How to set only 1 bit of a register?
stoyanoff
PostPosted: Tue Dec 04, 2012 2:23 am     Reply with quote
Hi! I want to know how to set only 1 bit from a register. For example if I want to set PIN_A0 to be an input I should set TRISA0 bit to 1. I don`t like this:
set_tris_a();
because it changes the other pins of PORT A.
How can I achieve this??
Thanks!
Mike Walne
PostPosted: Tue Dec 04, 2012 3:48 am     Reply with quote
You use the CCS:-
value = input(PIN_A0)
The compiler takes care of the tris etc.
If your chosen pin can be analogue, that will have to be turned off.
It's all in the CCS manual.
Mike
PostPosted: Tue Dec 04, 2012 9:07 am     Reply with quote
Or if you feel you must access TRIS separately, 'output_drive' sets a pin to output, and 'output_float' sets it as an input.
PostPosted: Tue Dec 04, 2012 5:06 pm     Reply with quote
There are at least 4 OK CCS ways to do this:
The 3rd is to use get_ /set_tris with masking of one or more bits between the operations.
The 4th way is to avoid fixed/static IO and just do the input or output operation you wish on the pin, and let the compiler sort our the TRIS for you , which it can do rather well if you let it ( oh right Mike W already pointed you to that ).
Very Happy Very Happy
stoyanoff
PostPosted: Wed Dec 05, 2012 1:30 am     Reply with quote
I'm using 18F66J60 and the automatic setup from ccs doesn`t work.
I've seen this trick with the mask. It should be something like this:
*0xF93=*0xF93 && 0x01;
I'll try this methods.
PostPosted: Wed Dec 05, 2012 2:08 am     Reply with quote
Seriously, avoid this.
Multiple reasons:
1) Avoid using hardwired register addresses like this. Reduces portability.
2) Takes a lot of time. This will involve reading the register, performing the masking operation, and writing it back.
0xF93, is not the TRISA register, which you asked about. It is TRISB.
Now, what do you mean 'the automatic setup from CCS doesn't work'. Just tried:
output_float(PIN_B0);
Which is the instruction to set the bottom TRIS bit for this register, and it correctly codes for your processor, to:
....................    output_float(PIN_B0);
0020:  BSF    F93.0
Setting bit 0 in this register as required. Worked with 4.134, and .140 correctly.
If you must do it by register access, then code as:
#byte TRISB=getenv("SFR:TRISB")
#bit TRISB0=TRISB.0
    TRISB0=1;
//which again correctly generates:
0022:  BSF    F93.0
Compare with the bit code you show, and a version modified to use register names:
....................    *0xF93=*0xF93 && 0x01;
0024:  MOVF   F93,F
0026:  BNZ   002C
0028:  MOVLW  00
002A:  BRA    002E
002C:  MOVLW  01
002E:  MOVWF  F93
....................    TRISB=TRISB && 0x01;
0030:  MOVF   F93,F
0032:  BNZ   0038
0034:  MOVLW  00
0036:  BRA    003A
0038:  MOVLW  01
003A:  MOVWF  F93
//Or just use bit_set
....................    bit_set(TRISB,0);
003C:  BSF    F93.0
Note how much bulkier, slower, etc., the mask versions are....
Use the output_float, or bit_set with the register named as shown......
PostPosted: Wed Dec 05, 2012 8:09 am     Reply with quote
Masking is of use when 2 or more pins are to be changed synchronously.
The key concept is if a synchronous state change is required for more than one pin at a time then mask. Otherwise one at a time is most code efficient.
PostPosted: Thu Dec 06, 2012 1:53 am     Reply with quote
One last note:
This code will fail for other values than 0 or 1. '&&' is the 'logical AND' operator which can only return 0 or 1. What should have been used is the 'bit wise AND' operator '&':
*0xF93=*0xF93 & 0x01;
PostPosted: Fri Dec 07, 2012 3:46 am     Reply with quote
Couldn't help myself but tested the '&&' version against the correct '&' version:
....................    *0xF93=*0xF93 & 0x01;
0026:  MOVLW  01
0028:  ANDWF  TRISB,F
....................    TRISB=TRISB & 0x01;
002A:  ANDWF  TRISB,F
....................    //Or just use bit_set
002C:  BSF    TRISB.TRISB0
Now the mask version is reduced to only 2 instructions instead of 6.
Conclusion:
For just (re)setting a single bit the bit_set() function is fastest with 1 instruction, but for 2 or more bits the masked version is equal or faster.
PostPosted: Fri Dec 07, 2012 5:20 am     Reply with quote
Yes, if you think about it, the && version performs a logical test before the mask. That is the extra code.
I'd expect the mask code generally to be worse on a PIC16, with bank switching getting involved, so probably going up to four instructions instead.
hemnath
PostPosted: Sat Dec 08, 2012 5:34 am     Reply with quote
 #BYTE TRISA        =  0xF92  // for pic18F2520 and change this value accoding to your controller
 #BIT    TRIS_A0    =  TRISA.0
 #BIT    TRIS_A1    =  TRISA.1
 #BIT    TRIS_A2    =  TRISA.2
 #BIT    TRIS_A3    =  TRISA.3
 #BIT    TRIS_A4    =  TRISA.4
 #BIT    TRIS_A5    =  TRISA.5
 #BIT    TRIS_A6    =  TRISA.6
 #BIT    TRIS_A7    =  TRISA.7
PostPosted: Sat Dec 08, 2012 8:54 am     Reply with quote
ahh yes, the 4th way .....
as already pointed out:
let the compiler translate:
#byte TRISA=getenv("SFR:TRISA")
