Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Multi servo controller.
Post new topic   Reply to topic    CCS Forum Index -> Code Library
btklister
PostPosted: Sat Apr 10, 2010 8:55 am     Reply with quote
This code reads UART values and generates 50hz pwm, 50 steps for drive servo motors, 6 servos in this case, but you can change as many as you want by adding extra lines.
How it works:
Every 50us an interrupt is generated, so when passed 400 interrupts 400*50us=20ms required for servo. So by adding some counters to interrupt to count the time passed, we can control when IO port is pulled to 0. When the counter reach 400 we do the same again, creating a pwm.
This controller is a uart slave to control it is require send 3 bytes to it:
0xsomething > to trigger the ready pin (pin_c3)
0xID > ID of servo (0x00 to 0x05 in this case)
0xPOS > position of servo (0x00 to 0x32, 50 steps)
#include <16F688.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES MCLR                     //Master Clear pin enabled
#FUSES PUT                      //Power Up Timer
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use rs232(baud=9600,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8)
int16 end=0;
int8 aux=0,c0=25,s0=25,c1=0,s1=25,c2=0,s2=25,c3=0,s3=25,c4=0,s4=25,c5=0,s5=25;
int8 code[3];
int1 flag=0;
void brain();
void clear();
void read();
void config();
void getcode();
#int_TIMER0             //Interrupt every 50us
void  TIMER0_isr(void)
   brain(); //turn of the IO in respective time
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
         if(kbhit())    //read uart if a char is arived
            getcode();
         read();
void clear()
   //will reset the pulse
   output_high(pin_c2);
   output_high(pin_c1);
   output_high(pin_c0);
   output_high(pin_a2);
   output_high(pin_a1);
   output_high(pin_a0);
   c0=0;c1=0;c2=0;c3=0;c4=0;c5=0;
   end=0;
void brain()
   if(c0==s0)
      output_low(pin_c2);
   if(c1==s1)
      output_low(pin_c1);
   if(c2==s2)
      output_low(pin_c0);
   if(c3==s3)
      output_low(pin_a2);
   if(c4==s4)
      output_low(pin_a1);
   if(c5==s5)
      output_low(pin_a0);
   if(end==400)    //400*50us = 20ms (wave periodo required for drive a servo)
      clear();
   c0++;
   c1++;
   c2++;
   c3++;
   c4++;
   c5++;
   end++;
void read()
      if(flag==1)
               switch (code[0])
                     case 0:
                     s0=code[1];
                     case 1:
                     s1=code[1];
                     case 2:
                     s2=code[1];
                     case 3:
                     s3=code[1];
                     case 4:
                     s4=code[1];
                     case 5:
                     s5=code[1];
                     default:
               flag=0;
void getcode()
   char c;
   c=getc();
   flag=0;
   switch (aux)
         case 0:     //active ready bit with any char received (trash)
         output_high(pin_c3);
         case 1:
         code[0]=c;  //store in array servo ID (0-5)
         output_low(pin_c3);
         case 2:
         if(c>=0 && c<=50)   //sote in array servo position
            code[1]=c;
         flag=1;
   aux++;
   if(flag==1)
      aux=0;
  //after the 3 char were received we have an array with trash+ID+POSITION
Cumpz
Fabio Rico
Ali_P
View user's profile Send private message ICQ Number
PostPosted: Thu Oct 20, 2011 4:43 am     Reply with quote
Greetings btklister,
Great code ! I wanted to control 4 servos since your program has 6 servo control. It shouldn't be a problem, but when I simulate your code and send command from tx, 2 servos work properly. But if I add command for the 3rd servo, only the 3rd works and the other two doesn't work. Could you explain why? Or what should I do to counter it?
Best Regards
Ali
John P
PostPosted: Fri Oct 28, 2011 6:29 am     Reply with quote
Even if this works, I don't think it's adequate. With a resolution of 50usec, given that a hobby servo has an "official" active range of 1msec, you only have 20 potential stopping positions. I wouldn't accept a driver that has such coarse control of the servo.
By "active range" I mean the time interval over which control is possible, i.e. 1msec < T < 2msec. Some servos will accept wider ranges for increased travel.
btklister
PostPosted: Sun Nov 13, 2011 6:31 am     Reply with quote
Usually simulators don't work properly with fast sitching pins, try to implement in a test board, it works for me.
mbradley
PostPosted: Mon Nov 14, 2011 10:50 pm     Reply with quote
I am not trying to take away from any ones glory, but here is code for a 32, 16, or 8 chanel servo controller, all tested, opensource, CCS compiled, board available, etc....
http://www.mculabs.com/projects/ssx32.html
Michael Bradley
www.mculabs.com
Open Drivers and Projects
hasimi20
PostPosted: Sun Mar 24, 2013 9:21 am     Reply with quote
It works for me! my Q is, how can I increase the servo positioning angle from 0 to 50, to 0 to 100 maybe?
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
