MinIMU-9 v2 from Pololu interfacing with PIC
rajm
PostPosted: Fri Feb 22, 2013 3:43 am     Reply with quote
I have written code to read only gyro values from the the sensor, but I'm not getting anything with this code. Can any one help in this problem ?
My datasheet is from: http://www.pololu.com/catalog/product/1268
my code is:
#include <18f4550.h>
//#include <L3G20.h>
#device ADC=10
#fuses HS,MCLR,NOWDT,NOPROTECT,NOLVP,USBDIV,PLL5,CPUDIV1,VREGEN
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,stream=Rec_Dat)
#use I2C(master,sda=PIN_B0, scl=PIN_B1)          /*Set I2C Settings */
#define LCD_ENABLE_PIN PIN_C2
#define LCD_RS_PIN PIN_C0
#define LCD_RW_PIN PIN_C1
#define DATA_PORT  PORTD
#include <lcd.c>
//long int  n,ch0;
unsigned int i,I2c_Data[10];
void WriteData(unsigned char address, unsigned char data)
i2c_start();
i2c_write(0x98);
i2c_write(address);
i2c_write(data);
i2c_stop();
set_tris_c(0xff);
  set_tris_d(0x00);
//i2c_start();
   //i2c_write(0x6B);
//WriteData(0x30,0xFF);
while(true)
lcd_gotoxy(1,1);
    lcd_putc(" acc:");
   i2c_start();                /* Read Mode */
      //i2c_write(0x99);
   //i2c_write(0x6B);
   for(i=0;i<7;i++)
      I2c_Data[i]=i2c_read(0x28);          /* Read Data */
   //I2c_Data[i]=i2c_read(0);
// lcd_gotoxy(2,2);
printf("\n\rX=%u",I2c_Data[0]);       /* Send X-axis value */
printf(" Y=%u",I2c_Data[1]);          /* Send Y-axis value */
printf(" Z=%u",I2c_Data[2]);          /* Send Z-axis value */
   i2c_stop();
//delay_ms(1000);
PostPosted: Fri Feb 22, 2013 5:28 am     Reply with quote
One 'glaring thing', before we look any deeper.
Try the fuse NOPBADEN.
The chip defaults to having the PORTB pins setup for ADC use. If you look at the datasheet, this overrides the peripherals on PORTB.
Come back if this doesn't work, and then we'll look at the code.
PostPosted: Fri Feb 22, 2013 6:25 am     Reply with quote
With ANY program using an I2C device, first download PCMprogrammer's I2C 'scanner' program located here or in the code forum.
Run it FIRST to confirm your hardware is OK BEFORE you cut your own code.
You'll save countless hours trying to debug.Right now it might be hardware or it might be software.
Running his program will QUICKLY confirm where you have to spend your time!
hth
jay
