wireless module with PIC16F88
Chapre
PostPosted: Thu Aug 23, 2012 6:16 am     Reply with quote
Hi;
can you please recommend me a low cost wireless module (RF, Bluetooth, ...) to use with PICF88; I would like to design a wireless communication system between two PICS; distance ranging from 2 to 10 meters.
gpsmikey
PostPosted: Thu Aug 23, 2012 10:08 am     Reply with quote
Well, there are a number of options - part of "designing" a system means you need to get a better handle on the requirements than what you posted. What is the environment like (noise wise), what data rate (and how much data) needs to be transferred? Does it need to be secure ? Zigbee is an option, Bluetooth is an option, IR or even ultrasonic is an option (which could work underwater). These issues need to be addressed before you can start the "design" portion of your assignment.
mikey
mikey
Chapre
PostPosted: Thu Aug 23, 2012 11:09 am     Reply with quote
Well I'll be sending char characters only; I might also write my own protocol; no security needed; as for the data rate any is applicable as long as I can send and receive data; I'm still in experimentation stage; I have never used wireless communication with PICS, just to get me started somewhere.
gpsmikey
PostPosted: Thu Aug 23, 2012 12:31 pm     Reply with quote
You might want to check out the "wireless buying guide" over at sparkfun - http://www.sparkfun.com/tutorials/128 - there is a bunch of good information there comparing the various flavors (although they skip the IR or ultrasonic ones). Most of the modules simply drop in and you talk to them with a serial port (don't forget when you configure the RS232 port to include "ERRORS" or your program will hang if any error occurs - see the "#USE RS232" compiler directive in the CCS manual for details)
mikey
mikey
PostPosted: Thu Aug 23, 2012 2:11 pm     Reply with quote
also...
to aid in debugging....
design and build your PICs and code ,then test WITHOUT the wireless modules...
simply connect xmt1---rcv2, rcv1---xmt2 ,gnd1---gnd2
that way you will eliminate ANY 'funny' problems that wireless modules can cause you to lose hair over !!
I know sounds 'silly', but if you get it working without the wireless modules you'll be lightyears ahead..as there's always 'some' quirk buried on page 47 that nobody ever reads about...
hth
jay
