Sounds and Melodys 16F887
benni
PostPosted: Wed Sep 19, 2012 10:32 am     Reply with quote
I want ask if someone knows the chords for the Tetris melody in the example of: EX_TONES.c
OR
is there is a way to write a .wav file in the PIC?
Thanks for the Help
Regards Benni
PostPosted: Wed Sep 19, 2012 12:19 pm     Reply with quote
How well versed are you in PCM format wave file playback?
Do you expect the 887 to have the required HARDWARE?
What is the purpose of this question?
Darren Rook
Re: Sounds and Melodys 16F887
PostPosted: Wed Sep 19, 2012 3:54 pm     Reply with quote
benni wrote:
OR
Thanks for the Help
Regards Benni
LOL.
ex_tones.c / tones.c takes frequency. Therefore -
Get sheet music here:
http://www.gamemusicthemes.com/pdf/GameBoy/Tetris_-_Theme_A.pdf
Convert note to frequency here:
http://www.phy.mtu.edu/~suits/notefreqs.html
Please post youtube of this working when done.
I came, I saw, I compiled.
benni
PostPosted: Thu Sep 20, 2012 10:19 am     Reply with quote
Hey,
Does someone knows to read notes and could translate this to me please?
Regards Benni
PostPosted: Thu Sep 20, 2012 12:09 pm     Reply with quote
google
READ MUSIC notation
and also
MUSIC NOTE FREQUENCY
this is web research 101
benni
PostPosted: Thu Sep 20, 2012 12:46 pm     Reply with quote
I already googled -.-
I just don't find the notes that are in the pdf file of the Tetris theme...
PostPosted: Thu Sep 20, 2012 12:49 pm     Reply with quote
i think you must agree that :
is not a CCS problem
rald
PostPosted: Sat Mar 14, 2015 6:11 pm     Reply with quote
hello
I have been trying to create a very simple laser sound saved into the internal eeprom of a pic 12F683, I have read the documents about tones but I have not idea about how to create those sounds.
does anyone know how can I convert a wav file or create this kind of sounds for microcontroller?
thanks
PostPosted: Sun Mar 15, 2015 2:25 am     Reply with quote
For basic tunes, the 'simple' way is to start with a piece of music.
Look for things written to be played on monotonic instruments (like a xylophone etc.).
Take this, and work out the names of each note. Then put these into ex_tones.
.wav files are direct bitstreams. You don't have the storage size, or the hardware to handle these on a PIC, without a lot of work. Potentially it would be possible on one of the larger PIC's (PIC24 for example), to read such a file from an SD card (it'd get hard to handle all the possible variants, since .wav can contain streams that loop, streams at different sample rates, or even streams that are compressed), but the standard LPCM stream would be relatively 'doable', and this could then be output using a DAC at the constant rate (normally 44.1KHz). However this is a fairly 'large' project.
One system that is much easier to code in the PIC, is 'midi'. This is a serial interface at a relatively low data rate, which in it's simplest form has messages like 'note on', and the tone/emphasis data for the note. It is possible to generate a controller to receive this data relatively easily with a PIC. There are programs on the web, that will convert .wav files to midi streams (understand you lose 90% of the data in the wav file, and end up with a sequence of midi commands to play the basic tune). The output these produce can then be played by a PIC. Some years ago, I wrote a crude 'organ' using a PIC this way, and hardware has got much more capable since this time.
drh
PostPosted: Sun Mar 15, 2015 7:55 am     Reply with quote
Start here..http://www.romanblack.com/picsound.htm
Good luck.
David
rald
PostPosted: Sun Mar 15, 2015 12:18 pm     Reply with quote
Hi guys,
thanks for respond,
about the romanblack program, I used it but I can not undestand how to use the files. do you have any example that I can use to get an idea?
I am going to research about MIDI and see if I can find some solution.
regreats
necati
PostPosted: Mon Mar 16, 2015 12:19 am     Reply with quote
http://larios.tecnologia.ws/iBlog/archives/6632
balboa
how to use it
PostPosted: Fri Mar 27, 2015 1:16 pm     Reply with quote
Good luck.
would you please tell us how to use the exported file
PostPosted: Fri Mar 27, 2015 1:48 pm     Reply with quote
pretty simple
export the sound file as either a PIC .asm file or a MikroC .c file
It's up to you to convert the data into CCS C compatible format. real easy if you know how to use edit features in windows...
Save as filename.pcs ( Pic C Sound file extention) or whatever you want.
Depending on how big your PIC is and the soundfile, you have a couple options.
1) if saved on a flashdrive, simply cut code to read the data and send to an I/O pin with R-C filter as shown in the documentation
2) if small enough to be contained in the PIC codespace,save as const data.
either way will work. I did it for the 16F877 about 10 years ago as it was a bit easier than using a PC ISA sound card...
cheers
Jay
balboa
thank you for help
PostPosted: Sat Mar 28, 2015 12:41 pm     Reply with quote
temtronic wrote:
pretty simple
cheers
Jay
