Problem with 10F200
stoyanoff
Problem with 10F200
PostPosted: Sun Apr 21, 2013 6:46 am     Reply with quote
Hi, everyone! I have a problem with PIC10F200. The controller doesn`t output signals on it`s pins. Here is my code:
#include <10F200.h>
#FUSES NOWDT
#use delay(clock=4M)
   output_drive(PIN_B2);
      output_high(PIN_B2);
      output_low(PIN_B2);
And when I run this I have 1.6V on pin B2, but the Vcc is 4.4V(from PIC Kit 3)
Can you tell me what I`m doing wrong??
Thanks!
dyeatman
PostPosted: Sun Apr 21, 2013 6:58 am     Reply with quote
Look at the order of precedence on datasheet page 25 and you will see the pin is
used for multiple functions. I/O is the lowest order with TOCK1 and FOSC
being higher. This means those options must be disabled before the pin will
work for digital IO
Google and Forum Search are some of your best tools!!!!
stoyanoff
PostPosted: Sun Apr 21, 2013 10:15 am     Reply with quote
OK! I far as I understood I have to set OPTION_REG`s bit 5 to 1 and OSCCAL register`s bit 0 to 0.
In Special Function Registers I set OPTION_REG to 0xFF and OSCCAL to FE and again I have 1.6V on pin B2.
How do I have to set this values? Am I doing it wrong?
PostPosted: Sun Apr 21, 2013 11:16 am     Reply with quote
You almost never have to touch registers directly in CCS.
what does setup_timer_0(T0_INTERNAL);.... do?.
FOSC4 is disabled by default.
stoyanoff
PostPosted: Sun Apr 21, 2013 1:09 pm     Reply with quote
Sorry, but I can`t make it! This is my new program, but this time I have 0 volts on B2:
#include <10f200.h>
#Fuses NOWDT
PostPosted: Sun Apr 21, 2013 2:41 pm     Reply with quote
If you want pin GP2 (PIN_B2) to be an i/o pin, you need to clear the
T0CS bit in the OPTION register. See the example below:
#include <10F200.h>
#fuses NOWDT, NOMCLR
#define set_options(value)   {#ASM         \
                              MOVLW  value \
                              OPTION       \
                              #ENDASM}
set_options(0xDF);
PostPosted: Mon Apr 22, 2013 1:16 am     Reply with quote
The compiler does that for you, unless you have an old version.
0002:  MOVLW  DF
0003:  OPTION
First two lines of the generated assembler.
The poster hasn't said what compiler version they have. I'd suspect a rather old one....
stoyanoff
PostPosted: Wed Apr 24, 2013 10:30 am     Reply with quote
My CCS is v4.134. Here is my schematic: http://dox.bg/files/dw?a=7b11e5b117
Do I have a mistake in it?
stinky
PostPosted: Thu Apr 25, 2013 8:58 am     Reply with quote
Try adding a 0.1uf decoupling capp to the VDD line of the pic?
I've been bit in the butt by that causing odd behavior.
Also, my compiler version doesn't support this part so I cannot confirm, but does
produce the desired setting? Your schematic doesn't show an external crystal so I'd assume you want the internal r/c setting.
PostPosted: Thu Apr 25, 2013 9:14 am     Reply with quote
The 10F20x chips _only_ operate with the internal oscillator. To save pins. Quote from data sheet:
"The PIC10F200/202/204/206 devices are offered with
Internal Oscillator mode only."
Makes oscillator selection rather easy!....
No possibility of an external crystal.
Agree wholeheartedly on the capacitor. Strange behaviours of all sorts can result if there is not adequate decoupling. Also don't think 'bigger is better' here, and say 'got 470uF on the supply'. Needs to be a capacitor with good HF performance (most electrolytic's do not have good HF perfromance), close to the chip.
