Looking for CLOCKOUT fuse for 18F26K22
jgschmidt
PostPosted: Sat Apr 27, 2013 11:25 am     Reply with quote
Does anyone know the fuse setting to get the clock output on OSC2?
Usually this is CLOCKOUT or CLKOUT but neither works. Just something I like to use so I can verify proper clock setting with my O-Scope. The .h file and FUSES.TXT have not provided any clues.
Thanks.
Jürgen
www.jgscraft.com
jeremiah
PostPosted: Sat Apr 27, 2013 11:58 am     Reply with quote
Just scanning through the list of fuses provided by the compiler it would depend on your oscillator setup. You should look at the fuses used to select the oscillator. Some have an _IO at the end of the name, which is what turns off the clock out. You would need to use a FUSE that doesn't have the _IO. If you are using the internal RC for example, it would be INTRC (INTRC_IO makes the pin I/O rather than clock out).
If you have the IDE take a look at the Valid Fuses tool.
PostPosted: Sat Apr 27, 2013 12:03 pm     Reply with quote
the fuses do seem a bit inscrutable in CCS sometimes, as the spelling does not always match the data sheet
when i am faced with a problem like that -
and am in a HURRY ( which is usually )
i use my MEI PROGRAMMER to sort it out
(microEngineering Labs, Inc.)
the MEI ( micro engineering labs) , USB programmer has a wonderful drop down menu with VERY clear settings for ALL processor fuses.
decodes what the compiler inserted in the same language as the datasheet
and
best of all, it will let edit the HEX fuse line in the CCS hex source file to incorporate whatever fuses you want - interactively.
jgschmidt
PostPosted: Sat Apr 27, 2013 12:16 pm     Reply with quote
Thanks. I've gone through those, checked the fuse settings in the listing to see if I could reverse one, and still no joy. Here is my setup:
#include <18F26K22.h>
#FUSES INTRC         //Internal RC Osc, with output - doesn't work, CCS sets this back to INTRC_IO
#FUSES NOWDT         //No Watch Dog Timer
#FUSES NOPUT         //No Power Up Timer
#FUSES NOMCLR        //Engages weak pullup
#FUSES NOBROWNOUT    //No brownout reset
//#FUSES CLKOUT        //Check FOSC/4 on OSC2 - should be .125us - doesn't work
#use delay(internal=32M)
When I try INTRC, the compiler listing shows INTRC_IO so it appears CCS is overriding this for some reason.
PCWHD 4.135
Jürgen
www.jgscraft.com
PostPosted: Sat Apr 27, 2013 12:29 pm     Reply with quote
If your compiler version has a bug, the Config bits can be set manually.
See the posts near the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=48366
PostPosted: Sat Apr 27, 2013 12:30 pm     Reply with quote
YEP
CONFIG1H
BIT 0-3 set as
1001 = Internal oscillator block, CLKOUT function on OSC2
looks right - BUT how to get that set ??
not a fuse in the CCS list seems right for that bit of change.
you could try patching the HEX file - after compilation
jeremiah
PostPosted: Sat Apr 27, 2013 12:46 pm     Reply with quote
As an alternative, the manual suggests this example as a way to manually set fuses:
 #FUSES 1 = 0xC200 // sets config word 1 to 0xC200
Obviously change the number and the value to fit what you need. I haven't tested that to see how it works yet though.
PostPosted: Sat Apr 27, 2013 12:56 pm     Reply with quote
That's a neat little gem I never noticed after all these years of RTM!
gpsmikey
PostPosted: Sat Apr 27, 2013 1:33 pm     Reply with quote
Hey, cool - never noticed that before. Added a "flag" to my manual on that one (for others, it is in the #FUSES section - pg 105 or there abouts)
mikey
mikey
PostPosted: Sat Apr 27, 2013 2:03 pm     Reply with quote
In a simple flash the led program, where you do your normal fuses, as well as they can be done so far- calling for an INTernal oscillator with PLL off
and AFTER the normal #fuses statements
ADD
#FUSES 1 = 0x0900
what does it buy you ??
jgschmidt
PostPosted: Sat Apr 27, 2013 5:00 pm     Reply with quote
Thanks, guys. I always enjoy and learn from these discussions.
I tried the #FUSES 1=0xF900.
First, the compiler didn't like spaces around the "=" sign
Second, in the listing it still forced F800 as the first fuse. In fact the FUSES override seems to not work at all.
Fortunately, I can set the bits manually with my PicKit2 and it's only for testing so no big deal. Just something that makes me wonder what other surprises await.
I even checked the configuration editor. It has the correct entry and value for the INTRC option. It just doesn't come through when compiled.
That's why we double, and then redouble, our software development time estimates, right?
Cheers,
Jürgen
www.jgscraft.com
PostPosted: Sat Apr 27, 2013 5:12 pm     Reply with quote
thats why when in doubt - i rely on my programmer
to 'fixup' faulty fuses.
and not afraid to do that to a release version either - if thats what
it takes to push it across the finish line.
