10F320 Analog Pins on Power on Reset
stinky
PostPosted: Wed Mar 06, 2013 8:39 pm     Reply with quote
10F320
Version 4.141
I'm a little confused here and my [very] cursory search of the forum didn't find anything related.
Per the data sheet Section 10.1.2:
The ANSELA bits default to the Analog
mode after Reset. To use any pins as
digital general purpose or peripheral
inputs, the corresponding ANSEL bits
must be initialized to ‘0’ by user software.
I get that.
And my current project doesn't utilize anything analog. So CCS gives us the easy to use function of:
setup_adc_ports(NO_ANALOGS);
Only thing is that when I look at my .lst file of generated code I see that only a couple instructions after "main" it is writing 0 to the ANSELA register. I was attempting to save any precious words that I could so I removed my setup_adc_ports(NO_ANALOGS) line. Sure enough, it still says it is is writing 0 to ANSELA. To test if there was something else in my code that caused this I went ahead and made as small a program as I could get to compile.
#include <10F320.h>
#fuses INTRC, NOBROWNOUT, NOWDT, PUT, NOMCLR, NOPROTECT, NOLVP, NOLPBOR, NOWRT, NODEBUG
And the resulting .lst:
CCS PCM C Compiler, Version 4.141, 2020               06-Mar-13 20:13
               Filename:   C:\Users\Dan\Desktop\compile test\ansela_test.lst
               ROM used:   7 words (3%)
                           Largest free fragment is 249
               RAM used:   4 (6%) at main() level
                           4 (6%) worst case
               Stack:     0 locations
0000:  MOVLW  00
0001:  MOVWF  PCLATH
0002:  GOTO   main
0003:  NOP
.................... #include <10F320.h>
.................... //////// Standard Header file for the PIC10F320 device ////////////////
.................... #device PIC10F320
.................... #list
.................... #fuses INTRC, NOBROWNOUT, NOWDT, PUT, NOMCLR, NOPROTECT, NOLVP, NOLPBOR, NOWRT, NODEBUG
.................... void main(void)
0004:  MOVLW  00
0005:  MOVWF  ANSELA
0006:  SLEEP
Configuration Fuses:
   Word  1: 3C80   INTRC NOBROWNOUT NOWDT PUT NOMCLR NOPROTECT NOLVP NOLPBOR BORV19 NOWRT NODEBUG
I'm not complaining [now] because for my purpose, I don't want any analog pins and this is saving me two lines of code. But curiousity begs to know why it is that the ANSELA register is being written to? I didn't tell it to, and the behavior is not as the data sheet describes. Is this a bug in the compiler?
PostPosted: Wed Mar 06, 2013 9:43 pm     Reply with quote
The default behavior of the compiler is to initialize PortA to be all digital.
It's been that way for years.
stinky
PostPosted: Wed Mar 06, 2013 9:50 pm     Reply with quote
Thank You
stinky
PostPosted: Wed Mar 06, 2013 9:55 pm     Reply with quote
On second thought, is it possible to change this default behavior?
PostPosted: Wed Mar 06, 2013 10:36 pm     Reply with quote
I don't think there's an option to do that. It would be either a #device
or a #build option and I don't see one available.
