uart reception issue on PIC16LF88
backb0ne86
PostPosted: Sun Apr 28, 2013 10:09 am     Reply with quote
Hello Guys,
I m having trouble using the PIC16LF88.
Sending is working perfectly fine.
Reception is working only using SW UART (let me think that my board is good). However i want to use the HW uart to use the RDA interrupt.
Reception does not work (kbhit or interrupt).
My compiler is version 4.068.
I have read many think about UART problem, but i did not find the good tips to fix my problem.
Thanks in advance for your help Smile
Here is my code:
#include <16F88.h>
#device adc=8
#FUSES INTRC_IO
#FUSES NOBROWNOUT
#use delay(clock=8000000)
#use standard_io(A)
#use rs232(baud=1200, xmit=PIN_B5, rcv=PIN_B2, STREAM=XBEE, ERRORS)//, FORCE_SW)//, DISABLE_INTS)
char receivedChar;
char receivedCharOld;
#INT_RDA
void rda_isr()
 receivedChar =fgetc(XBEE);
 fputc(receivedChar,XBEE);
   int test;
   int c;
   char RCSTAValude;
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_timer_2(T2_DIV_BY_1,0,1);
   setup_vref(FALSE);
   setup_oscillator(OSC_8MHZ|OSC_TIMER1);
   setup_counters(RTCC_INTERNAL,RTCC_8_BIT|RTCC_DIV_256); // 50hz with preload
   set_tris_a(0b00000000);
   set_tris_b(0b00000000);
   setup_timer_2(T2_DIV_BY_1, 125, 1);
   delay_ms(2000);
   test=0;
   fprintf(XBEE,"Ready");
   enable_interrupts(INT_RDA);
   do
   int test;
   int c;
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_vref(FALSE);
   setup_vref(FALSE);
   delay_ms(2000);
   //setup_uart(1200, XBEE);
   do
      //if(kbhit(XBEE))
      //   receivedChar=fgetc(XBEE);
      if(receivedChar!=receivedCharOld)
         receivedCharOld=receivedChar;
//Processing
   }while(1);
PostPosted: Sun Apr 28, 2013 1:40 pm     Reply with quote
Start by posting a small compilable program.
What you have posted is half each of two separate programs, and hasn't got a hope of compiling, let alone working.
PostPosted: Sun Apr 28, 2013 2:53 pm     Reply with quote
Also, You are using Standard I/O so you don't need to set TRIS.
The below two lines are setting all the pins to outputs.
Get rid of these lines..
You also enabled Interrupts for Timer 2 with no interrupt handler defined.
Never enable interrupts without an Interrupt handler.
PostPosted: Sun Apr 28, 2013 9:56 pm     Reply with quote
Also your program has many unnecessary lines which turn off modules
which are already off when the PIC is reset. Normally adding all these
extra lines doesn't cause a problem, but in this case it does:
char RCSTAValude;
setup_adc(ADC_OFF);
setup_spi(FALSE);
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=29830
backb0ne86
PostPosted: Thu May 02, 2013 9:30 am     Reply with quote
Thanks PCM programmer. You are a genius!
I have also corrected my set_tris_b line which was wrong too.
Thanks again all for your usefull replies!
