shenba
PIC12F510-LIGHT UP |
Posted: Sat Sep 15, 2012 3:41 am |
HI.... i am new for PIC12F510 microcontroller.i tried to light up a LED.there is no error in my coding.but led is not glowing.
This is my coding
#include <12F510.h>
#fuses INTRC,NOWDT,MCLR,PROTECT
#use delay(clock=8000000)
#use fast_io(B)
void port_init(void);
void led_on(void);
void led_off(void);
port_init();
led_on();
delay_ms(1500);
led_off();
delay_ms(1500);
SET_TRIS_B(0b11111101);
OUTPUT_B(0x00);
void led_on(void)
OUTPUT_HIGH(PIN_B1);
void led_off(void)
OUTPUT_LOW(PIN_B1);
Thanks............. |
Posted: Sat Sep 15, 2012 5:17 am |
1) Use the code buttons.
2) 80% of your code is not needed. You can get the same effect with:
#include <12F510.h>
#define LED PIN_B1
void main(void) {
while(TRUE) {
output_high(LED);
delay_ms(1500);
output_low(LED);
delay_ms(1500);
CCS will handle the TRIS for you.
There are two other things that do have to be done though:
1) Turn off the comparator.
2) Turn off the ADC,
Both of these can potentially disable the output on this pin.
One other thing that could cause problems, is not a large enough current limiting resistor feeding the LED. This could result in the PIC overloading, and then resetting. This can be so fast that you would not see it.
Other thing obvious, is that you need a pull-up on the MCLR pin.
Joined: 01 Jul 2010 Posts: 9110 Location: Greensville,Ontario
Posted: Sat Sep 15, 2012 5:55 am |
also..
the LED has to be wired up correctly...quick way to test, take the resistor lead that goes to the PIC I/O pin (B1) and put onto Vcc(+5V) and the LED should light.
yes, simple ,..but some LEDs are hard to figure out anode/cathode connections.
hth
jay |
Mike Walne
Posted: Sat Sep 15, 2012 10:17 am |
Quote: | the LED has to be wired up correctly...quick way to test, take the resistor lead that goes to the PIC I/O pin (B1) and put onto Vcc(+5V) and the LED should light. | Depends on which way LED is wired. May need to connect to 0V Gnd. Idea is right, one way should work, no damage done if you make wrong connection.
Mike |
