itol("100000") = 34464...... Why?
williankleber
PostPosted: Mon Sep 17, 2012 2:21 pm     Reply with quote
      int16 k;
      char u[] = "100000";
      k = atol(u);
At the end of this code, the variable "K" takes the value 34464.
I'm using PICC PCW and the PIC is 18F4520.
I will use this algorithm to convert one string with binary sequence, in a binary type.
I thank all for the attention Very Happy
bkamen
PostPosted: Mon Sep 17, 2012 2:25 pm     Reply with quote
What's the largest number an int16 can hold?
and answer that question for unsigned and signed.
-Ben
williankleber
PostPosted: Mon Sep 17, 2012 2:34 pm     Reply with quote
I changed my code to
   while (1){
      unsigned int32 k;
      printf(lcd_putc,"\fu = %s",u);
      delay_ms(2000);
      k = atol(u);
      printf(lcd_putc,"\fk = %lu",k);
      delay_ms(2000);
and the problem continues,
The number 100000 should fit into a INT32 variable. Does this has to do with processing of 16bit PIC?
bkamen
PostPosted: Mon Sep 17, 2012 2:41 pm     Reply with quote
   while (1){
      unsigned int32 k;
      delay_ms(2000);
      k = atol(u);
      delay_ms(2000);
The PIC18's are 8bit CPUs (just so you know) and being 16 or 32 bits doesn't matter as the compiler does the work for that. I do 16/32bit math all the time on PIC18's.
So at this point, you should post a small compilable example (and your compiler version) as the second sticky-post to this forum describes.
Also, you're not using Proteus, are you?
-Ben
bkamen
PostPosted: Mon Sep 17, 2012 2:53 pm     Reply with quote
Better yet -- look at the CCS manual (.CHM) again for atol
And look closely at the other items listed on the same help page.
-Ben
williankleber
PostPosted: Mon Sep 17, 2012 2:56 pm     Reply with quote
This is my code:
#include <18F4520.h>
#include <stdio.h>
#include <stdlib.h>
#include "lcd.c"
#include <math.h>
void main(){
   while (1){
      unsigned int32 k;
      delay_ms(2000);
      k = atol(u);
      delay_ms(2000);
My compiler version is 4.074
And really, I'm using proteus for simulation. Does that is causing the problem?
I'll mount the circuit on a board, soon put the result.
Thank you very much bkamen, is helping me a lot...
bkamen
PostPosted: Mon Sep 17, 2012 3:10 pm     Reply with quote
This is my code:
In this case, Proteus is not the problem. Look at the CCS PICC compiler manual again.
Just keep in mind that in the future -- Proteus can be a problem in general for emulating PIC code. There's enough features in a PIC that proteus incorrectly emulates nullifying using proteus at all.
Cheers,
-Ben
FvM
PostPosted: Mon Sep 17, 2012 3:11 pm     Reply with quote
This is my code
You still didn't change your code to use atoi32()...
bkamen
PostPosted: Mon Sep 17, 2012 5:13 pm     Reply with quote
FvM wrote:
This is my code
Boooo! I told him that! (via "look at the manual") hahaha...
Razz
williankleber
Fixed...
PostPosted: Tue Sep 18, 2012 7:57 am     Reply with quote
solved using atoi32()...
Follow the hint of bkamen, and found all the documentation in the HELP Files of PICC.
Posted: Mon Sep 17, 2012 6:11 pm Post subject:
This is my code
Sorry FvM and bkamen, I posted the same instant that the bkamen, for this reason the code had not yet been changed...
anyway, thanks to all for help.
