jcal54321
| How to direct fprintf() output to MPLAB Output Window? |
Posted: Sun May 19, 2013 10:50 am |
Hi Everyone,
I was wondering if it is possible to direct the printf() or fprintf() output to the MPLAB Output WIndow. I found the topic dealing with this using MPLAB Sim. This worked fine. However, I would like to try this using data sent from the PIC MCU via the PICKit3 programmer. Here is my setup:
CCS ver. PCH 3.249
MPLAB IDE ver. 8.89
Programmer: PICKit 3
...and here is my code
#include <18F2420.h>
#include <stdlib.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT
#use delay(clock=4915000)
#use rs232(baud=9600, xmit=PIN_C6, bits=8, rcv=PIN_C7, parity=N, bits=8)
void main() {
//fprintf(stderr,"Hello World\n"); // this works with MPLAB Sim
printf("Hello World\n"); //...so does this
while(1) ;
Thanks in advance for your help. By the way, in case anyone is wondering, I don't happen to have a RS-232 cable at the moment so I am trying this as a temporary solution. |
gpsmikey
Posted: Sun May 19, 2013 7:48 pm |
I don't have a pickit 3, however, the pickit2 (which is what I have) has a "uart tool" mode - the 3 may have the same thing (or you may have a 2 also around). I have used that in debugging many times and it works fairly well. That allows you to have a connection to the PC from your board via the pickit - you just declare a stream then use fprintf to talk to it - here are a couple of key lines from my little test program I was using to simulate a fuel gauge sender:
| Code: | #use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B6, ERRORS, PARITY=N, \
BITS=8, STREAM=MIKEYMON)
// Gas Tank Sender simulator using PWM - M. Fields 12-July-2011
// uses the Microchip PICKit 2 18 pin demo board with a 16F1827 processor
// installed. ( DM164120-4 )
void disp_pct(int duty, int cycle) // display duty cycle percentage
pct = ((int16) duty * 100) / cycle ;
fprintf(MIKEYMON,"Duty Cycle = %u%% (%u/%u)\r\n",pct, duty, width); |
Hopefully that will help :-) _________________ mikey
jcal54321
Posted: Tue May 21, 2013 10:44 pm |
Hi GPSMikey,
Thanks for your reply. I tried as you have suggested, but it did not work. Also the PICKit3 documentation has no mention of the UART Tool that you have with the PICKit2. It is too bad. I think it would have been a nice feature to have been maintained in the PICKit3. It certainly would have been helpful troubleshooting any serial port issues.
Thanks again for your reply. Best regards. |
gpsmikey
Posted: Tue May 21, 2013 11:24 pm |
Too bad they didn't put that feature in the Pickit3 - quite a while back, I had looked into getting the 3, but it was still early in development. Unfortunately, it seems to have been frozen in the "early in development" stage. The uart tool was a handy feature for debugging.
mikey _________________ mikey
