PIC24 Bit array equality testing
john.ma
PostPosted: Thu Nov 29, 2012 11:47 am     Reply with quote
Hi Guys,
Could someone confirm whether they're also getting the same output through MPSIM when using the below code? Testing for same bits returns false if referenced as array element :/
I tested this with version PCD 4.138
#include <24fj128GA010.h>
#fuses NODEBUG      // Debug Mode. 1.11   NODEBUG   No Debug mode for ICD
#fuses HS,PR_PLL    // Crystal HS, 4xPLL
#fuses NOIESO       // No 2-speed Start Up
#fuses NOJTAG       // No JTAG
#fuses NOPROTECT    // No Memory Protection
#fuses NOWDT        // No WatchDog Timer
#use delay(clock=32M, crystal=8M)
int outIndex, outDataSize=16, x, duration;
int1 outputData[] = { 1,0,0,1,1,0,1,0,1,0,1,0,1,0,0,0};
int1 temp3= 0, temp2=0, temp;
   duration = 0;
   outIndex = 0;
   temp3 = outputData[outIndex];
   temp2 = outputData[duration];
   if(temp2 == outputData[outIndex])
      x = 19; // doesnt work
   if(outputData[outIndex] == outputData[duration])
      x = 20;  // doesnt work
   if(temp2 == temp3)
      x = 21;  // works
   if(temp3 == outputData[duration])
      x = 22;  // doesnt work
   if(!(outputData[duration] ^ temp3))
      x = 22;  // works
   // Does not compile. Error 84 Pointers to bits are not permitted
   // Reodering terms resolves compiler error (?!)
   //if(!(temp3 ^ outputData[duration))
   //   x = 22;
   // Doesnt work.
   for( duration=outIndex; temp3 == outputData[duration] ; duration++);
   duration = (duration-outIndex);
   // Works. Terms must be in that order otherwise compiler will raise error
   for( duration=outIndex; !(outputData[duration] ^ temp3) ; duration++);
Thanks Smile
PostPosted: Fri Nov 30, 2012 4:08 am     Reply with quote
I don't have the PIC24 compiler, but from the release notes for 4.139 I noted this:
4.139 Some packed structure problems have been fixed
You might give the new version a try...
PostPosted: Sun Dec 02, 2012 2:27 am     Reply with quote
This seems to relate to a long standing problem with PCD, and 'types'.
If you code, with 4.137:
   if(outputData[outIndex]==temp2)
      x = 19;
//Versus
The former correctly references the bit field, calling a subroutine to solve the value of the bit, while the latter does not.
If then you try:
   if((int8)temp2==(int8)outputData[outIndex])
      x = 19;
This again forces the subroutine call, and works.
Same applies to the noted error about bitfields....
   if(!((int8)temp3 ^ (int8)outputData[duration]))
      x = 22;
So:
   //Works because though 'temp3' is an int1, in the expression on the right
   //the compiler 'sees' the array as int8, and performs the access.
   if(temp2==outputData[outIndex])
   //Fails because the compiler tries to use 'int1' as the basic type, and this
   //doesn't access the bit array correctly.....
   if(temp2==(int8)outputData[outIndex])
   //works again.....
   //as does:
   if(!(temp3 ^ (int8)outputData[duration]))
      x = 22;
It appears you can make it always work, by preceding every point where you access a bit array, with an int8 cast.
It appears that in getting bit arrays to work, CCS have 'missed' a little bit in the type casting, with the code needed to correctly access the bits, only being called if the expression is using int8 or larger types, while the bit field returned is an int1. Hence if everything in the expression is int1, the access code fails....
The code still does the same, not using the bitfield access, unless you force use of int8, with 4.140.
john.ma
PostPosted: Fri Dec 07, 2012 3:59 am     Reply with quote
Ttelmah,
If I could buy you a pint I would. Second time you've helped me :D
Much appreciated.
PostPosted: Fri Dec 07, 2012 9:37 am     Reply with quote
Glad it worked.
If no-one else has done so, I'll post a bug report to CCS. They might then fix this.
PostPosted: Mon Dec 10, 2012 3:21 pm     Reply with quote
FYI, CCS, have said this will be fixed in the next release.
Watch this space. Smile
