Problem with lcd and 18f2550
fr3nsis
PostPosted: Mon May 13, 2013 10:30 am     Reply with quote
I'm going to crazy! Please help me guys!
I have an 1602 lcd connected to 18f2550 pic with this pinout:
pic is connect to 20mhz crystal
test di fr3nsis, su Flickr
gnd
5v
vo to 10k trimmer
rs to Ra5
r/w to gnd
e to Ra4 (that have 10k pull up resistor)
db0-1-2-3 to gnd
db4 to ra3
db5 to ra2
db6 to ra1
db7 to ra0
Without lcd code board work fine, with it stop to work.
I try also to connect e and rs ro portb but no luck.
This is my code using flex_lcd.c:
setup_timer_1 ( T1_DISABLED );
setup_vref(FALSE);
SETUP_SPI(SPI_DISABLED);
SETUP_ADC(ADC_OFF);
SETUP_ADC_PORTS(NO_ANALOGS);
setup_ccp1 (CCP_OFF);
setup_ccp2 (CCP_OFF);
lcd_putc("\fCREDITI  INSUFF.");
     output_high(PIN_C1);
     delay_ms(2000);
     output_low(PIN_C1);
      delay_ms(2000);
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver.  Change these
// pins to fit your own board.
#define LCD_DB4   PIN_a3
#define LCD_DB5   PIN_a2
#define LCD_DB6   PIN_a1
#define LCD_DB7   PIN_a0
#define LCD_E     PIN_a4
#define LCD_RS    PIN_a5
#define LCD_RW    PIN_A2
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW   1
#include <18LF2550.h>
#device adc=16
#fuses HSPLL,NOMCLR,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOPBADEN
#use delay(crystal=48000000)
PostPosted: Mon May 13, 2013 10:51 am     Reply with quote
Have you read what this says?....
//#define USE_LCD_RW   1
Note the change.
fr3nsis
PostPosted: Mon May 13, 2013 11:08 am     Reply with quote
Rw is connected to ground so must be
or i'm wrong?
PostPosted: Mon May 13, 2013 11:17 am     Reply with quote
You are wrong. Read what it says...
You must _comment out the following line_.
Unless the line is commented out, the code tries to use R/W, and since it is not connected, it'll wait forever.
gpsmikey
PostPosted: Mon May 13, 2013 11:21 am     Reply with quote
Note that the LCD's are funny creatures and you may need to play with the "init" a bit. Usually, you need a delay before init (after coming out of reset) then you need a delay after init before you can send data to it or it simply ignores you. Check the spec sheet for your display for the delay times (I have also found that sometimes the needed delay is even longer than specified for surplus parts).
mikey
mikey
fr3nsis
PostPosted: Mon May 13, 2013 12:35 pm     Reply with quote
Connecting e and rs to portb led blinks but no char on lcd.
Connecting e and rs to porta like before led wont blink.
I don't understand why...
I have also added 5 seconds before and after lcd_init.
Confused
PostPosted: Mon May 13, 2013 2:39 pm     Reply with quote
hmmm...LCD db0...3 are grounded ?(in original post).
I've always just let them 'float'(ie: no connection).
I know the flex_lcd driver works.....
...squares on LCD is a good sign..
Maybe post your current version of program, maybe 'something' got edited by mistake.
hth
jay
PostPosted: Mon May 13, 2013 2:49 pm     Reply with quote
You are not disabling Timer0, so RA4 will be the timer0 clock input (this is the default on power on). You don't need a pull up on RA4, on this chip the pin can pull up as well as down.
The clock statement should really say _clock=48000000_, not crystal. Your crystal is (hopefully) 20Mhz.
Are you sure you have got the DB4 to DB7 lines reversed as you show?.
Where did you get the define 'SPI_DISABLED' from?. It is not a standard one for the compiler. The normal syntax is:
setup_spi(FALSE);
If you have re-labelled the SPI_SS_DISABLED define, this turns the SPI _on_.....
fr3nsis
PostPosted: Tue May 14, 2013 1:12 am     Reply with quote
setup_spi(FALSE);
thank so much
test ok di fr3nsis, su Flickr
Very Happy
david_bur_91
I have got the same problem
PostPosted: Tue Jun 25, 2013 2:11 am     Reply with quote
here is my code:
#include <18F2550.h>
#device adc=10
#FUSES NOWDT,HS,NOPROTECT,NOBROWNOUT,PUT,NOCPD,STVREN,NODEBUG,NOLVP
#FUSES NOWRT,NOWRTD,IESO,FCMEN,PBADEN,NOWRTC,NOWRTB,NOEBTR,NOEBTRB,NOCPB,MCLR
#USE delay(clock=20000000)
#USE rtos(timer=0,minor_cycle=1ms)
#USE fast_io(b)
#INCLUDE <flex_lcd.c>
#INCLUDE <string.h>
   setup_spi(FALSE);
   setup_adc_ports(AN0|VSS_VDD);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_vref(FALSE);
   delay_ms(10000);
   set_tris_b(0xF0);
   delay_ms(10000);
david_bur_91
solution
PostPosted: Tue Jun 25, 2013 3:14 am     Reply with quote
I have just found the solution.
I had conect lcd to pins RC4 and RC5.
I read in another post that can“t be used as outputs or something like that, so I tried to change them to ports RC0 and RC1 and now works ok!!
delays before and after init of LCD was not the problem, it works correctly with a delay of 100 ms.
hope your answer.
