Generate code COF.
fiasgardone
Generate code COF.
PostPosted: Thu Apr 04, 2013 2:49 am     Reply with quote
Hi!!
My compiler(V-4.128) did not generate the code COF, anyone have any idea how to configure this file
thank you
PostPosted: Thu Apr 04, 2013 3:35 am     Reply with quote
Command line, or IDE?.
From the IDE, Options, Project Options, Output files. Left hand column 'Debug file' bottom option 'COFF'.
Command line '+DF' in the compiler calling line.
fiasgardone
PostPosted: Thu Apr 04, 2013 4:26 am     Reply with quote
Thanks again for your help Ttelmah.
In the IDE everything is fine!
In the command line, the compiler can not find!
PostPosted: Thu Apr 04, 2013 4:44 am     Reply with quote
CCSC +FH +DF +LN testfile.c
(assuming PCH, and a source file called 'testfile.c')
testfile, needs a full pathname if it is not in the CCSC directory.
fiasgardone
PostPosted: Fri Apr 05, 2013 1:47 am     Reply with quote
Hi! Ttelmah
I do not know what is the problem but the complilador, does not generate the code COFF.
when I compile the code, the message to say who created The HEX, COFF files, but the folder where the files should be created both the HEX and COFF and only appears HEX.
Where I have installed complilador CCSC,has the folder, but source file called 'testfile.c' I can not find it.
thanks for the help
PostPosted: Fri Apr 05, 2013 2:44 am     Reply with quote
Of course you can't. testfile.c , would be the source code you want to compile. So 'yoursourcefilename.c', as I say, with a full pathname.
