sprintf resetting PIC24
alan
PostPosted: Wed Dec 12, 2012 2:44 pm     Reply with quote
I am using sprintf to format a string, but the PIC keeps on resetting if I use the sprintf. If I remove the sprintf then no problem. I have replaced the sprintf with writing the data in one byte at a time and then everything works OK, tried to use sprintf to tidy the code up and more readable.
CCS 4.140
PIC24F16KA302
Osc.h
#include <24F16KA302.h>
//#device ICD=TRUE
#DEVICE ADC=12
#include <stdlib.h>
#include <math.h>
//#FUSES WPRES32                  //Watch Dog Timer PreScalar 1:32
//#FUSES WPOSTS3                  //Watch Dog Timer PostScalar 1:4
#FUSES SOSC_DIGITAL
#FUSES NOWRT                      //Program Memory Write Protected
#FUSES NOPROTECT                  //Code protected from reads
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES OSCIO                    //OSC2 is general purpose output
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
//#FUSES WDT_NOSL                 //Watch Dog Timer, disabled during SLEEP
//#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES FRC_PLL
#FUSES NOWDT                 // No Watchdog timer
#CASE
//#use delay(clock=32000000,RESTART_WDT)
#use standard_IO(A)
#use standard_IO(B)
//--- IO assignment for LCD PG12864 --------------------------------------------
#define  A0  PIN_B8    //A0
#define  CS  PIN_B12
#define  SCL PIN_B5
#define  SDA PIN_B6
#define  RES PIN_B10
#define  VBat 0
#define  V1Ch 5
#define  V2Ch 1
#define  I1Ch 4
#define  I2Ch 15
#byte  SPI1STAT = 0x0240
#byte  SPI1CON2 = 0x0244
#define REG_VOLT 338  //Voltage output of Reference
extern int8 Cnt;
extern  char BatDisp[10];
extern  char V1Disp[10];
extern  char V2Disp[10];
extern  char I1Disp[10];
extern  char I2Disp[10];
extern  int8 GainTest;
int1 Temp;
void delay_ms(int16 delay);
Osc1.c
#include <Osc1.h>
//--- Add modules headers ------------------------------------------------------
#include "font_eb.h"
#include "PgSer.h"
#include "ADC.h"
#include "PGA.h"
//--- Add module code ----------------------------------------------------------
#include "PgSer.c"
#include "ADC.c"
#include "PGA.c"
char BVolt[12]= "Bat = ";
char V1Volt[12]="V1 = ";
char V2Volt[12]="V2 = ";
char I1Volt[12]="I1 = ";
char I2Volt[12]="I2 = ";
int8 Cnt;
char BatDisp[10];
char V1Disp[10];
char V2Disp[10];
char I1Disp[10];
char I2Disp[10];
int8 GainTest;
#int_TIMER2
void  TIMER2_isr(void)
// Test Code flashing LED
   Cnt = Cnt + 1;
   if (Cnt >= 5) {
     Temp = input(PIN_A2);
     Temp = !Temp;
     output_bit(PIN_A2,Temp);
     Cnt = 0;
#int_SPI2
void  SPI2_isr(void)
  //Finished writing, disable CS
  output_bit(CS,1);
void delay_ms(int16 delay) {
    int16 i;
    int16 j,a;
    j= delay;
    for (j=0;j<delay;j++) {
       for (i=0;i<delay;i++) {
        a=i*3;
        a=a*4;
   setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4 | SPI_XMIT_L_TO_H | SPI_MODE_8B | SPI_SS_DISABLED);
   setup_spi2(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4);
   setup_adc_ports(sAN0 | sAN1 | sAN4 | sAN5 | sAN15);
   setup_adc(ADC_CLOCK_INTERNAL | ADC_TAD_MUL_31);
   //setup_adc(ADC_CLOCK_DIV_32 | ADC_TAD_MUL_16);
   setup_timer2(TMR_INTERNAL |TMR_DIV_BY_256 ,6250); //100ms interrupt
   setup_timer4(TMR_DISABLED |TMR_DIV_BY_1 ,0);
 //  setup_timer3(TMR_INTERNAL |TMR_DIV_BY_64 ,250);  //1ms interrupt
   setup_timer5(TMR_DISABLED |TMR_DIV_BY_1 ,0);
   setup_oscillator(OSC_INTERNAL,8000000);
   setup_timer1(TMR_DISABLED);
   //Define TRIS REG
  glcd_Init();                  //initialize LCD
  while(TRUE){                  //loop forever
    ReadBatVolt();
    ReadV1();
    ReadV2();
ADC.c
void ReadBatVolt(void) {
  int16 adcVal;
  float BatVolt;
  set_adc_channel(VBat);
  delay_ms(1);
  adcVal = read_adc();
  BatVolt = ((float)adcVal*REG_VOLT/88200);
  sprintf(BatDisp,"%4.2f V",BatVolt);
void ReadV1(void) {
  int16 adcVal;
  float Volt1;
  set_adc_channel(V1Ch);
  delay_ms(1);
  if (adcVal < 12) { //Overflow of positive signal
    strcpy(V1Disp,"OFlow");
    return;
  adcVal = (GV1Off[pgaGV1E]-adcVal)/pgaGV1A;
  Volt1 = ((float)adcVal*REG_VOLT*0.12/4096);
  sprintf(V1Disp,"%4.2f V",Volt1);
void ReadV2(void) {
  int16 adcVal;
  float Volt;
  set_adc_channel(V2Ch);
  delay_ms(1);
    strcpy(V2Disp,"OFlow");
    return;
  adcVal = (GV2Off[pgaGV2E]-adcVal)/pgaGV2A;
  Volt = ((float)adcVal*REG_VOLT*0.12/4096);
  sprintf(V2Disp,"%4.2f V",Volt);
Thanks Alan
PostPosted: Wed Dec 12, 2012 3:36 pm     Reply with quote
comment...
I'm curious as to how the compiler handled your 'delay_ms()' function when it already has one.
I'd have thought some sort of error message would have occoured...
PostPosted: Wed Dec 12, 2012 3:59 pm     Reply with quote
Commonest reason for printf/sprintf problems on PIC24. Stack not large enough.
alan
PostPosted: Wed Dec 12, 2012 11:13 pm     Reply with quote
Thanks for replies.
temtronic, I always battle with the CCS delay when simulating or debugging. On production code I use CCS. I found if I just define after #USE delay, compiler sees it as overload and uses that.
Ttelmah, any suggestions or work around. If I do it 'manually' it generates a lot of overhead code, eg. on 16k PIC ROM used go from 46% to 54%.
Thanks again
alan
PostPosted: Wed Dec 12, 2012 11:30 pm     Reply with quote
Sorry Tlelmah, I missed the solution last night, already on forum. Embarassed
Need to include
#build (stack=256)
