string operation
Johann17943
string operation
PostPosted: Thu Nov 22, 2012 11:16 am     Reply with quote
Hi there!
I want to use a string array to use different language for printf(printlcd..)-function. My idea is to put all strings that I use in a 2-dimensional array, where the first is the English string and second the other language.
I could use the following code, but it seems to be not a very nice programming
if (i==0) printf(printlcd,"german");
else printf(printlcd,"deutsch");
I would like something like
printf(printlcd,text[i,7]);
this should show the according string while i=0 for english and i=1 for other language.
One string is maximum 16 characters long (according to one display line).
Could anybody help me? I'm working with PCWH 4.138 on PIC18F4550 (8% RAM used until now).
Thanks.
Johann
Mike Walne
PostPosted: Thu Nov 22, 2012 12:29 pm     Reply with quote
Declare a variable 'language'.
Use arrays as you suggest.
When language == 0, prints in english.
When language == 1, prints in other.
Mike
Johann17943
PostPosted: Thu Nov 22, 2012 1:57 pm     Reply with quote
Hi Mike,
thanks, but how to declare the arrays (strings)? And where to store them (RAM, EEPROM, Program Memory? The strings should not have all the same length (min. 3 characters, max. 16). Is that possible? Anyway I will try to use for the two languages the same length.
Could you give me an example? What header files do I have to include?
Thanks.
Johann
PostPosted: Thu Nov 22, 2012 7:18 pm     Reply with quote
There are many threads on this topic. There are many complex variations
of how to store strings and how to pass a pointer to them:
http://www.ccsinfo.com/forum/viewtopic.php?t=48456
http://www.ccsinfo.com/forum/viewtopic.php?t=30610&start=1
http://www.ccsinfo.com/forum/viewtopic.php?t=41353
If you're a newbie, I suggest that you just put the string in a printf
statement:
#include <16F877.H>
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
printf("Hello World\n\r");
Johann17943
PostPosted: Sat Nov 24, 2012 8:26 am     Reply with quote
Thanks!
I was searching but, as you say, there are many threads. This helped me to save a lot of time.
Regards,
Johann
catacomsa
Error during compilation
PostPosted: Sun Dec 02, 2012 2:16 pm     Reply with quote
Hello All,
I'm a beginner in micro controllers
I create a short code, the idea is to pass a string to a function, but with no success...
#include "18F4550.h"
#DEVICE ICD=TRUE
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,MCLR,DEBUG
#use delay(clock=48000000)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
void prints(char *s)
printf("%s",*s);
void main (void)
prints("test");
The error:
    *** Error 90 "main.c" Line 17(14,15): Attempt to create a pointer to a constant
    1 Errors, 0 Warnings.
Seems that the function can not handle a string
why this error? what is wrong?
PS: Sorry for my English
PostPosted: Sun Dec 02, 2012 3:15 pm     Reply with quote
How about searching the forum?. This has been covered in thousands of threads...
char str[]="test";
prints(str);
Key is that "test" is a _constant_ string, not a RAM string.
Mike Walne
Your code is neither complete nor compilable, so we can't test it!
Mike
No PIC type, compiler version etc.
Read the CCS forum guidelines.
catacomsa
PostPosted: Mon Dec 03, 2012 2:14 am     Reply with quote
@ Ttelmah
Thanks for hint, I'll try in this afternoon.
I have to dig a bit more to understand all details.
@Mike Walne
I use the following setup:
- PIC 18F4550 , 20MHz quartz, serial communication with PC
- CCS V4.114 (I used MPLAB as IDE)
Sorry for inconvenience by posting on this thread.
