Interrupt stop when multimeter on pin
huhu
PostPosted: Tue Apr 30, 2013 11:59 am     Reply with quote
Hi all!
I want to receive an irda signal, and put out to 2 output pin (16F628).
The LED pin flashing correctly when data comes , but when I measure with a multimeter(1Mohm res) on the PIN_A1, the LED stop flashing.
PIN_A1 not changed.
(I try with 10kohm pull up resistor too in PIN_A1)
(I try another pin too)
Why?
I copy a code from here: http://www.ccsinfo.com/forum/viewtopic.php?t=44113
I use 16F628 and 16f688 pic, but the same.
#include <16F628.h>
#FUSES INTRC_IO                          //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#define LED PIN_B4
#define DELAY 1000
#use FIXED_IO(A_outputs=PIN_A1)
int1 a[58]={}; //array for storing the complete stream
int flag=0,state,i;
#int_TIMER0
void timer0_interrupt(void)
  set_timer0(65258);//value of T i-e 444 us
  if(!input(PIN_A2))
    a[state]=0;//store 0 in array
    state++;   //increament the postion
    output_high(LED);
  else if(input(PIN_A2))
    a[state]=1;//store 1 in array
    output_low(LED);
    output_low(PIN_A1);
  if(state>=58)//if stream is complete then disable the timer 0
    state=0;
    flag=1;
#int_EXT
void isr_ext(void)
  flag=0;
  set_timer0(65397);//value of 1/2T i-e 222 us
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1|RTCC_8_bit);
  ext_int_edge(2,H_TO_L);//when interrupt goes high to low (falling edge)
  enable_interrupts(INT_EXT);//enable int2
  enable_interrupts(Global); //enable global interrupts
   while(true)
    if(flag==1)
      disable_interrupts(INT_TIMER0);
      for(i=0;i<58;i++)
      flag=2;
Confused
10kohm pull up on MCLR, 100nF and 100uF between VDD, Vss. On solderless breadboard.
PostPosted: Tue Apr 30, 2013 1:22 pm     Reply with quote
set_timer0(65397);
set_timer0(65258);
Timer0 is an 8-bit timer in the 16F628. The maximum count it can hold is 255.
ext_int_edge(2, H_TO_L);
16F628 only has one external input pin (not 3). Therefore, the parameter
of "2" does nothing.
It could be a static electricity issue. Put one hand on a good earth ground
(for example, a screw on the back of your PC), and then use the other
hand to hold the multimeter.
huhu
PostPosted: Wed May 01, 2013 7:25 am     Reply with quote
Thank you PCM programmer for the corrections.
It may be an electrical noise, this is the very first time that I use solderless breadboard.
Idea
Mike Walne
PostPosted: Wed May 01, 2013 11:35 am     Reply with quote
I hope you've remembered to fit HF decoupling caps as close as possible to the power supply pins on the PIC.
Mike
huhu
PostPosted: Sat May 04, 2013 2:59 am     Reply with quote
Yes, i did.
I found lot of complaints that the solderless breadboard is so noisy.
Thanks for replies.
Mike Walne
PostPosted: Sat May 04, 2013 3:09 am     Reply with quote
I've used them for donkey's years.
I think they're brilliant up to low MHz.
You have to be careful with layout, shielding is difficult, but can be done.
Use very short leads, neat wiring, plenty of decoupling.
Mike
PostPosted: Sat May 04, 2013 3:32 am     Reply with quote
Ignoring the breadboard, a multimeter lead can always cause problems. This is like attaching a three foot or so aerial to a pin. Depending on what else is radiating signals nearby, with the diode structures in the PIC input, this can effectively form a radio receiver.....
Mike Walne
PostPosted: Sat May 04, 2013 4:43 am     Reply with quote
You can mitigate the aerial effect with a resistor (100R to 10k).
Connect one end close to the pin under test, and the other to the meter lead.
Mike
