andys
| rs232 software |
Posted: Mon Nov 05, 2012 5:17 pm |
I would like to connect a pic microcontroller via rs232 to pc.
I need to ask if i need any other software (for the pc ) . (i don't mean the pic programming) |
newguy
Posted: Mon Nov 05, 2012 5:44 pm |
| If you simply need a terminal program for debugging, then the "SIOW" program bundled with the CCS compiler works well. If you don't have the windows version of the compiler (SIOW is bundled with it, I believe), then "realterm" (google it) is very good. |
andys
| rs232 software |
Posted: Fri Nov 30, 2012 12:28 pm |
I used "realterm"with a MAX232IN component and the following code but something is wrong. I can not see any character to my screen.
The code which I used is:
#include <33fj128mc802.h>
#fuses HS
#fuses NOWDT
#fuses NOPROTECT
#use delay (clock=20000000)
#use rs232(baud=9600, xmit=PIN_B14,rcv=PIN_B15)
void main(void) {
int i;
char buffer[10]={'0','1','2','3','4','5','6','7','8','9'};
putc('*');
output_low(PIN_A0);
output_low(PIN_A1);
output_high(PIN_A0);
output_high(PIN_A1);
for(i=0;i<=10;i++) {
putc(buffer[i]);
putc(13);
output_low(PIN_B0);
output_low(PIN_B1);
First of all my code is ok??
How can I use the realterm ?? (There are any setting which i have to change?) |
Posted: Fri Nov 30, 2012 12:51 pm |
I don't use the 33 series PICs but..some have programmable pin uses and there's a CCS C 'command' to tell the compiler which pin is used for what fuction. Others using that PIC will know
As for your program, I'd start with the simple example CCS gives of 'getting a character form PC and sending it back' AKA active loopback test.By keeping things simple, you'll get it working faster.
Also the simple '1Hz LED' program is a great start as well.it PROVES the PIC and your code is OK.
hth
jay |
gpsmikey
Posted: Fri Nov 30, 2012 1:08 pm |
Definitely second the "blinkey led" thing - not only tells you the PIC is alive, but lets you verify the clock is being set correctly (if the clock is wrong, the RS232 ain't gonna talk to the PC) - if you are setting the LED to blink at a 1hz rate and it isn't, the baud rate will be wrong also. I also like to use a spare pin if I have it to set it high going into an ISR then set it low just before exiting - lets me look at the pulse width on a scope and see just how much time the ISR is actually spending in the ISR.
mikey _________________ mikey
andys
| rs232 software |
Posted: Wed Dec 05, 2012 3:05 am |
I used max232 with putty and the code bellow.My problem is that, nothing appear at my screen. Is anyone who know what is going wrong?????
#fuses HS
#fuses NOWDT
#fuses NOPROTECT
#use rs232(baud=9600, xmit=PIN_B8,rcv=PIN_B9)
void main(void) {
int i;
putc('*');
output_low(PIN_A0);
output_low(PIN_A1);
putc(buffer[i]);
putc(13);
delay_ms(100000000);
output_low(PIN_A0);
output_low(PIN_A1);
Posted: Wed Dec 05, 2012 4:02 am |
First, have you followed Temtronic's suggestion about the 1Hz LED test.
At the moment you are like the person saying "I can't get my car to move", who is not responding to the question 'can you start the engine'.....
Then look at the first line of Temtronic's post. 'programmable pin uses'. Your PIC _does_ have relocatable pins, and these need to be setup. The syntax is:
#PIN_SELECT U1TX=PIN_B14
#PIN_SELECT U1RX=PIN_B15
#USE RS232(UART1,ERRORS,BAUD=9600)
//In place of your current RS232 line
However get the LED test going first. Nothing will work, till the chip _is_ running at the right speed.
andys
| rs232 software |
Posted: Wed Dec 05, 2012 6:55 am |
| Thanks guys for your answer but please can you make clear what do you mean by 1Hz LED test ???? |
ezflyr
Posted: Wed Dec 05, 2012 7:07 am |
Hi andys,
Please forgive my shock, but after 83 posts and 6 years on the forum,
you still seem surprisingly helpless .......
Connect an LED from one PIC I/O pin to GND thru a suitable current
limiting resistor, and load some code onto the PIC to flash the LED at a
predictable rate. This test will tell you two things: (1) your PIC is actually
executing code, and (2) the execution speed of the PIC is correct.
While(1) {
output_high(LED);
output_low(LED);
This simple test should be the FIRST thing that you do every time you
start a new PIC project!
Good Luck!
John |
Mike Walne
Posted: Wed Dec 05, 2012 7:55 am |
Did you really mean to include this in your code?
| Code: | | delay_ms(100000000); |
What did you think might happen?
Have you tested your PC's RS232?
Connecting the TX to the RX should cause any characters typed on your PC to appear on the screen. (Once per keystroke without echo, twice with.)
Like ezflyr says we should not be having this conversation.
Mike |
andys
| rs232 software |
Posted: Wed Dec 05, 2012 5:44 pm |
Dear ezflyr,
I know the following procedure
"Connect an LED from one PIC I/O pin to GND through a suitable current
executing code, and (2) the execution speed of the PIC is correct. "
With this procedure you can test if the PIC is actually
executing code but you need an oscillator to measure the execution speed of the PIC (correct me if i am wrong).
Furthermore i used the code bellow is anyone who can help me/suggest me what to do???
#fuses HS
#fuses NOWDT
#fuses NOPROTECT
putc('*');
puts("A");
puts("\n");
output_high(pin_A0);
output_low(pin_A0);
putc(13);
Posted: Wed Dec 05, 2012 7:39 pm |
With respect to the 1Hz test program, no test equipment is really necessary except for your eyeballs.
If the LED flashes at all, your PIC should be alive and well...
If it flashes about 1Hz, that's like 'one steamboat,two steamboat' in timing and that's good too.
This simple program will confirm that
1) the hardware you've constructed is good(layout,pinout,etc.)
2) the code you cut is good
3) the selection of 'fuses' is appropriate
4) that serial communications(aka RS232) should work as well.
5) that you've programmed the PIC in RELEASE mode and NOT DEBUG.
With respect to your code.
I don't use the 33 series however..general trouble shooting comments..
Are you using a real RS232 comport on your PC or a USB<>RS232 module.
Do you have a MAX232 or equal between your PIC and the PC?
Do you have PIC TX to PC RCV ?
Do you have a good ground between the two devices?
Is the PIC running on 3 or 5 volts?
Do you get anything on the PC at all?
Can you confirm, via a loopback(pin 2---pin3) that the PC software is running?
Note: if using a USB port, please note that a TTL<->USB adapter is NOT the same as an RS232<->USB adapter.
I know some points are obvious...but the more information you can supply, the better we can help.
hth
jay |
andys
| rs232 software |
Posted: Wed Dec 05, 2012 7:52 pm |
--> I used a real RS232
--> YES A MAX 232
--> Yes i used female port which include tx,rx,gnd
-->Yes i used the ground which is provided by the microkit 2 which i used
--> power supply 3.3V (provided by the microkit 2)
-->nothing
-->how to do this? |
Posted: Wed Dec 05, 2012 8:05 pm |
re loopback test.
Disconnect any wiring to the PIC setup...
Connect a wire between pin 2 of the PC comport DE-9 connector and pin 3.
This sends anything you type on the PC keyboard out pin 3(xmt) and then into the PC via pin 2(rcv) which will show up on the PC screen.
Just be sure whatever serial communications software you're using an NO flow control set! If this test fails..then either the software you're using is faulty,not setup correctly or a hardware issue.
I use Realterm and Hyperterminal for 'quick' testing.
hth
jay |
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Wed Dec 05, 2012 9:34 pm |
Just a note that if your power supply is 3.3V, then you should be using a MAX3232 (good for 3.3V) and not a MAX232 (good for 5V). _________________ Andrew |
