lindoudaM2
| signal phase dimmer code |
Posted: Wed Oct 10, 2012 3:56 pm |
My code works well in ISIS simulation but in reality-show it's not same. I want to control dimming light with a triac.
Someone help me please to correct my code.
#include <16F877A.h>
#fuses XT, NOWDT, NOPROTECT, PUT, NOLVP
byte x;
void init ()
setup_adc_ports(RA0_ANALOG);
setup_adc(adc_clock_div_2);
set_adc_Channel(0);
setup_ccp1(ccp_pwm) ;
setup_timer_2 (T2_Div_by_1,255,1);
setup_timer_1(T1_internal);
SET_TRIS_B(0xFD);
#int_ext
void ext_isr()
if(input (pin_B0) )
ext_int_edge(H_to_L);
init();
while (1)
enable_interrupts(INT_EXT);
delay_ms (10);
x=read_adc();
set_pwm1_Duty(x);
delay_ms (10);
disable_interrupts(INT_EXT);
Clear_interrupt(INT_EXT);
Gabriel
Posted: Wed Oct 10, 2012 4:14 pm |
why not use RB int instead of Ext int?
it trigger on change... so you dont have to change the direction of the trigger signal....
I would also move these:
| Code: | enable_interrupts(INT_EXT);
enable_interrupts(GLOBAL); |
out of the while loop and reverse the order...
| Code: | enable_interrupts(GLOBAL);
enable_interrupts(INT_EXT); |
i believe... that once the ISR triggers it automaticaly clears the interrupt flag... so you dont have to doit manually....
your crystal fuse is XT... yet you are declaring a 20MHz clock...
Try HS better...
just my 2 cents..
G _________________ CCS PCM 5.078 & CCS PCH 5.093 |
lindoudaM2
Posted: Wed Oct 10, 2012 4:27 pm |
| I don't understand what you mean by that, not use RB int is that i did wrong (int_ext). |
Mike Walne
Posted: Wed Oct 10, 2012 4:44 pm |
| Quote: | | My code works well in ISIS simulation but in reality-show it's not same. I want to control dimming light with a triac. |
Three things.
1) Forget ISIS. It's so full of bugs you're wasting your time and ours.
2) Describe your hardware, or show us a schematic.
3) Tell us what's happening that's not what you expect.
Mike |
lindoudaM2
Posted: Wed Oct 10, 2012 5:13 pm |
| Mike Walne wrote: | | Quote: | | My code works well in ISIS simulation but in reality-show it's not same. I want to control dimming light with a triac. |
Three things.
Mike |
I am trying to conceive a single-phase triac dimmer controlled by the PIC 16F877A. My problem is at the level of the load (lamp) there are no variation of brightness despite the PWM signal varies appropriately. |
Posted: Thu Oct 11, 2012 12:51 am |
First of all, don't start a new thread for the same project every time. This is already your 4th thread for this dimmer project.
Keeping it all together makes it easier for everyone to see what has already been discussed.
| Quote: | | I am trying to conceive a single-phase triac dimmer controlled by the PIC 16F877A. My problem is at the level of the load (lamp) there are no variation of brightness despite the PWM signal varies appropriately. | I think you made a major design flaw. A triac is not to be connected to a PWM output. PWM will generate a lot of trigger pulses but, by it's nature, the triac will stay enabled once it is triggered till the current flowing through it drops to zero. So, after the first PWM pulse, the triac will enable and then nothing changes until the next mains line zero crossing.
I suggest you do some more reading into the subject. Microchip has some really nice Application Notes on their website for this. |
Mike Walne
Posted: Thu Oct 11, 2012 8:25 am |
Like ckielstra says, you need to think about how you're going to trigger the triac.
So far you've not shown us anything about your hardware.
When your hardware is sorted, the triac part of the software goes:-
1) Wait for zero crossing.
2) Wait for a time set by ADC output (0 - 10ms for UK mains).
3) Trigger triac.
4) Loop back to 1, assuming triac will turn off close to next zero crossing.
Mike |
gpsmikey
Posted: Thu Oct 11, 2012 2:37 pm |
All of this is assuming we are talking a resistive (tungsten) light or something similar for dimming. If it is an inductive (fluorescent or something else), then it opens a whole new can of worms. Usually in this kind of project, it is a resistive load, but every now and then, after many posts, the OP happens to mention the fact it is an inductive load or something else.
mikey _________________ mikey
Posted: Fri Oct 12, 2012 10:11 am |
1- PWM is NOT the way to trigger a triac
2- you need to sense each zero crossing of the AC power waveform
and trigger at an appropriate phase angle offset from zero - to get phase control
3-study triac phase control , then design a circuit and ONLY THEN create your control code. |
Posted: Fri Oct 12, 2012 12:21 pm |
Also you need to look at some real AC waveform.
Real mains, especially when triacs are involved anywhere nearby, does not resemble a sinusoid at all closely. This is a typical example of where Proteus will give very erroneous results.
This is why there are quite complex IC;s around to make zero crossing detectors, since it is not a simple thing to do...
lindoudaM2
Posted: Fri Oct 12, 2012 4:19 pm |
Hello
I ameliorated my code and here is it
wish that everything will be fixed
#include<16F877A.h>
#use delay (clock =20000000)
#fuses HS,NOWDT, NOPROTECT, PUT, NOLVP
byte x;
void init ()
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_2);
Set_adc_channel(0);
setup_CCP1(CCP_PWM);
set_tris_b(0xFE);
#int_ext
void ext_isr()
if (input(pin_B0))
init();
while (1)
delay_ms (10);
x=read_adc();
set_pwm1_Duty(x);
clear_interrupt(INT_EXT);
delay_ms(10);
gpsmikey
Posted: Fri Oct 12, 2012 6:59 pm |
"ameliorated" - good grief - i'd never heard that word before so had to look it up. Obviously others have not heard of it before either - they claim "Ameliorate is currently in the top 1% of lookups and is the 104th most popular word on Merriam-Webster.com." - my learning for today is complete - time to relax :-)
Mike Walne
Posted: Sat Oct 13, 2012 3:41 am |
| Quote: | I ameliorated my code and here is it
wish that everything will be fixed |
So, does it now work?
Mike |
Posted: Sat Oct 13, 2012 7:31 am |
| Mike Walne wrote: | | Quote: | I ameliorated my code and here is it
Mike | I guess not because his interrupt is doing nothing, he is not using any synchronization to the AC waveform and the PWM output that was discouraged is still there...
I don't mind to help, but what is the question? |
Posted: Sat Oct 13, 2012 9:09 am |
I'd be very hesitant to use the word ameliorated, since it implies 'better'.
It's like posting saying "I've fixed my code, but it still doesn't work". One part or the other of the statement is untrue....
