arunb
| Drivers for sdhc memory cards |
Posted: Tue Feb 19, 2013 7:10 am |
hi,
I use the sdcard drivers in picc folder quite successfully for my projects. But nowadays sdhc cards are more popular than sdcards.
I find that the sdcard drivers do not work with the sdhc cards, CRC does not get turned off during initialisation.
I have searched this forum for a solution to the problem, some members have suggested that the initialisation routines for the cards are different, whereas others have suggested that the spi mode in the sdhc card is not supported.
Please advise whether this is the case, also how do I modify the sdcard drivers to support sdhc cards (or if this is a doable solution) ?
Can the problem be in the 5v to 3.3v translation? I use resistors dividers for output lines and a ttl buffer for input. This has worked with all the sdcards I have including microSD cards but not sdhc cards, also I have not used pullups in the output lines, I make these lines high on startup through the pic.
Could this be the issue ?
thanks
a |
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Tue Feb 19, 2013 9:19 am |
Several comments here.
There are a great many sdhc libraries around, mostly commercial. One of our forum regulars, asmallri (sp?), is one such vendor. I've not used them, but heard they're very good and worth the money.
Regarding SD vs SDHC, the difference is in how the cards are addressed. SD cards are addressed at the byte level. They use 32-bit addresses and so can only access 2^32 bytes = 4GB. SDHC cards are addressed using 32-bit block numbers, each block being 512 bytes. That means SDHC cards are limited to 2TB. The byte vs block addressing is a fundamental change that requires a complete rewrite of the driver.
Lastly, a 5V to 3.3V translation is always problematic. When I've had to interface to SD cards, I've always used a 3.3V design. _________________ Andrew |
asmallri
Joined: 12 Aug 2004 Posts: 1675 Location: Perth, Australia
| Re: Drivers for sdhc memory cards |
Posted: Wed Feb 20, 2013 10:51 am |
| Quote: | | One of our forum regulars, asmallri (sp?), is one such vendor. I've not used them, but heard they're very good and worth the money. |
I have it on good authority that his drivers are great :-)
| arunb wrote: | hi,
I have searched this forum for a solution to the problem, some members have suggested that the initialisation routines for the cards are different, whereas others have suggested that the spi mode in the sdhc card is not supported. |
The initializations routines ARE different. A SDHC driver will correctly initialize a stardard card but a driver written only for a standard card will not initialize an SDHC card.
The standard for SDHC has dropped SPI support as a mandatory requirement however, have tested a large number of cards from multiple vendors, I have not found any SDHC cards that do not support SPI. Most microSD vendors provide adapters to enable microSD media to be used for mini and full size SD card applications. If the microSD cards did not support SPI then these vendors would be restricting the addressable market for there cards.
| Quote: | | Can the problem be in the 5v to 3.3v translation? I use resistors dividers for output lines and a ttl buffer for input. This has worked with all the sdcards I have including microSD cards but not sdhc cards |
No. If the hardware works for standard media then the problem is the driver.
| Quote: | | also I have not used pullups in the output lines, I make these lines high on startup through the pic. |
You NEED a pull-up on D0. _________________ Regards, Andrew
