		| Author | Message |
		| alan
				| Display driver for LM6063 GLCD |
				|  Posted: Mon Dec 10, 2012 4:01 am |   |
				| Below is a driver based on Torello's driver also in this forum but for the LM6063 chip.
 Uses the SPI bus instead of software SPI and include the necessary changes to work, otherwise it performs the same as the original driver.
 Thanks Torello for the driver, made the work much less than to design from scratch.
 I only included the PgSer.c file as the others are identical to Torello's files.
  	  | Code: |  	  | void glcd_WriteData(int8 data, char type) {
 //Wait while SPI still busy
 //while (SPI2_Busy) {}
 output_bit(CS,0);               //Chip Select = Active
 output_bit(A0,type);               //A0 = Data
 //SPI2_Busy = TRUE;
 spi_write2(data);
 void glcd_Init() {
 output_bit(CS,1);
 output_bit(A0,0);
 output_bit(CS,0);
 output_bit(RES,0);
 output_bit(RES,1);
 delay_ms(10);
 glcd_WriteData(0xE2,0);                  //Reset display
 glcd_WriteData(0xA2,0);                  //1/9 bias
 glcd_WriteData(0xA1,0);                  //RAM->SEG output = normal
 glcd_WriteData(0xC0,0);                  //COM scan direction = normal
 glcd_WriteData(0x40,0);                  //Set Display start line
 glcd_WriteData(0x2C,0);                  //power control set
 glcd_WriteData(0x2E,0);                  //power control set
 glcd_WriteData(0x2F,0);                  //power control set
 glcd_WriteData(0x25,0);                  //set Rb/Ra voltage resistor ratio to 6 (Adafruit Value, no info from LM6063 Manual)
 glcd_WriteData(0xA6,0);                  //Normal Display
 glcd_WriteData(0x81,0);                  //Electronic volume command (set contrast)
 //Electronic volume value (contrast value) Higher less contrast
 glcd_WriteData(0x28,0);
 glcd_WriteData(0xAF,0);                  //Display ON
 //glcd_WriteData(0xA5,0);                  //Display all points ON
 //delay_ms(1);
 void glcd_DispClr() {
 unsigned int8 i,j;
 glcd_WriteData(0xE0,0);  //Col inc after write
 for(j=0;j<8;j++){
 glcd_SetRowCol(j,0);
 for(i=0; i<128; i++) {             // 16 bytes per line 64 lines
 glcd_WriteData(0,1);                // write empty byte
 glcd_WriteData(0xE0,0);  //Reset Col inc after write
 void glcd_SetRowCol(int8 row, int8 col) {   // Col=0..15, Row=0..63
 int8 cl;
 glcd_WriteData((row&0x0F)+0xB0,0);               // set the X adr=0 (0-15)
 cl=(col&0x0F)+ 0x0;                   // concat command to Ynibble low
 glcd_WriteData(cl,0);                     // set the Yadr low nibble  (0-63)
 cl=(swap(col)&0x0F)+0x10;              // concat command to Ynibble high
 glcd_WriteData(cl,0);                     // set the Yadr hi nibble   (0-63)
 void glcd_printf(int8 row, int8 col, char *cstring, int8 mode) {
 int8 cl,c,i,j;                        // col counter
 int8 si;                              // string index
 int8 bi;                              // font byte index
 int8 fi;                              // font array index
 int8 BoxSm;                           // box State machine 0=no box
 int8 W2Sm;                            // width2 state machine
 int8 Lmax;                            // number of lines in casde of magnify
 Lmax=1;                                 //H1 line
 if ( dBT(h2) ) Lmax=2;                  //H2 line
 if ( dBT(h4) ) Lmax=4;                  //H4 line
 row=row>>3;
 for(i=0; i<Lmax; i++) {                 // line loop
 cl=col;                            // load current col with start colum
 si=0;                                 // clear string index
 bi=0;                                 // clear font byte line index
 fi=0;                                 // clear from 255;
 W2Sm=0;                               // clear width state machine
 BoxSm=0; if dBT(box) BoxSm=1;         // arm box statemachine
 if dBT(inv) BoxSm=1;                  // invert mode add 1 vertical black line (more readable)
 do {
 if dBT(w2) W2Sm=2;                  // arm width2 statemachine
 if (!bi) {
 if (BoxSm==1) {
 BoxSm=2;                        // advance state machine "print chars"
 if dBT(inv) BoxSm=3;            // invert mode add 1 vertical black line then stop BoxSM.
 si--;                           // need to correct the bi==5 increment.
 bi=5;                           // force next line to be a space line
 c=0xFF;                         // load the vertical line
 goto pf_next_bx;                // skip font[]{bi] reading stuff
 } else {
 fi = cstring[si];               // get string character
 if (fi==0) {                    // string end read. But:
 if (BoxSm==2) {
 BoxSm=3;                    // advance state machine
 } else {
 fi=255;                     // load sting end value need to exit while
 goto pf_next2;              // ri==0 thus we are done for this line
 fi-=32;                         // substract font array offset
 if (bi<5) {                         // still reading font
 c = Font5x7[fi][bi];              // read font data
 bi++;
 if (c==0x99) {                    // T: font end marker detected
 c=0;                            // replace with empty
 if dBT(var) {                   // var font requested..
 bi=0; si++;                   // so 0x99 ends character
 } else {
 c=0;                              // bi=5 always a space line
 bi=0; si++;                       // clear byte line index and increase character index.
 pf_next_bx:
 if dBT(h2) {                        // T: double magnefy character
 if (i) swap(c);                   // line2; need upper nible as magnefy index
 c&=0x0F;                          // get rid of unwanted nibble
 c = Mgnfy2[c];                    // get the magnefied font byte
 if dBT(h4) {                        // T: quadruplle magnefy character
 if (i&0x2) swap(c);               // line2 or 3; need upper nible as magnefy index
 if (i&0x1) c>>=2;                 // need b3&2 on spot b1&0
 c&=0x03;                          // get rid of unwanted bits
 c = Mgnfy4[c];                    // get the magnefied font byte
 //===== linestuf
 //Toplines:
 if (i==0) {
 if dBT(box) c|=0x01;                                                    // add boxing topline
 if dBT(tl) c|=0x01;                                                     // add just topline
 if (!dBT(h2) && !dBT(h4) ) {                                            // T: Height -SINGLE-
 if dBT(box) c|=0x80;                                                  // add boxing botline
 if dBT(bl) c|=0x80;                                                   // add touching botline
 if ((i==1) && dBT(h2)) {                                                  // last line Height -DOUBLE-
 if dBT(box) c|=0x80;                                                    // add boxing botline (free botline)
 if dBT(bl) c|=0x80;                                                     // add free botline
 if ((i==3) && dBT(h4)) {                                                  // last line Height -QUADRO-
 if (c==0xFF) c=0x3F;                                                    // correct left right vertical boxing line for i==3
 if dBT(box) c|=0x20;                                                    // add boxing botline
 if dBT(bl) c|=0x20;                                                     // add free botline
 if dBT(inv) c|=0xC0;                                                    // correct inversion to come
 pf_next3:
 if dBT(inv) c=~c;                                                         // T: invert font.
 do {
 pf_next1:
 glcd_SetRowCol(row,cl++);                                               //set printing adress and increase cl.
 glcd_WriteData(c,1);
 if (W2Sm) W2Sm--;                                                         //countdown w2 state machine
 } while (W2Sm>0);
 } while( (cl<128) && (fi!=255));                                             // until colum 16 is written or end sign set
 pf_next2:
 row=row+1;        // next line
		| octopuss83
				| Config SPI |
				|  Posted: Sun Jan 26, 2014 4:41 am |   |
				| Can you tell me how is set your Spi ?
 #USE SPI(???)    (MASTER , Speed ? etc...)
 and
 setup_spi2 (???)
 Thanks for your driver ...
 ______________________
 -- Octopuss ---
		| pieter
				|  Posted: Tue May 06, 2014 3:39 pm |   |
				| Hi Alan, can you post the complete library with all files please?
 Thanks!
 | You cannot post new topics in this forum You cannot reply to topics in this forum
