Standard C function for strings
Lemosek
PostPosted: Sat Oct 06, 2012 5:37 am     Reply with quote
I have small problem. I want compare two string and i find strncasecmp function, but in CCS is only strncmp. This function recognize big and small symbols, like A is not a. In my program I don't need this.
For me "aaa" must be egual with "AAA".
How I can do this ??
Best regards
R.L.
gpsmikey
PostPosted: Sat Oct 06, 2012 9:20 am     Reply with quote
Does stricmp(s1,s2) not do what you want ? - see the "standard string functions" section in the user manual for what is available.
mikey
mikey
Lemosek
PostPosted: Sat Oct 06, 2012 9:49 am     Reply with quote
Thank You for reply.
Yes this function doing this but for all string. In function strncmp I have third parameter s3 - number of characters from each string to be used in the comparison.
Best regards
R.L.
PostPosted: Sat Oct 06, 2012 2:32 pm     Reply with quote
just write it.
int strncmpn(char* s1, char* s2, int n) {
   if (n==0) return 0;
   while (n-- != 0 && tolower(*s1) == tolower(*s2)) {
      if (n == 0 || *s1 == '\0' || *s2 == '\0')
      s1++;
      s2++;
    return tolower(*(unsigned char *) s1) - tolower(*(unsigned char *) s2);
There is nothing magical about any of the functions. strncasecmp, is a non standard function that was included in quite a few unix/linux distributions, but because it was _not_ part of C, the source was included as well in the include library.
Lemosek
PostPosted: Sun Oct 07, 2012 11:50 am     Reply with quote
Thank You very much, this is exactly what I need Smile.
best regards
R.L.
