communication between CCS uart and C18 usart
yalcinelmas
PostPosted: Thu Sep 13, 2012 2:00 pm     Reply with quote
Hi, I have a question. I spend lot of time. There is a receiver circuit and code developed with CCS.
And there is a transmitter circuit and code developed with C18. I want to communicate these circuit serially. I wrote the CCS and C18 code below. Can anyone help me ?
C18 sender code :
#include<p18f4685.h>
#include <stdlib.h>
#include <string.h>
#include <usart.h>
#pragma config OSC=HSPLL, WDT=OFF, MCLRE=ON, PBADEN=OFF, LVP=OFF
#define LED_TRIS      (TRISAbits.TRISA0)
#define LED_IO         (LATAbits.LATA0)
char SYNC[]={0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0x01,0XFE};
char veri[]="Bu bir denemedir.";
char sayi[10];
void dizigonder(char * veri , int uzunluk)
    int i;
    for(i=0;i<uzunluk;i++)
        while(BusyUSART());
            putcUSART(veri[i]);
    int n=0;
    long int i;
    LED_TRIS=0;
    OpenUSART( USART_TX_INT_OFF & USART_RX_INT_ON & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, 2082);
    TXSTA = 0x20;
    RCSTA = 0x90;
    BAUDCONbits.BRG16=1;
        while(BusyUSART());
            WriteUSART('vexxx\r');
        //putcUSART('veseeds\r\n');
        LED_IO ^= 1;
        Delay10KTCYx(100);
        /*while(BusyUSART());
            WriteUSART('0');
        LED_IO ^= 1;
        Delay10KTCYx(100);
CCS receiver code:
#include <18F4685.h>     // Kullanılacak denetleyicinin başlık dosyası tanıtılıyor.
#fuses HS,NOWDT
#use delay (clock=40000000)
#use rs232 (baud=1200,xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, stop=1)
char kk[20];
void main ( )
      gets(kk);
      if(kk[0]=='v' && kk[1]=='e')
         output_high(pin_a0);
         output_low(pin_a0);
         printf("ok\r");
PostPosted: Thu Sep 13, 2012 2:15 pm     Reply with quote
Well, you have only posted the CCS code, and called it the C18 code. However comments apply:
1) Your #use RS232 _must_ have 'ERRORS'. This _must_ be present when using the hardware UART, unless you handle hardware errors yourself. Otherwise the UART can become hung.
2) Your C18 code, must terminate what it sends with a line feed.
3) Your C18 code, must pause for at least 0.2 seconds between sending lines.
4) Your transmitted string must be <19 characters long.
5) Your oscillator setup is wrong. HS supports a maximum crystal frequency of 25MHz. Table 27-6, section 1A of the data sheet.
yalcinelmas
thanks for answer
PostPosted: Thu Sep 13, 2012 2:24 pm     Reply with quote
I updated my message.
Do you have a comment based on this situation?
Thanks for help ?
By the way I used 25 MHz crystal
PostPosted: Thu Sep 13, 2012 2:47 pm     Reply with quote
1, 3, & 5 apply. You are sending two characters, receiving all the incoming characters, plus pausing for 200mSec on the CCS PIC. On the C18 end, there are not the extra two characters involved, so it _will_ be looping faster. Your receiving device needs to loop faster than your sending device.
yalcinelmas
I could not it :(
PostPosted: Thu Sep 13, 2012 2:58 pm     Reply with quote
I writed below but it is not working... where is incorrect
  while(BusyUSART());
            WriteUSART('v\r');
        LED_IO ^= 1;
        Delay10KTCYx(200);
            WriteUSART('0');
        LED_IO ^= 1;
        Delay10KTCYx(200);
ezflyr
PostPosted: Thu Sep 13, 2012 8:35 pm     Reply with quote
That's C18 code, and this isn't a C18 forum.
John
