Jean FOUGERON
| Have you ever heard of such a thing ? |
Posted: Mon Feb 04, 2013 8:01 am |
Hi friends
I know, it is not a software problem, but a hardware one. It makes me angry as I am blocked on it since months, without answer of manufacturers.
Does anybody know somebody who can help me ?
PLEEEAAAASE
The story is :
I use, in my application, the GPIO PCA9655E from ON Semi or PCA9535 form NXP/Philips.
This IC is pilot via I2C bus and has its own address fixed with 3 pins
I cannot use all the possible addresses allowed in the data sheet. Only 4 of them work !
I have built a test board on which I test each address allowed (apply address combination on pins, apply supply voltage, send I2C command, see result) and only 4 of them work.
Thank you |
Posted: Mon Feb 04, 2013 8:12 am |
Remember this uses 7bit addresses. The address byte needed for a particular pattern on the bits, is twice the number given in the data sheet.
Then study the sheet, The pattern needed are not simple high/low wiring, they require the address pins to be cross wired to SCL, SDA, Vdd and GND. Four different connections for each pin. Using just Vdd and GND, would give just eight possible addresses.
I have used these, and the addresses do work.
Remember the extra loads on SCL and SDA, mean the pull up resistors on these have to be a little lower than is otherwise needed.
Jean FOUGERON
Posted: Mon Feb 04, 2013 8:32 am |
Thanks Ttelmah.
I fix AD2 to AD0 to Gnd of Vcc (on the test board, I fix with 3 outputs of a PIC18F and experiment all the range.
When A2 to A0 goes from 0-0-0 to 1-1-1 the address value goes from 0x40 to 0x4E.
So I make a loop, increasing address value 2 by 2 from 0x40 to 0x4E
I need only these 8 addresses.
The SCL and SDA have 1K resistor to Vcc. |
Posted: Mon Feb 04, 2013 9:32 am |
1K is rather low!. Are you running with 3.3v?. Rpmin at 5v, for fast mode or standard mode I2c, is normally quoted as about 1.2KR.
Jean FOUGERON
Posted: Mon Feb 04, 2013 11:23 am |
OH, 1K is recommended in the data sheet, and I think it is not stupid, as I tried with 10K and the I2C signal was very integrated.
Yes it runs under 3V3
I work in fast mode (400kHz)
Only 0x40, 0x42, 0x4C and 0x4E are recognized
Nor ONSemi nor NXP answer on their forum. I will try Texas.
On your application, did you connect ADx to Vcc or Gnd directly or with a resistor or a RC ? Have the adress to be present at the beginning of POR or after ? |
Humberto
Posted: Mon Feb 04, 2013 1:02 pm |
Jean FOUGERON wrote:
| Quote: |
Wrong.
A0 it is not the LSB in the internal PCA9655E Address Register, instead it is the bit #1.
A0 = R/W selector
Hence A2-A0 going from 000 to 111 should give the following values:
0x00 to 0x0E for Write cycle
0x01 to 0x0F for Read cycle
The detected errors regarding 'unrecognizable addresses' double -check that a slave receiver which is addressed, must generate an
acknowledge after the reception of each byte.
Also, a master must generate an acknowledge after the reception of each byte that has been clocked out of the slave transmitter.
The device that acknowledges has to pull down the SDA line during the acknowledge clock pulse, such that the SDA line is stable LOW
during the HIGH period of the acknowledge clock pulse.
Scope the bus signal signal shapes, set−up time and hold time must be taken into account working in FAST MODE.
regards,
Humberto |
Posted: Mon Feb 04, 2013 3:52 pm |
For 3.3v 1K is fine. It is all down to current, and at 3.3v, you only want about 2/3rd the resistor values normally used with 5v.
Humberto, the addressing of this chip is not simple like this, it allows up to 64 addresses using just three pins. With the pins wired with the 8 patterns using GND or VDD, the 7 bit addresses will be 0x40 to 0x4E.
However, Jean, note the second point that Humberto is making. It is the same as the first line of my earlier post:
| Quote: |
So, alternate addresses 0x80 to 0x9c as sent by the PIC.
Use PCM programmers device finder program, rather than going DIY. It's in the code library.
Jean FOUGERON
Posted: Tue Feb 05, 2013 1:43 am |
| Ttelmah wrote: | the 7 bit addresses will be 0x40 to 0x4E.
| Quote: |
That is why when applying Gnd-Gnd-Gnd the adress is 0x40 (= 2 times 0100 000 "Gnd-Gnd-Gnd-Write")
and when applying Vcc-Vcc-Vcc the adress is 0x4E (= 2 times 0100 111 "Vcc-Vcc-Vcc-Write")
So, when I write 0xFF to the adress AA I obtain SS on the PCA outputs
AA SS
0x40 0xFF
0x42 0xFF
0x44 0x00
0x46 0x00
0x48 0x00
0x4A 0x00
0x4C 0xFF
0x4E 0xFF
| Ttelmah wrote: | | Use PCM programmers device finder program, rather than going DIY. It's in the code library. |
Please explain this as I am not sure to understand. What do you mean by DIY. I think it is not a software problem, but a hardware one. Maybe it is a time problem, I change delays between Supply and Applying Adress values, but no effect.
What do you mean by "PCM progr' device finder prg", I use PCH. |
Posted: Tue Feb 05, 2013 1:58 am |
PCM's scanner will scan the bus, and show you the address the chip is at.
Allow you to see where the device really is.
Jean FOUGERON
Posted: Tue Feb 05, 2013 2:14 am |
| Tell me more, I don't know this tool. |
Posted: Tue Feb 05, 2013 2:39 am |
As I said, it is in the code library. Search for I2C scanner.
Jean FOUGERON
Posted: Tue Feb 05, 2013 3:29 am |
I see
You know, my test board looks like a scanner (I apply an Adress on DUT,I switch on power supply on DUT,I configure the DUT in OUTPUT MODE, I send a write 0xFF and I look whether the output goes on. Then finally I switch off the supply on DUT)
I observe there is no ACK when it does'nt work, it seems normal but I do not understand why it ACKS on som adresses and not on others !  |
Posted: Tue Feb 05, 2013 6:08 am |
Seriously, I doubt if you can do addressing like this. Most devices would not accept this. If you are applying the address as signals, which include Vdd, then the device will be partially powered by the address lines, and the address won't be correctly read. You can't have powered lines driving a chip that is switched off. If you are controlling the chip's power with a processor output, then the same power line needs to feed the circuit that 'applies the address' as well.....
Jean FOUGERON
Posted: Tue Feb 05, 2013 7:51 am |
| Ttelmah wrote: | If you are controlling the chip's power with a processor output, then the same power line needs to feed the circuit that 'applies the address' as well.....
The processor drives a emmitter follower trans which supply the DUT |
Posted: Tue Feb 05, 2013 8:04 am |
But what feeds the addresses.
The point is that the chip _will_ have protection diodes on the address inputs, so that if they go above the supply rail (when the chip is turned off), current will flow through these inputs leading to unexpected results.
I'd say the only way you are going to get this to work right, without major changes to the hardware, is to connect all the address inputs via resistors to the computer controlled supply. Then use the outputs that drive these as open collector drives. So set the latch to 'low', and use output_drive when you want the pin to be driven low, and output_float when you want it to go high.
The problem is in how you are trying to control the address signals, not the chip.
