24FJ..Buffered RS232 still not working - any help please
micro_debugger
PostPosted: Tue Aug 21, 2012 4:23 pm     Reply with quote
I have started to write a simple program for buffered RS232 communication on the 24FJ64GB106. The non buffered procedure is working well, however the buffered routines are not working. Could you please make a short lookup and suggest me where I'm wrong. Thank you in advance,
Best Regards
#include <24FJ64GB106.h>
//#device ICD=TRUE
#build(stack=512)
#fuses HS,NOWDT,PR
#use delay(clock=12000000,RESTART_WDT)
#pin_select U1TX = PIN_B6
#pin_select U1RX = PIN_B7
#use rs232(UART1,baud=9600,parity=N,bits=8, STREAM=RADIO)
#pin_select U2TX = PIN_G6
#pin_select U2RX = PIN_G7
#use rs232(UART2,baud=9600,parity=N,bits=8, STREAM=RS232)
// defined crystal is 12 Mhz fro the following calculated RTC timmer interrupt
#define    RTCC_TIME_20_ms            35405             //20ms
#define    RTCC_TIME_10_ms            50470             //10ms
#define    RTCC_TIME_5_ms             58003             //5ms
#define    RTCC_TIME_2_5ms            61769             //2.5ms
#define    RTCC_TIME_2ms              62523             //2ms
#define    TX_RADIO_BUFFER_SIZE       192
volatile unsigned int8                tx_radio_buffer[TX_RADIO_BUFFER_SIZE];
volatile unsigned int8                tx_radio_next_in;
volatile unsigned int8                tx_radio_next_out;
#define    TX_RS232_BUFFER_SIZE       192
volatile unsigned int8                tx_rs232_buffer[TX_RS232_BUFFER_SIZE];
volatile unsigned int8                tx_rs232_next_in;
volatile unsigned int8                tx_rs232_next_out;
#define    RX_RADIO_BUFFER_SIZE       192
volatile unsigned int8                rx_radio_buffer[RX_RADIO_BUFFER_SIZE];
volatile unsigned int8                rx_radio_next_in;
volatile unsigned int8                rx_radio_next_out;
#define    bkbhit_radio               (rx_radio_next_in != rx_radio_next_out)
#define    RX_RS232_BUFFER_SIZE       192
volatile unsigned int8                rx_rs232_buffer[RX_RS232_BUFFER_SIZE];
volatile unsigned int8                rx_rs232_next_in;
volatile unsigned int8                rx_rs232_next_out;
#define    bkbhit_rs232               (rx_rs232_next_in != rx_rs232_next_out)
void LED_SYNC_ON(void)
      output_high(PIN_E0);
void LED_SYNC_OFF(void)
      output_low(PIN_E0);
/////////////// RADIO SERIAL PORT HANDLER START ///////////////////////
#int_TBE
void TBE_isr(void)
   if(tx_radio_next_in!=tx_radio_next_out)
      putc(tx_radio_buffer[tx_radio_next_out], RADIO);
      tx_radio_next_out=(tx_radio_next_out+1) % TX_RADIO_BUFFER_SIZE;
      disable_interrupts(int_tbe);
void bputc_radio(unsigned char c)
short restart;
int ni;
   restart=tx_radio_next_in==tx_radio_next_out;
   tx_radio_buffer[tx_radio_next_in]=c;
   ni=(tx_radio_next_in+1) % TX_RADIO_BUFFER_SIZE;
   while(ni==tx_radio_next_out);
   tx_radio_next_in=ni;
   if(restart)
      enable_interrupts(int_tbe);
#INT_RDA
void RDA_isr()
unsigned int8 t;
   rx_radio_buffer[rx_radio_next_in] = fgetc(RADIO);
   t = rx_radio_next_in;
   rx_radio_next_in = (rx_radio_next_in+1) % RX_RADIO_BUFFER_SIZE;
   if(rx_radio_next_in == rx_radio_next_out)
      rx_radio_next_in=t;        // Buffer full !!
int8 bgetc_radio()
unsigned int8 c;
unsigned int8 timeout;
   while(!bkbhit_radio && ++timeout<=10)
      delay_ms(10);
   c = rx_radio_buffer[rx_radio_next_out];
   rx_radio_next_out = (rx_radio_next_out+1) % RX_RADIO_BUFFER_SIZE;
   return c;
/////////////// RADIO SERIAL PORT HANDLER STOP ///////////////////////
/////////////// RS232 SERIAL PORT HANDLER START ///////////////////////
#int_TBE2
void TBE2_isr(void)
   if(tx_rs232_next_in!=tx_rs232_next_out)
      putc(tx_rs232_buffer[tx_rs232_next_out], RS232);
      tx_rs232_next_out=(tx_rs232_next_out+1) % TX_RS232_BUFFER_SIZE;
      disable_interrupts(int_tbe2);
void bputc_rs232(unsigned char c)
short restart;
int ni;
   restart=tx_rs232_next_in==tx_rs232_next_out;
   tx_rs232_buffer[tx_rs232_next_in]=c;
   ni=(tx_rs232_next_in+1) % TX_RS232_BUFFER_SIZE;
   while(ni==tx_rs232_next_out);
   tx_rs232_next_in=ni;
   if(restart)
      enable_interrupts(int_tbe2);
#INT_RDA2
void RDA2_isr()
unsigned int8 t;
   rx_rs232_buffer[rx_rs232_next_in] = fgetc(RS232);
   t = rx_rs232_next_in;
   rx_rs232_next_in = (rx_rs232_next_in+1) % RX_RS232_BUFFER_SIZE;
   if(rx_rs232_next_in == rx_rs232_next_out)
      rx_rs232_next_in=t;        // Buffer full !!
int8 bgetc_rs232()
unsigned int8 c;
   while(!bkbhit_rs232 && ++timeout<=10)
      delay_ms(10);
   c = rx_rs232_buffer[rx_rs232_next_out];
   rx_rs232_next_out = (rx_rs232_next_out+1) % RX_RS232_BUFFER_SIZE;
   return c;
/////////////// RS232 SERIAL PORT HANDLER STOP ///////////////////////
#INT_TIMER1
void timer1_isr()
//   set_timer1(TIMER_SET_01);  //0.1 sec
//   multipier10--;
//   if(multipier10==0)
//      multipier10=10;
//      num_seconds_LED++;
//      num_seconds++;
   //setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   //set_timer1(TIMER_SET_01);  //0.1 sec
   //multipier10=10;
   tx_radio_next_in = tx_radio_next_out = 0;
   tx_rs232_next_in = tx_rs232_next_out = 0;
   rx_radio_next_in = rx_radio_next_out = 0;
   rx_rs232_next_in = rx_rs232_next_out = 0;
   //setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_TBE);
   enable_interrupts(INT_RDA2);
   enable_interrupts(INT_TBE2);
      LED_SYNC_OFF();
      fprintf(radio,"%x", 0xAA);
      fprintf(rs232, "%x", 0xAA);
      delay_ms(50);
      LED_SYNC_ON();
      delay_ms(50);
      LED_SYNC_OFF();
      printf(bgetc_radio,"%x", 0xAA);
      printf(bgetc_rs232, "%x", 0xAA);
      delay_ms(50);
      LED_SYNC_ON();
      delay_ms(50);
PostPosted: Wed Aug 22, 2012 1:26 am     Reply with quote
The obvious big mistake, is you are talking to the wrong function.
_putc_ (and bputc for the buffer), is the function to 'put' data. You are printing to 'bgetc', the function to get data.....
micro_debugger
PostPosted: Wed Aug 22, 2012 11:38 am     Reply with quote
Hi Ttelmah,
Thank you so much for your indication. I corrected it as alo other small mistakes I have found. However it is still not working. I have used it 100 times in the 8 bit processors, but it is my first impression with 16bit. May be you can see it again, please, ansd have any idea. 4 eyes is much more than 2 eyes :-)
My best regards
here is the corrected code with your and some mine corrections
#device ICD=3
#build(stack=512)
#ZERO_RAM
#fuses HS,NOWDT,PR
//#fuses ICSP2
#define    TX_RADIO_BUFFER_SIZE       64
#define    RX_RADIO_BUFFER_SIZE       64
#define    TX_RS232_BUFFER_SIZE       64
#define    RX_RS232_BUFFER_SIZE       64
      output_low(PIN_E0);
#int_TBE
void TBE_isr(void)
      fputc(tx_radio_buffer[tx_radio_next_out], RADIO);
short restart;
unsigned int8 ni;
   if(restart)
#INT_RDA
void RDA_isr()
unsigned int8 t;
int8 bgetc_radio()
unsigned int8 c;
      delay_ms(10);
   return c;
#int_TBE2
void TBE2_isr(void)
      fputc(tx_rs232_buffer[tx_rs232_next_out], RS232);
short restart;
unsigned int8 ni;
   if(restart)
#INT_RDA2
void RDA2_isr()
unsigned int8 t;
int8 bgetc_rs232()
unsigned int8 c;
      delay_ms(10);
   return c;
#INT_TIMER1
void timer1_isr()
//   multipier10--;
//      multipier10=10;
//      num_seconds++;
   //multipier10=10;
      LED_SYNC_OFF();
      delay_ms(50);
      LED_SYNC_ON();
      delay_ms(50);
      LED_SYNC_OFF();
      printf(bputc_radio,"A");
      printf(bputc_rs232, "A");
      delay_ms(50);
      LED_SYNC_ON();
      delay_ms(50);
