Jun 07, 2013 12:42 am     Reply with quote
Hi all,
Yes i would like to confirm that there is a error in
CCSLOAD Programmer Control Software for Windows - 4.040 and 4.039
I tried v4.025 there is no error in that version.
It displays code protect verification message as it should.
I hope CCS will fix this.
Regards,
Jai.
PostPosted: Fri Jun 07, 2013 1:29 am     Reply with quote
You should never be able to 'verify' a code protected chip. Depending on the chip, older chips when read with code protection enabled, will return a 'scrambled' version of the code, while later chips just read as blank if code protection is enabled. Verify can't then work.
The 'standard' sequence to program a code protected chip, is to program and verify with code protection off, _then_ enable just the code protection fuse.
On older chips what you could do, was to program and verify a chip, then enable it's code protect fuse, and read the scrambled contents back. Save this. Then write new chips with the protection enabled, and verify them against the scrambled file. The same 'code' would always give the same 'scrambled' result.
It sounds as if 4.025, is not setting the code protect bits, hence the chip verifies...
I'd say that the later version is doing what it should. Refusing to verify if code protection is enabled.
However then have to point out that all these versions are at best 'beta'; compiler versions. It is generally held that first 'reasonably working' V4 compilers, were around 4.068 and later....
4.040, has to be perhaps three years old.
Realise you are talking about CCSLoad, not CCSC. So version numbering is different, but comment still applies. I'd say the newer version is doing what it should, and is not able to verify a code protected chip.
jai
PostPosted: Fri Jun 07, 2013 6:44 am     Reply with quote
Dear Ttelmah,
Thank you for the info.
I think i should clarify the problem.
I understand that if not protected the verification must be chip = file.
and if protected chip not equal to file.
But the problem here is that in CCS programmer CCSLOAD V4.040 in the
settings tab there is a VERIFY ROM PROTECT AFTER WRITE.
Which when programmed with PROTECT should come after programming and display CODE PROTECTED.
This never happens - it always says NOT PROTECTED with fuse protect or not.
But it works on CCSLOAD V4.025.
regards,
jai.
