filjoa
| program crash |
Posted: Wed May 01, 2013 12:12 pm |
Hi
I try read from GPS module and write on windows terminal with PIC18F458 @ 20Mhz but program crash after read +-9 strings.
#include <18F458.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,BROWNOUT,STVREN
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, stream=gpsport)
#use rs232(baud=9600,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8, stream=outport)
#include<string.h>
#include<stdlib.h>
int1 data_available=FALSE;
char c;
void rda_isr();
#int_rda
void rda_isr(void)
c = getc(gpsport);
data_available=TRUE;
fputc(c,outport);
enable_interrupts(INT_RDA);
Any idea where stay the problem?
best regards |
ezflyr
Posted: Wed May 01, 2013 12:15 pm |
Modify your #use rs232 line as shown below.
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, stream=gpsport, Errors)
BTW, your program is probably not 'crashing' in the traditional sense. Rather,
the UART is becoming over-run, and is locking up, preventing other
characters from being received. The addition of 'Errors' to the #use rs232 line
will allow the UART to recover in the event of an over-run.
It's not a good idea to be putting something like your putc inside the serial
ISR. You should be reading characters into a buffer, and then printing them
out in your Main() routine. Looke at the example program ex_sisr.c to see
how this is done!
John |
filjoa
Posted: Wed May 01, 2013 4:56 pm |
Hi
thanks ezflyr
Problem solved, with "ERRORS" add, it make UART reset...
I know this is not correct, but is the 1st test, to start the program.
best regards |
