tx433 & rx433
midoroi
tx433 & rx433
PostPosted: Tue Apr 09, 2013 10:43 am     Reply with quote
I have tried many code, and that doesn't work.
Confused
I really need a real help here (correcting the code).
Transmission
#include <16F876.h>
#fuses XT,NOWDT,PROTECT,NOBROWNOUT,PUT
#use delay(clock=10M)
int start;
int addr;
int data ;
int chksum;
set_tris_b(0x00);
set_tris_a(0xff);
start = 0x55 ;
addr = 0x8E;
data = 0x27;
chksum = (addr + data);
while(true)
if (input(pin_b1))
output_high(pin_a1);
putc(start);
delay_ms(20);
putc(addr);
delay_ms(20);
putc(data);
delay_ms(20);
putc(chksum);
delay_ms(20);
putc(0x66);
delay_ms(20);
putc(0x66);
delay_ms(20);
putc(0x66);
delay_ms(20);
putc(0x66);
delay_ms(20);
receiver code
#include <16F876.h>
char c;
int start;
int addr;
int data;
int chksum;
set_tris_b(0x03);
while(true)
if(kbhit())
start=getc();
delay_ms(20);
addr=getc();
data=getc();
delay_ms(20);
chksum=getc();
delay_ms(20);
if (start ==0x55)
         output_high(pin_b1);
               output_low(pin_b1);
  if (data ==0x27)
  output_high(pin_b2);
  output_low(pin_b2);
   if (addr ==0x8E)
  output_high(pin_b3);
  output_low(pin_b3);
  if (chksum ==(addr + data))
  output_high(pin_b4);
  output_low(pin_b4);
in isis this work perfectly
SherpaDoug
PostPosted: Tue Apr 09, 2013 11:05 am     Reply with quote
On the receiver get rid of the 2ms delays. Once the PIC reaches getc() it will wait until a character comes in. Beware it will wait forever if a character never comes in.
If your receiver 2ms is a little longer than the transmitter 2ms then the receiver will wait too long and getc() will miss the start of the next byte.
midoroi
PostPosted: Tue Apr 09, 2013 11:38 am     Reply with quote
i thinked to make if(kbhit()) to read all the bytes.on the place of delay_ms(20)
i means make 5 ==> if (kbhit())
ezflyr
PostPosted: Tue Apr 09, 2013 12:16 pm     Reply with quote
Why have you started a new thread on exactly the same topic? This is confusing, because people won't realize it, and a lot of information will need to be repeated. This is a sure way to annoy the forum members and get your thread locked!
Use your original thread here: http://www.ccsinfo.com/forum/viewtopic.php?t=50212
John
midoroi
PostPosted: Tue Apr 09, 2013 3:32 pm     Reply with quote
ezflyr wrote:
John
i opened new topic because it is new idea
midoroi
PostPosted: Tue Apr 16, 2013 12:47 pm     Reply with quote
help friends,
I need simple program for these components.
Mike Walne
PostPosted: Wed Apr 17, 2013 5:11 am     Reply with quote
You have not explained:-
1) What you are trying to do.
2) What result(s) you expect.
3) What result(s) you get.
4) What does/doesn't work.
5) What the problem is.
Start by posting the SHORTEST possible, complete, compilable code which shows the issue you've got.
Mike
PostPosted: Wed Apr 17, 2013 8:06 am     Reply with quote
Classic thing.
What is the maximum clock frequency supported by the XT fuse setting?.
Isis doesn't check such things at all, and the things it does check it often gets wrong. It is like repeatedly shooting yourself in the foot, to look at Isis as being 'helpful' with the PIC.....
