2-Wire LCD Interface
mohamed2040
PostPosted: Thu May 30, 2013 1:33 pm     Reply with quote
hello everybody !
i use pc 16F877 4MHZ i wanna use the bus I2C to communicate with (DS1703 TIME - AND my LCD 16x2)
the communication with PIC and LCD use an flip-flops into 74LS174 this is refer to "Myke method" you can join : http://www.rentron.com/Myke1.htm
so ! i make a search on ccs forum ! i find this two result :
http://www.ccsinfo.com/forum/viewtopic.php?t=24426&highlight=74ls174
http://www.ccsinfo.com/forum/viewforum.php?f=1
and no solution yet ! cause the code or driver was wrong !
so can you help me !
this is a big problem :( thank you
PostPosted: Thu May 30, 2013 1:45 pm     Reply with quote
You cannot use the I2C peripheral of the PIC to communicate with the 'Myke method of LCD control' schematic.
Although it is a 'clock and data' serial communications protocol it is NOT I2C.
You'll have to use 2 other pins for your LCD system leavng the I2C pins for the DS1307 RTC. Be sure to use correct pullups on the I2C bus line !!
hth
jay
mohamed2040
PostPosted: Thu May 30, 2013 2:03 pm     Reply with quote
thank you for your fast answer Smile
but !
so i must use two other pins to make communication with LCD , the first PIN used to (internal ou external clock ?) and the second one to send data ? from pic to 74LS147 ? sorry i not understand :(
i have an other solution! to use MCP23016 ! on I2C Bus ! ?? with DS1307
but i havent MCP23016 driver :(
PostPosted: Thu May 30, 2013 2:22 pm     Reply with quote
There is a 23016 driver in the code library.
mohamed2040
PostPosted: Thu May 30, 2013 2:32 pm     Reply with quote
oops ! yep you right :( but I'm searching solutions :( to make communication PIC-LCD with only two wires cause i need more pin :( to connect other hardware
so this is the driver of MCP
#ifndef  MCP23016
#define  MCP23016
#define MCP_write 0B01000000
#define MCP_read  0B01000001
#define GP0     0x00
#define GP1     0x01
#define OLAT0   0x02
#define OLAT1   0x03
#define IPOL0   0x04    // INPUT POLARITY PORT REGISTER 0
#define IPOL1   0x05    // INPUT POLARITY PORT REGISTER 1
#define IODIR0  0x06    // I/O DIRECTION REGISTER 0
#define IODIR1  0x07    // I/O DIRECTION REGISTER 1
#define INTCAP0 0x08 // INTERRUPT CAPTURE REGISTER 0
#define INTCAP1 0x09 // INTERRUPT CAPTURE REGISTER 1
#define IOCON0  0x0A // I/O EXPANDER CONTROL REGISTER 0
#define IOCON1  0x0B // I/O EXPANDER CONTROL REGISTER 1
void InitMCP23016(int8 AddressSelect, int8 P0, int8 P1)
   i2c_start();
      delay_us(20);
   i2c_write(MCP_write | (AddressSelect << 1));
      delay_us(20);
   i2c_write(IODIR0);
      delay_us(20);
   i2c_write(P0);
      delay_us(20);
   i2c_write(P1);
      delay_us(20);
   i2c_stop();
      delay_us(20);
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(IOCON0);
      delay_us(20);
   i2c_write(0x01);
      delay_us(20);
   i2c_stop();
      delay_us(50);
void GetGPx(int8 AddressSelect, int8 *P0, int8 *P1)
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(GP0);
      delay_us(20);
   i2c_stop();
      delay_us(50);
   i2c_start();
      delay_us(20);
   i2c_write(MCP_read | (AddressSelect << 1));
      delay_us(20);
   *P0 = i2c_read();
      delay_us(20);
   *P1 = i2c_read(0);
      delay_us(20);
   i2c_stop();
      delay_us(50);
void SetGPx(int8 AddressSelect, int8 P0, int8 P1)
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(OLAT0);
      delay_us(20);
   i2c_write(P0);
      delay_us(20);
   i2c_write(P1);
      delay_us(20);
   i2c_stop();
      delay_us(50);
void GetINTGPx(int8 AddressSelect, int8 *P0, int8 *P1)
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(INTCAP0);
      delay_us(20);
   i2c_stop();
      delay_us(50);
   i2c_start();
      delay_us(20);
      delay_us(20);
   *P0 = i2c_read();
      delay_us(20);
   *P1 = i2c_read(0);
      delay_us(20);
   i2c_stop();
      delay_us(50);
void SetGPREG(int8 AddressSelect, int8 REG, int8 Data)
   i2c_start();
      delay_us(20);
      delay_us(20);
   i2c_write(REG);
      delay_us(20);
   i2c_write(Data);
      delay_us(20);
   i2c_stop();
      delay_us(50);
#endif
AND this is the schematic connection :
[img]
http://u7903.direct.atpic.com/37111/0/2395801/0.png
[/img]
lien : http://u7903.direct.atpic.com/37111/0/2395801/0.png
i wanna just know how can i use this code to communicate with PIC and to print just "HELLO"
PostPosted: Thu May 30, 2013 2:41 pm     Reply with quote
You are trying to do this in Proteus correct?
mohamed2040
PostPosted: Thu May 30, 2013 2:54 pm     Reply with quote
dyeatman, yes sure but can't make communication between MCP and PIC to write something on LCD.
But : I'm using DS1307 on I2C to put TIME on LCD
PostPosted: Thu May 30, 2013 3:01 pm     Reply with quote
Please read the PIC101 message at the top of the forum. We generally
dont assist with Proteus projects in this forum. You need to go to the Proteus
forum. Too many serious bugs in Proteus...
mohamed2040
PostPosted: Thu May 30, 2013 3:18 pm     Reply with quote
Proteus is not my problem now Smile
my problem is : how can i make communication with 3 devices :
The Pic 16F877 and MC23016 and LCD 16x2 to write "HELLO" on LCD Smile
so i don't say that i had a problem in Proteus Smile
PostPosted: Thu May 30, 2013 4:40 pm     Reply with quote
Proteus itself IS the problem... Proteus does not emulate many devices
well especially when you start looking at PICS communicating using I2C and
SPI. The pros on this site have been burned so many times they just
don't do Proteus....Proteus will not complain even when a number of serious
problems exist with your code and circuit, it just won't work. Many times
the code and circuit wil be OK but Proteus won't work properly.
PostPosted: Thu May 30, 2013 5:06 pm     Reply with quote
As I've used the '877 for a couple decades...please tell us WHY you can't wire the LCD to the PIC in 8bit mode?
According to your original post you have a DS1307 RTC that needs 2 pins, another I2C device( 2 more pins).
It is very easy to interface LCD module to PIC using an entire port(8 bits) for data and 2 more for control.
As others have said Proteus is NOT reliable! Full of bugs,errors, faulty DRCs! I've yet to see ANY Proteus schematic presented here (over 100 !) that would actually work in the real world.
Also, you should consider using the '887. More memory,more fuctionality, LESS cost !
hth
jay
mohamed2040
PostPosted: Sat Jun 01, 2013 6:46 am     Reply with quote
thank you all Smile
yessss Proteus >> Full of bugs with I2C
my problem was solved! Rolling Eyes
with Proteus frankly I have not found problems!
I used the PCF 8574
with this driver :
#use i2c(master, sda=PIN_C4, scl=PIN_C3)
#define PORT_BASE_ADDRESS 0x40
unsigned char read_from_port();
void write_to_port(unsigned char data_byte);
    unsigned char port_byte=0;
    i2c_start();
    i2c_write((PORT_BASE_ADDRESS + 1));
    port_byte=i2c_read(0);
    i2c_stop();
    return port_byte;
    i2c_start();
    i2c_write(PORT_BASE_ADDRESS);
    i2c_write(data_byte);
    i2c_stop();
mohamed2040
PostPosted: Sat Jun 01, 2013 6:51 am     Reply with quote
temtronic Embarassed
thank you sooo much bro
i use I2C PCF with 2 wires to write and read from LCD with an other DS1307 wasconnected on I2C cause i need more PIN :(
PostPosted: Sat Jun 01, 2013 7:32 am     Reply with quote
So now you're NOT using the 'Myke method', but using an I2C port chip.....
Actually a good option as it keeps you 'I2C' compatible, frees up 2 pins,and easy to understand.
Be adviced though not ONE proteus schematic presented here(100s have) will ever work in the real world....
cheers
Jay
mohamed2040
PostPosted: Sat Jun 01, 2013 4:24 pm     Reply with quote
yes that's sure ! but no problem ! to use two devices ! (DS1307 and PCF8574)
on I2C ! it will be working in real ! i'll buy PCF Devices and i'll try ! on test plate
temtronic Smile thank you again ! you are the best !
