UART buffer strange behavior
Requan
PostPosted: Fri Oct 19, 2012 6:35 am     Reply with quote
Dear CCS Member,
I wrote program on Host to communicate via modbus RTU, rs485 with sensors(PIC 18F67J60, CCS 4.134).
When during communication i disconnect and connect again sensor, sometimes ( i think when i connect during data transmission and host receive incomplete data) host receive data in wrong sequence from this moment up to forever, please look at:
Correct data:
01 03 1D 00 09 54 82 73 33 33 85 46 CC CD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 AA 55 6B
Receive by Host:
eg.1
6B 01 03 1D 00 09 54 82 73 33 33 85 46 CC CD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 AA 55
eg.2
00 00 00 00 00 00 00 00 00 00 00 00 00 02 AA 55 6B 00 01 03 1D 00 09 54 82 73 33 33 85 46 CC CD 00 00
The data are shifted.
my code:
int8 ModbusReceiveData(int8 SlaveID, int16 BytesQuantity, int32 TimeOutValue)
   int8 FunctionCode = 1;
   int8 index=0;
   BYTE temp_chr;
   int32 TimeOutCounter = 0;
   for(int i = 0; i < BytesQuantity; i++)
   Modbus.Buffer[i] = 0;
         while (TimeOutCounter < TimeOutValue)
            if (bkbhit)
               //Now have a character
               temp_chr = bgetc(); //get the character
               TimeOutCounter = 0;
               Modbus.Buffer[index]=temp_chr; //store the character
               if (index < BytesQuantity) ++index; //and update the counter
               if (index == BytesQuantity) //if i receive all data
                 //Modbus.Buffer[index] = '\0'; // end buffer
                  ModbusCalcCrc(BytesQuantity - 2);
                  if((Modbus.Buffer[index - 1] == Modbus.CRC_Hi) && (Modbus.Buffer[index - 2] == Modbus.CRC_Lo ))
                     index=0;
                     if((Modbus.Buffer[0]==SlaveID))// sprawdzam odebrany kod funkcji
                      FunctionCode =  Modbus.Buffer[1];
                        FunctionCode =  0;
                     FunctionCode = 0;
            TimeOutCounter++;
   clear_usart();
   return FunctionCode;
clear_usart:
void clear_usart(void)
   char c;
   while (kbhit()) c=getc();
UART:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,bits=8,parity=N,stop=1,stream = UART1)
#define BUFFER_SIZE 64
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   t=next_in;
   if(++next_in==BUFFER_SIZE)
      next_in=0;
   if(next_in==next_out) //get rid of the ';' here - wrong.....
      next_in=t;    // Buffer full !!
BYTE bgetc()
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
It seems that buffer is not clear, i add clear function but it didn't help.
What else i have to do to clear buffer?
Best Regards,
Martin
asmallri
PostPosted: Fri Oct 19, 2012 6:38 am     Reply with quote
I am guessing your RS485 bus is not correctly terminated.
Regards, Andrew
Requan
PostPosted: Fri Oct 19, 2012 6:48 am     Reply with quote
Arrow asmallri
Thanks for reply.
I have resistor 120 Ohm on both side.
I tested on very short cable and behaviour is the same.
PostPosted: Fri Oct 19, 2012 8:14 am     Reply with quote
You have to be careful with RS485. Depending on the buffer chips you use, some are certified to give a 'idle' (high) output, when the bus is undriven. Others _require_ you to apply a tiny bias voltage to the bus as part of your termination, to ensure that when the bus is not driven, devices see this output. Without this, an undriven bus can float to the active state, and what you then receive is dependant on luck....
PostPosted: Fri Oct 19, 2012 11:42 am     Reply with quote
You should always add 'errors' to the use rs232(......) options as well when using the hardware UART.
hth
jay
Requan
PostPosted: Fri Oct 19, 2012 12:29 pm     Reply with quote
Thanks for answers.
Arrow Ttelmah
What do You advice to for me to do?
Arrow temtronic
You right i forget about it, but i have to admit that i don't understand how it works.
I have to add this option only or something else?
asmboy
PostPosted: Fri Oct 19, 2012 2:30 pm     Reply with quote
 while(!bkbhit) ;
should be EXTERNAL to the Bgetc function
NOT inside it !!!!
then use it like this :
    if (bkbhit) yourBYTE_var=bgetc();
PostPosted: Fri Oct 19, 2012 2:34 pm     Reply with quote
On bias, search the web. Texas do a very good note about it.
Search for "RS485 bus bias".
PostPosted: Fri Oct 19, 2012 2:37 pm     Reply with quote
should be EXTERNAL
That code is right out of Ex_sisr.c:
c:\program files\picc\examples\ex_sisr.c
PostPosted: Fri Oct 19, 2012 2:40 pm     Reply with quote
It is one of those 'understand what you and CCS are doing' things.
The bkbhit test needs to be inside bgetc, _in case_ somebody calls it _without_ first checking if data is available. It should be there, _but_ if you don't want to hang if data is not available, the programmer should also test before calling....
asmboy
PostPosted: Fri Oct 19, 2012 6:27 pm     Reply with quote
OH i get it - this was done for consistency -
to make bgetc() work logically the same as getc() right ??
I never knew getc() had an included kbhit inside it before.
i learn something useful every day on this forum.
Very Happy Very Happy Very Happy
Requan
PostPosted: Sun Oct 21, 2012 4:51 am     Reply with quote
I wonder one thing. When i had problem with data i connected PC via rs485/rs232 interface to the 485 bus. Data on bus were ok but PIC received in wrong seguence.
2 years ago i wrote similar program in "Proton PIC Basic" and it was ok.
PostPosted: Sun Oct 21, 2012 7:57 am     Reply with quote
That was something wrong with your code/hardware I'm afraid. The compiler does nothing to the byte order....
When you 'connected the PC to the bus', what you see, is dependant on the behaviour of the buffers used in the PC interface, so if they happen tobe ones that do accept an undriven bus as giving an 'idle' output, the result may well differ from what the PIC sees.
Also, unless the bus buffers used on yor PIC basic example, were the same as the ones you are now using, the sane applies here.
Requan
PostPosted: Sun Oct 21, 2012 10:30 am     Reply with quote
There is something strange more (maybe it helps to find solution):
during "wrong transmission" when is change 485 address in receiver (I have dip-switch on board) and host send query with no reply and next I return to proper address - from now all work fine.
I tried to manually reset many things: buffer, index, variables but nothing helps.
Could you tell me how to reset transmission, maybe reset interrupt?
