PGC and PGD as UART PROBLEM
pingice
PostPosted: Fri May 17, 2013 8:59 pm     Reply with quote
hi,
i misused the pins of PGC and PGD instead of usual tx rx pins for uart of my circuit to transmit the sms through gsm. It is found that the msg not constantly can be sent.. meaning that the msg can be send bt sometime not, it's very unstable. can actually other pins act exactly same as the hardware uart pins? because i just discovered this mistaken and i am lack of time of changing it.. thx..
PostPosted: Fri May 17, 2013 11:59 pm     Reply with quote
A transmitting software UART, will give erratic timings, if any interrupts occur during the transmission. If you use the option 'DISABLE_INTS' in #use rs232, interrupts will be turned off for each byte, to prevent problems from this, but with it comes the 'cost' that servicing of other interrupts will be delayed by up to one character time.
pingice
PostPosted: Sat May 18, 2013 8:14 am     Reply with quote
ok.. i will try to work on it.. thx so much.. Smile another question is, why when i use 18f44k22 with 20MHz oscillator, the speed of the pic is extremely slow.. I eliminate this problem by changing the coding part to
 #Use delay (clock = 1000000)
but i am not sure whether this will cause any problem to the PIC
PostPosted: Sat May 18, 2013 9:43 am     Reply with quote
The UART won't work, unless the clock rate declared in the clock statement matches what your chip is actually clocking at. I'd have a strong suspicion that your 20MHz oscillator is not setup right, and is not working. The chip 'falls back' to running the internal oscillator at 1MHz (unless you turn off the FSCM fuse). You have an oscillator problem. Either wrong fuse or wrong connection.....
