Prefekt
| PIC 18F4550 USB on Windows 2008 Server |
Posted: Thu May 30, 2013 2:14 am |
I have tried to connect a PIC 18F4550 with USB to an Windows 2008 server. The system can't find the PIC!
On my Windows7 Pc, it's working fine. Any Ideas? There a special drivers?
I thougt Win7 and 2008 Server has the same kernel, driver and so on!
thanks
Volker |
Posted: Thu May 30, 2013 6:19 am |
Has run OK on W2008 server for me.
Possible things:
Some USB3 implementations give reverse compatibility problems. What chipset?.
Does anything happen?. Even without a driver, the device should be listed in device manager, with a ?.
Security is the most likely problem. On servers it is common to lockdown the machine so a 'user' can't install any hardware. Anything third party attached is a potential security breach. You can set the group policy settings to prevent drivers from being installed.
I'd suspect the last is the most likely. I set up server installs like this out of the box, so _only_ the administrator can add hardware.
Prefekt
Posted: Wed Jun 05, 2013 2:42 am |
Thanks for the answer.
The device is listed in the device manger as unknown Device '?'.
Do you have a link to the correct driver?
thanks Volker |
Posted: Wed Jun 05, 2013 2:56 am |
Comes with the compiler.
'Drivers' directory of the complier, 'NT,2000,XP,VISTA,7' subdirectory.
cdc_NTXPvista.inf
In device manager, select the device, say 'update driver', and point it at this file.
Prefekt
Posted: Thu Jun 06, 2013 10:49 am |
it seems to be a general problem...
I have the PIC in a PC desktop the USB is connected and the power is connected to a power supply output.
Sometimes the PIC will not be identified from windows after a boot.
The problem seem, that the power is coming up, before the USB on board is ready.
Any Idea what I can do? |
Posted: Thu Jun 06, 2013 11:24 am |
Shouldn't matter at all.
Provided the device is correctly using the connection sense pin, you can have it powered before or after the PC, and it'll connect fine. I have both devices that are switched on/off while the PC is running, and PC's that are switched on/off while the PIC is running, without problems.
If a device has it's own power, the USB 'spec', _requires_ that connection sense is used. It is (unfortunately) a common error, to not use this.
Prefekt
Posted: Tue Jun 11, 2013 10:38 am |
I have deinstall all USB driver from the pc and the plug the pic on. So I could install the new driver and I works now.
Thanks |
