monsun
| Problem with pointers |
Posted: Thu Mar 21, 2013 2:11 am |
Sometimes i have problems with big arrays and pointers:
for example when i use it this way everything is allright:
float example(float *something_external)
int8 i;
float something;
for(i=0;i<10;i++)
something+=*something_external;
something_external++;
return something;
BUT when i use it this way sometimes it makes some problems
int8 i;
float something;
for(i=0;i<10;i++)
something+=*(something_external+i);
return something;
Any ideas? |
Posted: Thu Mar 21, 2013 2:20 am |
Incorrect syntax.....
You want.
something+=(*something_external)+i;
You are saying to add 'i' to the pointer, _then_ take the contents of this. Effectively treating it as an array, so
something+=something_external[i];
monsun
Posted: Thu Mar 21, 2013 2:44 am |
| Ive thought that something_external[i] is equal to *(something_external+i) using pointers?? |
Posted: Thu Mar 21, 2013 3:15 am |
OK. So you do want to use it as an array?.
Question then is compiler version and chip???.
If you want to use it as an array, then 'yes' this is right, _but only if you are on a modern compiler_. Historically the older compilers did not increment pointers correctly, treating their size as '1', whatever they pointed to.
There were also problems on particular chips when you crossed page boundaries.
