Jean FOUGERON
| TIMER 2 |
Posted: Fri May 24, 2013 2:17 am |
Hi friends
I often am upset with timer duration specs.
I need to do a FSK modem and begin with a prototype to test the principle.
I have Timer2 as carrier and Timer3 as modulation.
My project is to have Timer2 frequency ~= 100 kHz for a 1 value of Timer 3 and other (eg 120 or 80 kHz) for 0 value of Timer 3.
If I calculate correctly, when I want to transmit at 1200 Bdx, the bit duration is approx 830µs for Timer3.
So I need the carrier is much speeder, for example 10 (80µs) or 20 (40µs) times for Timer2 in order to have a quite correct "reaction time" and s/n ratio.
I want to setup timer 2.
And, there, the things become complicated.
setup_timer_2(T2_DIV_BY_1, period, postscale) works curiously
(my crystal is a 20MHz one, configured as HS).
(period, postscale)=(0x40,4) -> 52µs
(period, postscale)=(0x20,4) -> 26,4µs OK it is approx the half
(period, postscale)=(0x40,2) -> 26µs OK it is the half
But
(period, postscale)=(0x40,1) -> 19,6µs !
(period, postscale)=(0x20,2) -> 18,8µs !
(period, postscale)=(0x20,1) -> 18,8µs also !
(period, postscale)=(0x10,4) -> 21,4µs !
I understood that 0x20,4 == 0x40,2
or 0x40,8 (104µs) == 0x80,4 (104µs)
Am I wrong ?
I observe 0x10,4 != 0x20,2 != 0x40,1 |
Mike Walne
Posted: Fri May 24, 2013 3:59 am |
Why not throw a programmable divider at it, and save all the hassle?
Mike |
Jean FOUGERON
Posted: Fri May 24, 2013 7:51 am |
| Mike Walne wrote: | Why not throw a programmable divider at it, and save all the hassle?
Mike |
The emmision will be done with this method (modem like) and thru mains line and the reception will be done via a LM567 wich decodes the 100kHz carrier and output the data signal to a RX pin of a PIC18.
Don't you think it will work ? |
Mike Walne
Posted: Fri May 24, 2013 7:59 am |
You haven't told us the data rate.
Mike |
Joined: 01 Jul 2010 Posts: 9656 Location: Greensville,Ontario
Posted: Fri May 24, 2013 8:12 am |
Wow ! LM567 !! I haven't used them for 30 years ....
Low speed data rate <1200 baud, think X-10 style communications.
jay |
Jean FOUGERON
Posted: Fri May 24, 2013 8:17 am |
| temtronic wrote: | Wow ! LM567 !! I haven't used them for 30 years ....
jay |
Hé hé ...
Do you know a more modern solution ?
The data rate could be 1200Bdx, the usefull message is one byte long, so the transmitted message can be 2 or 3 bytes including a CRC.
The distance is approx 2 or 3 km |
Gabriel
Posted: Fri May 24, 2013 8:37 am |
I have a pile of LM567 left form a DTMF control proyect!
I am amazed you are using those too.... are they not extinct?
Sometime ago i was thinking of what kind of "hack" i could do to get similar functionality...
The only thing i came up with was to modulate signals at 38khz, and on the reciever end, feed them to a IR led and into a IR decoder....
... seemed like a Rube Goldberg machine, so i didnt test it.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
ezflyr
Posted: Fri May 24, 2013 8:43 am |
The MX-COM MX-614 FSK modem chip is popular with the 1200 baud Amateur packet radio crowd. It's a transceiver IC, and can be implemented with a minimum number of external components!
John |
Posted: Fri May 24, 2013 9:02 am |
Is this over existing power lines or can you run/use your own copper?
If own copper or leased lines from local telephone company it is super easy to do 3 kliks. I could get almost 20 miles on ONE solid copper wire( NO signal conditioning), using 24 baud( yes, 24 bits per second).hacker proof, lightning proof,rate ULC AA(think bank security systems).
Simple 16F877 master and up to 64 ,16F84 slaves..
hth
jay |
Posted: Fri May 24, 2013 10:05 am |
| Quote: | setup_timer_2(T2_DIV_BY_1, period, postscale) works curiously
But
This is most likely a problem caused by the interrupt overhead and
user code processing time. Post your #int_timer2 routine.
See these threads:
Maximum Timer ISR Speed -
http://www.ccsinfo.com/forum/viewtopic.php?t=43399
Timer 1 interrupt in high speed -
http://www.ccsinfo.com/forum/viewtopic.php?t=46522
External interrupt speed -
http://www.ccsinfo.com/forum/viewtopic.php?t=40169 |
Jean FOUGERON
Posted: Tue May 28, 2013 4:08 am |
| PCM programmer wrote: |
Post your #int_timer2 routine. |
| Code: | //génération des pulses flash et horloge---------------------------------------
#int_TIMER2 HIGH
void HF()
Output_toggle(PIN_B5);
This gives 26µs with 0x40,2
| Code: | #int_TIMER2 HIGH
void HF()
B_Interrupt2_seen=TRUE;
//--------------------------------------------------------------------------Main
while(true)
if(B_Interrupt2_seen)
B_Interrupt2_seen=FALSE;
Gives the same 26s
With 0x20,2 I have 40µs !! not 13, the half
With 0x80,2 I have a jitter betwen 51 and 52µs nearly the double, but instable.
Also with 0x40,4 |
Jean FOUGERON
Posted: Tue May 28, 2013 4:25 am |
| And with #FUSE H4 instead of #FUSE HS I have 9,4µs which is not in correlation any more, is it ? |
Posted: Tue May 28, 2013 5:08 am |
| Jean FOUGERON wrote: | | And with #FUSE H4 instead of #FUSE HS I have 9,4µs which is not in correlation any more, is it ? |
| Quote: | | my crystal is a 20MHz one, configured as HS | You didn't specify which PIC18 you are using, but I don't think there is one that can run at 4 * 20MHz = 80MHz.
For most PICs the maximum frequency you can get is a 10MHz crystal at H4 = 40MHz. |
Jean FOUGERON
Posted: Tue May 28, 2013 6:35 am |
| ckielstra wrote: | | You didn't specify which PIC18 you are using |
PIC 18F1220
But I observe a difference between HS and H4 with the same crystal 20MHz |
Posted: Tue May 28, 2013 7:32 am |
You would.
Either the chip will try to run at 80MHz, and lots of parts won't work, or the PLL will lock onto an undertone of the crystal, and you could be running at almost any frequency....
Taking things wildly out of spec is a very reliable way of ensuring they don't work. |
