pushbutton 16F88
Goto page 1, 2  Next
will
pushbutton 16F88
PostPosted: Tue Apr 16, 2013 4:01 am     Reply with quote
hello
I made a program, when I did nothing a blinking LED orange
and when I press a push button LED lights and the orange light stops flashing (like a traffic light).
But I want that when I press the button pusher, the led orange remains stationary for a few seconds before starting ammuge other 4 led
You have an solution?
#include <16F88.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP
#use standard_io (B)
#define pushbouton   PIN_B0
#define led_rouge     PIN_B1
#define led_orange   PIN_B2
#define led_vert       PIN_B3
#define led_BLUE     PIN_B4
int8 count;
#int_TIMER1
TIMER1_isr()
//clignotant
output_high(PIN_B2);
        for (count=0;count<100;count++) {
         if (input(PIN_B0))  break;
          delay_ms(10); }
output_low(PIN_B2);
         delay_ms(10); }
//RED
output_high(PIN_B1);
          if (!input(PIN_B0))  break;
          delay_ms(20); }
output_low(PIN_B1);
//GREEN
output_high(PIN_B3);
          delay_ms(50); }
output_low(PIN_B3);
//ORANGE
          delay_ms(20); }
output_low(PIN_B2);
//BLUE
output_high(PIN_B4);
          delay_ms(20); }
output_low(PIN_B4);
PostPosted: Tue Apr 16, 2013 6:42 am     Reply with quote
This is a classic example for where the state machine programming model can be used.
http://en.wikipedia.org/wiki/Finite-state_machine
First you create a drawing of all the different states the program can be in, a State Diagram. Then you draw arrows between the states for all events that can cause a state change. Documenting your program like this will create a better understanding, but also helps you a lot to create the program because this is a skeleton to use as a base for further implementation.
Implementation often consists of an endless while-loop with a large switch-case statement. Each case statement equals one state in your State Diagram. In the while-loop you wait for events to happen, for example a button-press or timer tick. On detecting a new event you call the switch-case where the state-logic can do its thing, for example set the conditions for going to the next stage.
Here an example of the basic concept is shown: http://www.ccsinfo.com/forum/viewtopic.php?p=44373
And a thread explaining the use of function pointers versus the nested-switch state machine: http://www.ccsinfo.com/forum/viewtopic.php?t=28656
will
PostPosted: Tue Apr 16, 2013 7:44 am     Reply with quote
thank you very much, I look at a ca
but there is not no way to turn on an LED that one time? a function that could do that?
when I do nothing the orange LED blinks then I press the pushbutton should be the orange LED remains stationary for a few seconds. And only after I turn the other led successively.
will
PostPosted: Sat Apr 20, 2013 4:35 am     Reply with quote
there would be no way to make a statement that will execute a single time?
good day
Mike Walne
PostPosted: Sun Apr 21, 2013 2:32 pm     Reply with quote
I simply don't understand EXACTLY what you are trying to do.
Please supply a clear diagram.
Mike
will
PostPosted: Wed May 01, 2013 11:04 am     Reply with quote
When I do nothing I have orange LED that blinks
  I want that when I press a pushbutton.
A blue LED stays on for a few seconds and then I have other LED that lights up without going through the blue LED
So I resume:
- LED blinks orange (boussoir the button is released)
- When the button is pressed: - orange LED goes out cligotante
                                            - Blue LED illuminates for a few seconds.
                                            - And other LED lights one after the other in a loop without going through the blue LED.
So I want to make a statement that executes only once (which will light the blue led only once)
thank you to you
Mike Walne
PostPosted: Wed May 01, 2013 1:53 pm     Reply with quote
What you've written here is the bones of your code.
Part translated to 'C' it looks like this:-
  while (button_not_pressed)
    flash_orange_LED;
  turn_orange_LED_off;
  turn_blue_LED_on;
  delay_few_seconds;
  turn_blue_LED_off
    light_other_LEDs_in_turn;
You now simply write the code for each of the sub-functions.
Use the delay_ms(xx) function to start with, then progress to a timer if needed.
eg. replace delay_few_seconds with delay_ms(few000)
Mike
will
PostPosted: Sun May 12, 2013 7:06 am     Reply with quote
Hello thank you for your reply,
I did like you.
  But the problem is if the final stage (when all the LEDs are lit) if I release the button, it does not fall flashing (all the LEDs remain fixed) ..
You have a solution?
a big thank you
PostPosted: Sun May 12, 2013 7:33 am     Reply with quote
Will
you'll have to show us your code before we can help as there are hundreds of ways to do this !
hth
jay
will
PostPosted: Sun May 12, 2013 7:55 am     Reply with quote
I put my code,
when I release the button lA LED remains fixed, it is not good.
The orange light should normally flashes when the button is released
thank you
//  b0 =  push button
// FLASH LED ORANGE ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
while(!input(PIN_B0))
          delay_ms(10);
output_low(PIN_B2);
         delay_ms(10);    }
//LED ORANGE FIXED
output_low(PIN_B2);
//LIGHTING THE OTHER LED successively
//ROUGE
output_high(PIN_B1); output_HIGH(PIN_B5);
          delay_ms(20); }
output_low(PIN_B1); output_low(PIN_B5);
//VERT
output_high(PIN_B3); output_HIGH(PIN_B5);
          delay_ms(50); }
output_low(PIN_B3); output_low(PIN_B5);
Mike Walne
PostPosted: Sun May 12, 2013 4:37 pm     Reply with quote
Several things.
1) The system's doing what you are telling it to do.
2) Sensible indenting would make your program flow clearer.
3) With better indenting you should be able to see the fault for yourself.
4) Each closing } needs to be immediately below its opening { with white space between.
5) Why have you got the !input(PIN_B0) test?
6) Try playing at being a computer and follow the process step by step.
7) Your code is not complete and compilable, so we can't copy and paste to test for ourselves.
Mike
PostPosted: Sun May 12, 2013 5:27 pm     Reply with quote
also..
as this is a 'simple' program, get rid of the use of interrupts.
not really needed for a 'pushbutton-LED action/reaction' program.
as Mike says, it's not a complete program, so you could have errors elsewhere
hth
jay
Mike Walne
PostPosted: Mon May 13, 2013 9:41 am     Reply with quote
Your logic is flawed.
a) What happens if you press button B0 again, after it's released?
b) What happens if you remove the two lines which test for !input(PIN_B0)?
c) Do these two things tell you anything?
I've changed the layout of your partial code to show what I mean by indenting.
I've not changed the code at all, just the formatting.
Mike
PS Re-formatted code
//  b0 =  push button
         delay_ms(10);
      output_low(PIN_B2);
         delay_ms(10);
   //LED ORANGE FIXED
   output_low(PIN_B2);
      //ROUGE
         delay_ms(20);
      //VERT
         delay_ms(50);
will
PostPosted: Thu May 23, 2013 11:04 am     Reply with quote
Hello
here I tried again but I do not.
I will put my complete code (without passing through the solid orange)
I summarize: when nothing is going on, the LED blinks orange.
  Then, when I hold the button down, the LED stops flashing and the password fixed for 2 seconds.
Then the traffic light starts.
a big thank you
#include <16F88.h>                              // Inclusion du Header correspondant au µC utilisé
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP            // Paramétrage des fusibles du microcontrôleur
#define PUSHBUTTON   PIN_B0
int8 count;
#int_TIMER1
TIMER1_isr()
// ORANGE blinks when push button is released
         delay_ms(10);
      output_low(PIN_B2);
         delay_ms(10);
// ORANGE fixed two seconds (just after the button be pressed)??????????????????????????????????????????
//FIRE tricolor starts, just after the extinction of solid orange 2seconde
//Red
          delay_ms(30);
output_low(PIN_B1);
//green
          delay_ms(60);
output_low(PIN_B3);
//orange
          delay_ms(30);
output_low(PIN_B2);
//red
          delay_ms(50);
output_low(PIN_B1);
Mike Walne
PostPosted: Thu May 23, 2013 2:52 pm     Reply with quote
Several things:-
1) Does your code do what you want it to do?
2) The interrupt routine does nothing, so it's better removed totally.
3) Your code is now almost impossible to follow.
4) The indentation is awful.
If your code does not do what you want then explain clearly:-
a) What the code does do.
b) What you want it to do.
Mike
Goto page 1, 2  Next
Page 1 of 2
