gets function for receiving uart data doesn't work
nehallove
PostPosted: Tue Sep 11, 2012 1:44 pm     Reply with quote
I am using PIC16f1937 and I am using UART. getc() and putc() works. But gets(string) doesn't work.
void main(){
   char string[30];
   setup_oscillator(OSC_16MHZ);
   while(1){
         gets(string);
         puts(string);
nehal
PostPosted: Tue Sep 11, 2012 2:09 pm     Reply with quote
Big difference is you need to send a line feed before gets will return.
PostPosted: Tue Sep 11, 2012 2:35 pm     Reply with quote
also add 'errors' to the use rs232(...) statement to avoid UART 'lockup'.
PostPosted: Tue Sep 11, 2012 5:11 pm     Reply with quote
Let me politely add, that i never have used gets() as it makes it too easy to hang the program.
The ONLY TWO receive functions i ever use on the USART are:
KBHIT, and when it is TRUE.
mybyte=getc();
and follow that -- process and loop while KBHIT stays true.
I build a string buffer as i go, ignoring ASC 10 and replacing ASC 13 with ASC 0 in the recovered string data.
By putting a KBHIT, conditional block in main() - you can run other processes instead of stall on the 'deadwait' that the pitiful (and really useless) GETS() imposes.
Douglas Kennedy
PostPosted: Tue Sep 11, 2012 6:58 pm     Reply with quote
Many fail to recognize that rs232 is asynchronous...yes it is never ever synchronized to your code unless you use flow control or if you have a very short isr linked to the RDA interrupt. Never never put delay_xx or puts or printf into an isr and expect a pleasant result.
The code below might work sometimes and sometimes not. The reason is while the puts is sending data the gets is blocked. If you are typing at a keyboard and stop to view the puts data before typing the next line you have created human flow control and it has a good chance of working. Otherwise just hope it's your lucky day.
   gets(string);
   puts(string);
nehallove
PostPosted: Mon Sep 17, 2012 5:50 pm     Reply with quote
Thank you guys.
nehal
