| pont_mx
				| Modbus Master does not receive messages from slave |
				|  Posted: Fri May 24, 2013 9:06 am |   |
				| Hi everyone! I'm implementing a Modbus RTU communication in a PIC18f4520, actually I'm using modbus CCS library. When i send a messge, the slave receive it, and does its work, but when the slave respond to the master, the master is not able to receive the massage.(for any function the exception always is TIMEOUT=12)
 I didn't make any change on the library code
  	  | Code: |  	  | #include <main.h> #include "LCD.c"
 #define MODBUS_TIMER_USED                    MODBUS_TIMER_T1
 #define MODBUS_PROTOCOL                      MODBUS_PROTOCOL_SERIAL
 #define MODBUS_TYPE                          MODBUS_TYPE_MASTER
 #define MODBUS_SERIAL_ENABLE_PIN             PIN_C5
 #define MODBUS_SERIAL_RX_ENABLE              PIN_C4
 #define MODBUS_SERIAL_BAUD                   19200
 #define MODBUS_SERAIL_RX_BUFFER_SIZE         64
 #define MODBUS_TIMER_UPDATE                  MODBUS_TIMER_ISR
 #define MODBUS_SERIAL_INT_SOURCE             MODBUS_INT_RDA
 #include <modbus.c>
 #define MODBUS_SLAVE_ADDRESS                 0x64
 #use FAST_IO(D)
 #use FAST_IO(A)
 unsigned char flags = 0;
 unsigned long int Frec = 290;
 float FrecLCD;
 setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
 lcd_init();
 modbus_init();
 SET_TRIS_D(0x0F);
 // read regieter 8451
 if( ( (0x01&flags) == 0x00 ) && ( 0x01 == (0X01&INPUT_D()) ) )
 delay_ms(8);
 if((modbus_read_holding_registers(MODBUS_SLAVE_ADDRESS,8451,1)))
 FrecLCD = (float)Frec/10;
 printf(lcd_putc,"\fFrec: %2.1f \n", FrecLCD );
 FrecLCD = (float)*(&modbus_rx.data[2]);
 printf(lcd_putc,"%2.1f Hz Exep. %d", FrecLCD , modbus_rx.error);
 printf(lcd_putc,"\fExep. %d", modbus_rx.error);
 flags ^= 0x01;
 if( ( (0x01&flags) == 0x01 ) && ( 0x00 == (0X01&INPUT_D())))
 delay_ms(8);
 //lcd_putc("\f =)");
 flags ^= 0x01;
 I've been working on this for 3 days and i can't get it.
 in advance thank you very much fory your help.
