USB keyboard with 18f14k50
kurtzweber
PostPosted: Mon Oct 22, 2012 6:24 am     Reply with quote
Hello!
I'm working on a project with a 18f14k50 PIC. I need to implement a keyboard HID device and I'm working with the provided examples.
My first attempt is to simply send "Hello" string every 10sec, here's my code:
#include "PwdHID.h"
#include "PwdHID_desc.h"
#include <pic18_usb.h>
#include <usb_bootloader.h>
#include <usb.c>
#define KB_MODIFIER_LEFT_SHIFT 2
void main() {
   set_tris_c(0x00);
   output_low(LED_RED);
   output_low(LED_YELLOW);
   output_low(LED_GREEN);
   usb_init_cs();
   while(TRUE) {
      usb_task();
      if(usb_enumerated()) {
         output_high(LED_GREEN);
         sendChar('H');
         sendChar('e');
         sendChar('l');
         sendChar('l');
         sendChar('o');
         sendChar('\n');
         delay_ms(10000);
void sendChar(char c) {
   unsigned int8 tx_msg[7];
   unsigned int8 leds;
   unsigned int16 scancode;
   if (usb_tbe(1)) {
      memset(tx_msg, 0x00, sizeof(tx_msg));
      scancode = ToHidKeyboardScancode(c);
      if(bit_test(scancode, 8)) tx_msg[0] = KB_MODIFIER_LEFT_SHIFT;
      tx_msg[2] = scancode;
      usb_put_packet(1, tx_msg, sizeof(tx_msg), USB_DTS_TOGGLE);
   if(usb_kbhit(1)) usb_get_packet(1, &leds, 1);
unsigned int16 ToHidKeyboardScancode(char c)
   unsigned int16 shift = 0;
   if ((c>='A')&&(c<='Z'))
      c = tolower(c);
      shift = 0x100;
   if ((c>='a')&&(c<='z'))
      return(((c-='a')+4)|shift);
   if ((c>='1')&&(c<='9'))
      return((c-='0')+0x1D);
   switch(c)
      case '!':   return(0x11E);
      case '@':   return(0x11F);
      case '#':   return(0x120);
      case '$':   return(0x121);
      case '%':   return(0x122);
      case '^':   return(0x123);
      case '&':   return(0x124);
      case '*':   return(0x125);
      case '(':   return(0x126);
      case ')':   return(0x127);
      case '0':   return(0x27);
      case '\n':  return(0x28);  //enter
      case '\r':  return(0x28);  //enter
      case '\b':  return(0x2A);  //backspace
      case '\t':  return(0x2B);  //tab
      case ' ':   return(0x2C);  //space
      case '_':   return(0x12D);
      case '-':   return(0x2D);
      case '+':   return(0x12E);
      case '=':   return(0x2E);
      case '{':   return(0x12F);
      case '[':   return(0x2F);
      case '}':   return(0x130);
      case ']':   return(0x30);
      case '|':   return(0x131);
      case '\\':   return(0x31);
      case ':':   return(0x133);
      case ';':   return(0x33);
      case '"':   return(0x134);
      case '\'':   return(0x34);
      case '~':   return(0x135);
      case '`':   return(0x35);
      case '<':   return(0x136);
      case ',':   return(0x36);
      case '>':   return(0x137);
      case '.':   return(0x37);
      case '?':   return(0x138);
      case '/':   return(0x38);
When I run it, my PC correctly detect the new device but it starts to send only 'H':
Where am I wrong?
Thanks!
PostPosted: Mon Oct 22, 2012 7:08 am     Reply with quote
Several little things.
First, rethink having a 10 second delay in the main loop. Have a timer interrupt 'ticking' at some convenient interval, and use this to do a countdown. USB, may run into problems if you pause this long between calling the task handler.
Big one though is that the key needs to release. You are sending a packet for the first key being pressed, and it is never released. Hence the computer will see it continuously repeating. To send a character, you need to send a key (with the required modifiers), and then release the key.
kurtzweber
PostPosted: Mon Oct 22, 2012 8:32 am     Reply with quote
Thanks for your reply!
To release the key, I thought to send a message with all 0x00 but nothing changes:
// tx_msg[2:6] = an array of held down keys. a=4, b=5, etc.
// if msg[2:7]={0} then no keys are held down
void send_char(char c) {
   unsigned int8 leds;
   if (usb_tbe(1)) {
      // release key
kurtzweber
PostPosted: Mon Oct 22, 2012 9:36 am     Reply with quote
Hello!
I added a small delay (100ms) between the two "usb_put_packet" and now it sends the key, but just the first one ('H'), both using printf() or calling the sub manually... very strange!
I changed also the delay function:
#include "PwdHID.h"
#include <usb.c>
int1 time_expired = FALSE;
unsigned int8 timer0_count;
#int_timer0
void int_timer0_handler() {
   set_timer0(28036);
   timer0_count++;
   if(timer0_count == 100) {
      time_expired = TRUE;
      timer0_count = 0;
void main() {
   set_tris_c(0x00);
   setup_timer_0(T0_INTERNAL | T0_DIV_32);
   set_timer0(28036);
   usb_init_cs();
   while(TRUE) {
      usb_task();
         if(time_expired) {
            //printf(send_char, "Hello World!\n");
            send_char('H');
            send_char('e');
            send_char('l');
            send_char('l');
            send_char('o');
   unsigned int8 leds;
   if (usb_tbe(1)) {
      // release key
      c = tolower(c);
      shift = 0x100;
   switch(c)
thanks again!
kurtzweber
PostPosted: Mon Oct 22, 2012 11:32 am     Reply with quote
Ok solved Wink
you need a delay after each send... now I'm using 100ms but from the examples provided it seems you can use 10ms:
      // release key
egemenakbas
PostPosted: Wed Mar 10, 2021 9:56 am     Reply with quote
kurtzweber wrote:
Ok solved Wink
      // release key
Hi, can you share ccs c project files to me?
thanks
PostPosted: Thu Mar 11, 2021 12:50 am     Reply with quote
kurtzweber's last post was on Oct 22, 2012. That was many years ago.
Don't expect a reply.
egemenakbas
PostPosted: Thu Mar 11, 2021 2:27 am     Reply with quote
Hi, I noticed but wanted to take a chance Smile I need such a project. Thanks for the return.
PostPosted: Thu Mar 11, 2021 6:18 am     Reply with quote
You could take any PIC,add a TTL-USB module to do the same 'task'.
PostPosted: Thu Mar 11, 2021 7:38 am     Reply with quote
No, Jay. Most of these modules would be CDC devices, not HID devices.
He wants data as if it comes from a keyboard.
The original posted code sounds as if it was working with the changes
implemented, so it should only be a couple of seconds work to test it.
The reason he was having to add a delay, is a common 'misunderstanding' of
how key scan codes work. To actually simulate a key being typed, you have
to send the 'key scan code', and then a 'key released' code. By sending just
the scan code, the system instead waits for the key repeat interval, and
then 'sees' the key. Hence the delay being needed.
