[Solved] USB_Init crash PIC18F4550
Goto page 1, 2  Next
ELCouz
PostPosted: Sun Dec 02, 2012 11:48 am     Reply with quote
Dear CCS/PIC expert,
I'm running into a pic crash (neither pic pin C6,C7 or A0 led light up) when i enable the usb function of the pic.
#include <18F4550.h>
#FUSES NOWDT,HSPLL,STVREN,NODEBUG,NOLVP,NOWRT,NOWRTD,NOMCLR,PLL3,CPUDIV1,USBDIV,VREGEN
#use delay(clock=48000000)
#include <usb_cdc.h>
#include <string.h>
usb_cdc_init();
usb_init();
output_high(pin_c7);
output_high(pin_c6);
output_high(pin_a0);
   usb_task();
If I comment the following lines pic will run ok (PIN_A0,C6,C7 goes HIGH)
usb_cdc_init();
usb_init();
usb_task();
I've checked the Vusb voltage it's 3.3V and steady!
Also no usb popup on windows side when connecting the usb (not even a device fail warning , or any sounds)
Btw, PCWHD 4.134 and 12 mhz quartz
Any clues?
Thank you very much!!
EDIT: 470 nF polymer cap on Vusb to ground
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
PostPosted: Sun Dec 02, 2012 12:49 pm     Reply with quote
1st thing...
Have you tried the CCS supplied USB example code...located in the examples folder?
Also have you installed , on the PC, the 'driver' or 'inf' file that they also supply ?
I know for a fact their code does work..but ...as the PIC USB driver code takes 1/3 of available code space I've since gone to 'regular' PICs and ttl-usb modules. Only $3 a pop,they work and NO codespace required.
hth
jay
ELCouz
PostPosted: Sun Dec 02, 2012 1:08 pm     Reply with quote
I've tried the example first it wasn't working so that's why i've posted a more simple usb code (easier troubleshooting)
For the driver to be installed, i need first the PIC to be recognized by Windows which i can't !
Is it possible to have a fried USB Module inside the pic but the rest is okay?
- The pic is working very well except when i enable USB (freeze)
- Vusb is stable and outputting correct voltage
I really don't know what to explain more ? :(
thank you
Regards,
Laurent
PostPosted: Sun Dec 02, 2012 1:35 pm     Reply with quote
Triple check your connections. Classic one is having D+ and D- reversed.
ELCouz
PostPosted: Sun Dec 02, 2012 1:39 pm     Reply with quote
That's what i thought first before posting here ... i wish it was simple as that!
Looks like I have a dead USB module ... even when doing output_high(PIN_C4 & C5 which are D- /D+) i get 0v on the scope!!!
Must be why the whole thing freeze!
Should have put a pdip socket on my prototype board... lets go resolder another one !!
Regards,
Laurent
PostPosted: Sun Dec 02, 2012 1:59 pm     Reply with quote
No, the USB pins _are not_ available as standard I/O pins. Nothing will come out on then from an output_high.
Remember the examples _do_ assume PIN_USB_SENSE is connected (normally B2), and the example code requires this.
rwskinner
PostPosted: Mon Dec 03, 2012 7:36 am     Reply with quote
On the 18F4550 I'm using, I also have problems with usb_init causing the program to stall there unless a usb cable is connected. As soon as I connect a cable and the PC bleeps stating the driver installed, then enumeration occurs, the rest of my program works as designed.
Commenting out
usb_cdc_init();
usb_init();
and the program runs fine with the exception of no USB.
Richard
PostPosted: Mon Dec 03, 2012 8:45 am     Reply with quote
Of course usb_init will stall unless the cable is attached.
It waits for the USB to be connected.....
If you want to wake up without USB, but with it becoming available if the connection is made, then you need to do the following:
void main(void) {
    int1 usb_cdc_old_connected=FALSE;
    int8 itemp;
    //Other initilalisation here
    //First you must have connection sense. This is actually _required_ by the
    //USB specification, but a lot of devices that are bus powered can cheat
    //and not use it. All other devices should have it.
    //Use usb_init_cs instead of usb_init.
    usb_init_cs();
    //see comment about interrupts below.....
    //You don't need to call cdc_init. This is called automatically by init, if cdc
    //is selected.
    while {
       //main code loop
       if (usb_attached()) {
          usb_task();
          //you must call 'task', before testing 'enumerated'.
          if (usb_enumerated()){
             if (usb_cdc_carrier.dte_present) {
               if (usb_cdc_oldconnected==FALSE) {
                  printf(usb_cdc_putc,"I/F active\n\r");
                  usb_cdc_oldconnected=TRUE;
               if (usb_cdc_kbhit()) {
                  itemp=usb_cdc_getc();
                  //and handler code here to do what you want
                usb_cdc_oldconnected=FALSE;
This automatically sends a message when the USB connects (I/F active). You can make this some suitable introduction to your device. But it will keep looping, and not hang if the USB is not there.
Key points are that you must use connection sense, and use the usb_init_cs, which sets of the peripheral _waiting_ for the connection to be made.
One other comment, if you are using interrupts in your code, you need to enable them. init_cs, _only_ enables the interrupts if the connection is present.
ELCouz
PostPosted: Mon Dec 03, 2012 5:56 pm     Reply with quote
hmmm after hours of troubleshooting... turns out a OSC related problem i think
Why when i touch the quartz pin the USB suddenly start (windows sound and device enumerated itself!)?
I use 22 pf caps (to ground) on both 12 mhz quartz pins...
What the hell?
Maybe an electronic guru can explain how is it possible...
thank you very much!
have a nice day!
EDIT: from the quartz casing to ground i have 1.39V is that normal?
Regards,
Laurent
ELCouz
PostPosted: Mon Dec 03, 2012 6:21 pm     Reply with quote
More information to help
Here's my usb test board
Everything is ok?
Regards,
Laurent
PostPosted: Mon Dec 03, 2012 6:45 pm     Reply with quote
Quirky problems can come from almost anything, sorry...
If a PCB, then maybe a bad solder joint, very thin trace, flux bridge, etc.
If a 'whiteboard' (solderless), could be minor corrosion of the internal strip, not enough contact (comes from trying to put 1W resistors in the holes).
Personally I'd have 100mfd, 10V cap on the power feed. On my 4550 boards, I used 4MHz xtals (still have tons from 16C84 days), though 12MHz should be fine (be sure 'mode' is right HS, I think...)
Now I'm using 18f46k22 with the internal osc. at 16MHz on breadboards and they're fine...
You 'might' have a bad xtal, try another 12 or 8 or 4 or ?? you have.
It'll be a process of elimination...hopefully not an ordeal.
Please report back when the 'cure' is found...always nice to know why!
hth
jay
ELCouz
PostPosted: Mon Dec 03, 2012 7:49 pm     Reply with quote
- Replaced xtal by another type (was L4 now UM1) @ 12 mhz
- Replaced 22 pf ceramic caps by 15 pf
- Grounded the xtal metal case
usb_cdc_init();
usb_init();
   usb_task();
   usb_cdc_putc("#");
USB connect well and transmit but hang after a few minutes :(
UPDATE: after reading docs of the compiler
usb_task()
If you use connection sense, and the usb_init_cs() for initialization, then you must periodically call this function to keep an eye on the connection sense pin. When the PIC is connected to the BUS, this function will then perpare the USB peripheral. When the PIC is disconnected from the BUS, it will reset the USB stack and peripheral. Will enable and use the USB interrupt.
I don't use the sense pin ...
I'll try with usb_task removed
UPDATE #2:
USB disconnect and reconnect itself ... I suspect noise in power vcc ou vusb.
I'll check with my scope
Regards,
Laurent
ELCouz
PostPosted: Mon Dec 03, 2012 8:41 pm     Reply with quote
I see alot of ripple on the Vusb (cyan)
5v is yellow
Should i increase or change caps on the Vusb?
Regards,
Laurent
PostPosted: Tue Dec 04, 2012 1:59 am     Reply with quote
Seriously, use connection sense.
CS, is actually required by the USB specs. A device is required to not enable it's transceivers, unless it sees power on the bus. It is OK to not have it, if you use a device powered by the bus (since then the presence of the 5v enables the chip and the transceivers), but otherwise CS is technically required.
Like a lot of things on USB, many devices 'get away' with this, but it causes problems later, when the CPU puts the bus to sleep, and it then doesn't wake up again, because the transceivers haven't switched off, and the devices don't re-negotiate properly....
Big capacitors on Vusb, are bad, and can damage the regulator. The spec originally suggested 220nF, but they later suggested 470nF. Something with good HF characteristics though. I'd suggest polyester. Generally polymer capacitors are better than traditional 'electrolytic', but do not have the HF responses of types like polyester. Put a 0.1uF ceramic in parallel with your polymer capacitor, to improve the HF response.
ELCouz
PostPosted: Tue Dec 04, 2012 4:21 pm     Reply with quote
Thanks Ttelmah!
I have a major problem and i think its the root of all my problems...
i've redone the prototype 2 times on 2 different veroboard. Same problem with the usb.... exactly the same prototype and components was used on a Breadboard works #1 with the usb (no random disconnect reconnect same code).
but...
when i touch the ground or any parts that are grounded the USB work #1... when i plug my scope on the ground the board works and i hear the usb connect sound
if i remove my finger from ground i get USB Unrecognized device popup in the tray... i retouch with my finger the ground, device work fine...
How to solve this ground problem ???
Everything is grounded on the GND pin (4) of USB B connector
Only power source is the 5V from the usb pin (1)
Flux has been cleaned more than once to be sure, checked solder bridge, bad joints found nothing!
Any clues?
Regards,
Laurent
Goto page 1, 2  Next
Page 1 of 2
