Olufola
Posted: Tue Jun 16, 2009 4:02 pm |
| I will go ahead with your advice. I think those codes are okay. I will do an extensive hardware troubleshooting now that the likelyhood of software errors is now largely ruled out. I will keep you informed about any progresses as soon as they are made. Thanks a lot. I may one day take on your role on this forum (That was a joke since experience does not come by boasting) |
Olufola
Posted: Sat Jun 20, 2009 1:56 am |
The impossible has become a possibility at last. I have a perfectly working sensor network implemented with I2C using the CCS C. All previous project managers could not do it. I will need to refer to PCM programmer when I am presenting the project but that is no name.
Thanks a thousand, a million ... infinitely to Mr PCM programmer but I cannot refer to you with that name when presenting the project.
The code that finally worked follows for any other person that might need it:
MASTER CODE
#include <18f4520.h>
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#define SLAVE1_WRT_ADDR 0x14
#define SLAVE1_READ_ADDR 0x15
#define SLAVE2_WRT_ADDR 0x28
#define SLAVE2_READ_ADDR 0x29
#define SLAVE3_WRT_ADDR 0x42
#define SLAVE3_READ_ADDR 0x43
int8 data1,data2,data3;
output_high(pin_d4);
delay_ms(60);
output_low(pin_d4);
i2c_start();
i2c_write(SLAVE1_READ_ADDR);
data1 = i2c_read(0);
i2c_stop();
delay_ms(10);
i2c_start();
i2c_write(SLAVE2_READ_ADDR);
data2 = i2c_read(0);
i2c_stop();
delay_ms(10);
i2c_start();
i2c_write(SLAVE3_READ_ADDR);
data3 = i2c_read(0);
i2c_stop();
printf(" [ %3U %3U %3U ] \r\n", data1,data2,data3);
output_high(pin_d6);
delay_ms(60);
output_low(pin_d6);
SLAVE1 CODE
#include <18F4520.h>
#device adc=8
#fuses HS,NOWDT,PUT,BROWNOUT,NOLVP
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x14)
int8 adc_result;
#INT_SSP
void ssp_interrupt()
int8 incoming, state;
state = i2c_isr_state();
if(state < 0x80) // Master is sending data
incoming = i2c_read();
if(state >= 0x80) // Master is requesting data from slave
i2c_write(14);
void main ()
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
adc_result = read_adc();
enable_interrupts(INT_SSP);
SLAVE2 CODE
#device adc=8
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x28)
int8 adc_result;
#INT_SSP
i2c_write(28);
void main ()
set_adc_channel(0);
delay_us(20);
SLAVE3 CODE
#device adc=8
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x42)
int8 adc_result;
#INT_SSP
i2c_write(42);
void main ()
set_adc_channel(0);
delay_us(20);
If you are using this code, then it will be okay if "PCM Programmer" which is no name but just an identifier be acknowledged. |
thedemri
Posted: Sat Aug 21, 2010 2:55 pm |
Olufola hi
I know it was long time ago but do you remember what was the problem with the 3 slaves?
because the code with and without the problems are pretty similar.
Thanks Amnon
JH1987
| Small Change to Your Example |
Posted: Tue Jan 25, 2011 2:10 pm |
| PCM programmer wrote: | Here is a simple i2c slave demo. The slave PIC reads the ADC value
every 500 ms and saves it in a global variable. This emulates a sensor.
The master PIC reads the ADC value from the slave. The master does
not send an internal address byte to the slave. It only sends the i2c
slave device address, and then it reads the data byte.
Also, notice that the master is not using FORCE_HW mode in the
#use i2c() statement. In some PICs, this can cause problems. It's best
to start by using a software i2c Master. When you get that working
reliably, then add the FORCE_HW to the master and try it.
I'm using the equivalent of 2.2K pullups on SDA and SCL. This was
tested on two PicDem2-Plus boards, with vs. 4.093 of the compiler.
Here is the output of the master PIC, as I slowly turn a trimpot that is
connected to the AN0 analog input pin. I turned the pot all the way to
the right, and then back to 0 again.
| Quote: |
read 00
read 30
read 8C
read F3
read FF
read FF
read D8
read 88
read 15
read 00
i2c Master:
| Code: | #include <16F877.H>
#define SLAVE1_WRT_ADDR 0x12
#define SLAVE1_READ_ADDR 0x13
int8 data;
i2c_start();
data = i2c_read(0);
i2c_stop();
printf("read %X \n\r", data);
i2c slave:
| Code: | #include <16F877.h>
#device adc=8
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x12)
int8 adc_result;
#INT_SSP
i2c_write(adc_result);
void main ()
set_adc_channel(0);
delay_us(20);
Edit #1: Fixed a typo
Edit #2: Changed the PROTECT fuse to NOPROTECT. There is no need
for code protection in a test program. |
Your example is good, as always, but its probably a good idea to do a read in the master that expects ACK, and to do a read in the slave isr for address 0x80, which will send the ACK. This seems more in line with actual I2C use, where its almost always true that the master expects to get an ACK after it sends the slave adr & Wr/Rd byte. |
Posted: Wed Jan 26, 2011 4:07 pm |
| Quote: | | and to do a read in the slave isr for address 0x80 |
No address of 0x80 is sent. The 0x80 (and other values) comes
from the CCS function i2c_isr_state(). It is described in the CCS manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf |
JH1987
| Sorry for miscommunication |
Posted: Wed Jan 26, 2011 10:12 pm |
| PCM programmer wrote: | | Quote: | | and to do a read in the slave isr for address 0x80 |
I know. I apologize for mistyping. I meant state 0x80, which corresponds to the master sending the slave a byte with the correct slave address & the R/W bit set.
What I meant was that doing an I2C read() when the state is 0x80 would cause the slave to send back an ACK to the master. I didn't realize that the slave PIC did this anyway, regardless of the argument you give I2C read(). In other words it seemed like the ISR was called when the PIC received an 8-bit data byte but before it returned ACK. In light of that it seems totally pointless for the CCS manual to do a read in their example ISR when the state is 0x80, because the ISR would not have been called without the correct slave address. That's why I assumed you had to do the read to load the ACK in the shift register. But then the slave PIC would have to do clock stretching automatically to buy time to load the register. Oh well, at least from these posts the details of the PIC I2C are very clear now. The manual was vague and unhelpful. Thanks for the info.
Here's the CCS example as an FYI to anybody reading this
#INT_SSP
void i2c_isr() {
if((state== 0 ) || (state== 0x80))
i@c_read();
if(state >= 0x80)
i2c_write(send_buffer[state - 0x80]);
else if(state > 0)
rcv_buffer[state - 1] = i2c_read();
khienpzo
Posted: Wed Nov 28, 2012 4:18 am |
Hi. I have a questions for you
if(state >= 0x80)
i2c_write(42);
before your code:
if(state >= 0x80)
the difference here ?
Can you explain?
thanks for answer the questions .. |
tienchuan
Posted: Mon Mar 11, 2013 9:37 pm |
| Quote: |
read 00
read 30
read 8C
read F3
read FF
read FF
read D8
read 88
read 15
read 00
i2c Master:
int8 data;
i2c_start();
data = i2c_read(0);
i2c_stop();
i2c slave:
#device adc=8
int8 adc_result;
#INT_SSP
void main ()
set_adc_channel(0);
delay_us(20);
Hi PCM programer
I try with your code in CCS C and Proteus to simulate, but it don't work as well as you tell. I saw master received one byte adc value from slave and it stop until restart.
Can you show me problems?
My PCH and PCM have a version 4.104.
thanks u so much. _________________ Begin Begin Begin !!! |
SherpaDoug
Posted: Mon Mar 11, 2013 9:49 pm |
Try having slave #1 send 1, 4, 7, 10 etc.
Slave #2 send 2, 5, 8, 11 etc.
Slave #3 send 3, 6, 9, 12 etc.
Then you will know who is sending and when they sent it. _________________ The search for better is endless. Instead simply find very good and get the job done. |
tienchuan
Posted: Mon Mar 11, 2013 10:15 pm |
| SherpaDoug wrote: | Try having slave #1 send 1, 4, 7, 10 etc.
Then you will know who is sending and when they sent it. |
Thanks SherpaDoug
I tested with your show but it's still error.
I'm still get only the first data, the next data is 0xFF?
Pls help me.
tienchuan,
Proteus is buggy for i2c slave. Read this:
PIC101 - No more Proteus questions
http://www.ccsinfo.com/forum/viewtopic.php?t=47549
- Forum Moderator
++++++++++++++++++++++++++ _________________ Begin Begin Begin !!! |
tienchuan
Posted: Tue Mar 12, 2013 12:48 am |
Thanks Mod
I'll test again on board.
Thanks. _________________ Begin Begin Begin !!! |
Posted: Tue Mar 12, 2013 1:42 am |
On _some_ PIC's, it is required to do the read in the 0x80 state.
On these the buffer full bit, does not reset unless this is done, and then the I2C will hang, because on the next received byte, the interrupt doesn't trigger.
This is one where lots of people run with a PIC where this doesn't happen, and other have chips where this is needed, and code that works happily on the former, won't work on the latter. It is also one where the Proteus emulation differs from real chips.....
mcr1981
| Thanks for this code. |
Posted: Mon Oct 12, 2015 7:06 am |
I was able to communicate a master with a slave.
Could not use hardware I²C on a 18F45K22 but did it with software routines (#use I2C).
Will post the address snapshot. It's something strange:
The protocol (if I've read correctly) will shift to the left the address one bit and does not looks like it.
The address is 0x10 for the slave and we are supposed to see 0x20 but the 0x10 is what I see.
The compiler version is 5.038.
Thanks for this code Mr PCM programmer.
Posted: Mon Oct 12, 2015 8:44 am |
CCS uses 8-bit format for the i2c slave address, in which the 7-bit address
is shifted left by 1 and combined with the R/W bit in the D0 position.
So a 7-bit address of 0x10 in the Philips (NXP) format, becomes 0x20 in
byte format. For more information, see this comment by Ttelmah:
http://www.ccsinfo.com/forum/viewtopic.php?t=45628&start=4 |
